Also referring to your email. Your stock OP6 Neo turbo only made 180rwkws on 14psi which that should be way over 200rwkws any where else.
a stock turbo'd rb25 making "way over 200rwkw" on 14psi... stao, whatever you are on can you pls organise me a pound? ;)
also trent's dyno with the appropriate correction reads the same as a dyno dynamics, my car has backed this up on 3-4 dyno's now
Well my stock NEO turbo made 214rwkw on 11.5 psi... dynodynamics... That's a LOT better than 180...
And given my stock R33 RB25 series 1 turbo made 192rwkw on 11psi on the SAME DYNO, I'd say that the NEO turbo should clearly be making more than 180rwkw.
Your definitely not going to lose 150hp through the drivetrain. More like 50 - 80 max.
So you really should be seeing an easy 260rwkw from this turbo, which is more like 350-360rwhp.
I have definitely got faith in Stao's products for the outcome he advertises them to produce, and his customer service is near second to none. You should definitely take him up on the offer of swapping his result proven turbo with yours, it will rule out ANY further question in the turbo itself. Like Stao has already told you, its not impossible that the turbo is faulty however it is far more likely that you have another problem somewhere else. I fully support Stao on this notion, and feel you may need to engage another workshop (after you have swapped turbos with him).
Can I ask what dump pipe you have on the car? Direct from the turbo to the cat, who makes the item and can you take a photo?
Fair enough, just a thought.
Looking forward to Stao's results with the turbo today. I am using a Tomei bellmouth dump/front pipe, I'll try to get a photo.
OK here's the post i started last page and got interrupted.
Hanaldo, hang in there! Take Stao up on his offer to send you a working tested turbo, swap it over yourself. drive it in to the dyno and get it tuned. If there aren't any more problems, and the tune is half done already then it shouldn't take more than 2 max hours on the dyno.
As for the power, I have an ATR43G2 .82 making PULP 270rwkw with boost dropping down to 15psi, E-Flex making 290rwkw with boost dropping down to 13.5 psi. I didn't even bother with setting my boost controller up on E-Flex to hold it higher...
All on a Dyno Dynamics Dyno.
And about your statement about buying this turbo for it's bolt on and concealiability. Here's a couple of pics of my engine bay. Remember this is a 290rwkw engine bay.
So yes you can make this turbo look very stock.
Well done on the engine bay, looks very stock indeed.
Yep, if I can make 167rwkw @ 7psi with a 2IU, and my friend made 200rwkw @ 12psi with his OP6...there is something else amiss here.
As I said, not too worried about the number, it's just a number. My power curve on the stock turbo was fine.
When my car had the stock turbo it was tuned on Hyperdrives old dyno. Their dyno was known to read 20-30rwhp lower than all other dynos in the area, so the power figure would have been about right. Since I have had the new turbo, Hyperdrive haven't tuned my car with their own dyno.
My R34 hit 182.7kw at 8psi untuned .. should be interesting to dyno again with a 10psi actuator fitted ..
Yeah who cares if the compressor cover is not factory with that airbox and scoop, you wouldnt be able to see it, nor would a cop bother after seeing it. Nice work! I gave up on trying to get the custom metal intake to fit the airbox nicely.
They will pick you up on it with a defect inspection though.
There's pod filter under the air box... which has almost no plastic left in the bottom of it :)
Of course if they go looking hard enough you'll always cop a defect, but my thoughts are keep it looking stock enough to give them less of a reason to go looking any further...
sorry to thread hijack Stao
That is why I don't see the point of a highflow unless it retains stock rear and front covers. if you are going to change one, might as well just get a full garret turbo and hide that as a low mount.
as soon as you go over the stock AFM limit and go Z32 it all becomes a bit pointless anyway doesn't it?
for the picky bastards who want to do ya on something, they will right?
Details please! Never heard of it!
Really it's custom, what I said before is probably a bit misleading. It was designed using a Tomei Expreme GTR dump as a model, so the dump section looks almost exactly like a Tomei dump pipe but made to fit an RB25 turbo and is 3" all the way through from the bellmouth. From there back it is a straight cut pipe to the cat. All one piece.
Made by Kermit :D
It's all just a gamble on how cluey and screwy your cop is. If they really wanted to screw you over, they would pull off the pipes and see that you don't have the standard comp wheel. It's all about how much you think you can get away with. The more you stick in there, the more power you get, but the worse it's going to be when/if you get defected for it all.
Change the pink sticker to a green sticker, that is all they can check and almost no one knows that is the difference.
It's not really because I have never ever heard of a defect station removing your entire intake piping to check the comp wheel size, plus I'm fairly sure nissan don't put the specs in a workshop manual so they would have no reference and hence no reason to fail you.
Edited by Rolls
1. Undo the E-clip on the wastegate arm (don't lose it)
2. pop the extender out and lose up the positioning nut
3. Rotate the extender clock wise (to make the rod shorter) to about half a hole sorter then where the arm is.
4. Force the extender back onto the wastegate arm, put E clip back in and job is done.
Ok so this has gone horribly wrong... The E-clip snapped in the process of getting it off. What do I do now :unsure:
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
