What's this talk about not doing z32 with your Nistune?
I have a Nistune with no Z32 presently and was about to get one.....
You are starting to worry me...
Regards,
Darren
I always get data corruption issues on the test car, and with the new illustration car it does all sort of random strange things and knock map is not responding to the tune. The test car goes onto the dyno every week so the data in it gets changed quite so often, I'm not sure if that causes the issue. I believe the boards or what ever the ecu its originally made for is ok. The Z32 ECU and nistune chip on R33GTST just didn't work probably on my cars. Which it's also the reason trent stopped doing those.
So are you saying that Trent won't tune my car now that I have Nistune & an r33 on a z32 ecu?
Nooooooo.....
Darren
He did say he will never do another one. Do makes sense after all those stuffing around and no results. Talk to him nicely and see what he says. :rolleyes:
Sorry, whats this prototyoe pu highflow?? The 230kw one, or?
The 230kw one is referred to as the ATR43G1.
The other one is the SS1 PU prototype, which has also been referred to as the SS1.5. I prefer the SS1.5 as its easier to say and type :)
Correct me if I am wrong Tao
How do you know for sure its data corruption? Did you read back the maps and they were all spiky or did the ECU stop running? These are the indicators that something is corrupt, otherwise there is a different issue. I have to have a chat to Trent about this one
Shouldnt cause the issue. If unsure read back the maps which were originally in it and compare what was saved on your laptop after burning the tune
The main problem with using a Z32 ECU on an RB25DET is the knock sensors. Z32 ECUs use the doughnut SR20 style knock sensors and RB25DET use the hose type knock sensors. I suspect there is more sensitivity and your ECU is jumping to knock maps
We normally recommend disabling knock feedback during tuning for this reason. Also Nistune software will now indicate which maps it is running from at any time. Boards dont lose their tune once a burn is performed as its stored to EEPROM.
Just a follow up. Found out that Pete did the install and was supplied with a 16 bit Z32 ECU
We officially only support (and have tested base maps) for the 8 bit models for RB25. Part numbers listed in our documents for 8 bit models should assist with finding correct units
We have not used 16 bit models so haven't got experience with these but from what Trent indicated there are issues with these ones as well as a glitch found with VE map RPM tracing (fixed in 0.10.9 software release)
spiky or did the ECU stop running.
Yes
Well I'm not a computer gig, I've emailed you all the issues I've experienced as a user, I guess trent will be happy to go into details when he's free.
I'm in the process of getting a LinkG4 will post up some feedbacks once they are installed and tuned.
Interesting. Best thing to do then is read back the tune before pressing the 'burn' button. I'm in the process of putting checksumming over the ECU code to prevent 'burning' with bad checksums. However is taking some time to implement since the ECU doesnt like being paused for too long (ie calculating the checksum takes time)
Well, looking forward to see you guys making some thing work Properly with R33 GTSTs in the near future.
Update:
This is for a set of GTR turbos that we've asked to match port their housings and manifolds then do a high flow. We will be using ATR43G1 profiles in those with FNT turbine modifications, They are expected to make some where close to 350awkws at full capacity as a twin on 98 fuel.
Photos in comparison:
Those are photo of stock GTR manifolds:
Photo of the pair that we've ported:
Photo of factory turbine housings:
Turbine housings we've match ported:
Profiled turbine housing to suit larger turbine wheel:
Machined and enlarged wastegate port:
Hello there,
I use Nistune with the Z32 ECU and it as never failed me.
The 16-Bit-Z32-ECU is not recommended by Nistune (that's why I bought the 8-Bit back then)
(Though I know people using the 16-Bit-Version, and there were never any problems with data corruption)
Also I change my settings (tune) quite frequently, and this has never been an issue either.
The only problem I ever experienced was due to a bad Consult-To-USB-Cable which caused connection issues and rom-images
not being read correctly. I then ordered a Nistune-Cable, and it works very well.
Maybe your ECU is 'damaged', (lose socket, cold solder, or ...)
Edited by Torques
They didn't work properly on my cars, the ECUs on them are fine. I don't want to discuss those issues publically, and I believe Nistune is working towards solving those glitches in their systems.
But don't you have the 16 bit version, not the 8 bit one?
Hello there,
Lets get this straight it is not a nistune issue as much as an incompatibility between some Z32 ecu's and the R33 car itself, we have done about 20 or so (upto 400rwkw) and of those 20 about 6 give major headaches (r32 nistuned ecu worked so its not the cars), since i cannot differentiate the exact problems between ecu serials and r33 model series1, 2 or 2.5 i have stopped doing them, Stao's latest issues were the 16bit ecu.
Nistune is a great system and is generally our Number 1 recommendation for S13, S15 and R32 / R34's.... just not R33 with ecu conversions :P
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
