Point him towards the diy section on here, then he can learn how to change injectors without taking the plenum off.
Girl like hands a needed my manly hands couldnt get in to take the plugs off
I've seen Trent doing it while ago. Remove the throttle body, which leaves you with a opening to fit your hand and tools. After removing all the brackets holding the fuel rail and plugs you can pull it out with all the injectors. Do the same putting it back. Not an easy task.
Easy job. Just be VERY carefull of the spacers under the rail. Easy to drop and lose
This.
Made my life hell for a few days the first time I did it (stupid enough to do it on the grass).
From memory all you have to do is push down on the clip part and you will hear a click and the plug will slide off, i think i used the tip of a screwdriver to push down on a couple of them.
I lost them as well, dont try to make some up with old rubber hose that "seems" hard enough to do the job.
also long pointy nose pliers and patience got the job done.
Hey Stao,
I currently have a gcg high flow making 254kw atw with full boost at 3200rpm. This turbo is great on the street with excellent response, great upgrade however i am in need of more power. The GCG turbo spikes at 18psi then drops down to 16psi and stays there untill 7000rpm.
What hypergear option would you recommend to achieve 280 kw plus, with very similar response to gcg high flow. I would like to run the nissan comp cover and also a rear housing which will bolt up to my current dump pipe. Basically im looking for a direct replacment bolton custom turbo which would make some more power.
Also if i decide to keep my gcg high flow can you supply me with a bolton actuator which can hold between 15 to 20 psi. My current actuator was taken of a rb20 turbo and it holds 10psi when boost controller is turned off. I think i might need a stronger one to maintain strong consistant boost, what do you think?
an electronic boost controller should let you hold 20psi+ to redline, this would almost certainly make 260-270kw which is what you are after yes? With small turbos like this they will always spike boost and then bleed down by redline without an electronic controller.
For fast response 280rwkws I would recommend the SS1PU version with a 20psi actuator.
By the way I'm doing some modifications to the SS2, not sure if it will work, but if so, I should get 300rwkws with SS1's response.
If this does work, could something like this be integrated into my turbo if and when I send it back for repairs?
Ah f**k, I found two of these hard spacers in my engine bay. They were sitting in the engine mount area. Could they be from my rail or something? I didn't fit them in, Advan performance did. Maybe they put new ones in, unless what ever they sit between can work without them...
Edited by SargeRX8
Have a feel under where the rail bolts on. Or use a little mirror to see if the black spacer is there.
Wolverine, hahaha, took 3 of us to find that little sucker, that was an injector o ring. I swear it was sucking the blood out of my leg and then just dropped off under the car after we had been searching for a few minutes
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
