Should be much the same, maybe a little less...I don't think the ATR43 comp housing is much bigger than the standard comp housing, if at all. I just wanted a more factory look so got Stao to high flow the factory comp. The rear housing is the same as the ATR43 so this is why it should produce similar results.
Apparently my turbo is now ready so I'll pick it up, install next weekend and get it tuned soon after.
sounds alright, just get a sensor to watch your intake temps..your runnign a PFC arent you??
Little update:
This is sent in from a member. Using an ATR43SS1 (none PU version) on a stock RB20det with usual mods. Car made 227rwkws on 18psi. Green is final tune, and Yellow is his previous tune on stock turbo. Running pump 98 fuel.
Yellow line looks much more like the SS1 on a lower boost setting than a stock turbo... Might want to check that stao
Been told by the tuner the yellow line was what the car had on stock turbo after it was tuned. It was back for return after new turbo was installed, Blue line was the SS1 on a lower boost and Green was final tune on 18psi.
That turbo had about the same response as a stock 21U turbo on a Rb25det.
that doesn't make sense, the stock rb20 turbo makes full boost far earlier than 4200rpm, more like 2800rpm.
The spool times look identical, it just looks wrong. Not to mention I am unaware of any rb20 that makes 195kw on a stock turbo.
Edited by Rolls
Except definition of "full boost" is differ. I don't have a boost reading yet, The point of where power starts to sprad is not where it reaches full boost. 195rwkws was archeived by the SS1 on lower boost based on the blue line.
I'm going by the information his tuner sent at this stage.
How is anyone getting that the yellow/stock turbo traces are reaching full boost at 4000?
They only show power and torque, not boost. The thing could be on full boost at lower revs but the engine isn't making a decent climb in power or torque until 4k.
Yeah, even if the stock turbo's result doesn't make much sense to people, no one has actually said how good the upgrade has been...that's a lot of power for something that needs a push to get up a hill.
Yeah it could be the typical stock tune midrange timing pull making the power dip making it look like full boost is there, and the full boost is at 3k where the earlier peak is. Good point.
edit: neo turbo has the bigger rear housing, maybe it was on full boost at 4k, makes sense I guess. Top result for a rb20 as well.
Edited by Rolls
I dont quite get how that pissy RB20 (flame suit on) can make 190rwkw on a stock turbo when a lot of us RB25 owners JUST make 200rwkw w/ stock turbo on a much ballsier engine..
its a 25 neo turbo
Yep i did read that, but still an RB20 with a neo turbo and typical RB25 neos (with neo turbos) both making in the vicinity of 190-200rwkw.. I smell somethings not right somewhere..
LOL I think I know what smells rondofj...
That makes much more sense the fact the yellow line was an R34 turbo. Great result by the SS1! Goes to show you that the R34 turbo doesnt really suit the RB20 engine as it has the same response as the SS1 which makes 30-40rwkw more.
People have made up to ~220rwkw with the standard turbo on an RB25, I see no reason the RB20 can't push 200 especially with the same turbo. Spool time and full boost would just take longer, which it does in the graph. Also allow 10-15rwkw variance between dynos.
Consider similar effect of RB25 vs RB30...they can make similar power but with the RB30 coming on much earlier. The 500cc difference isnt that great.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 😉. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 😍.
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 🙏 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 😉. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 😍 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
    • I've managed to find this: Nissan_Stagea_AutechVersion260RS (1).pdf
