Kasko you need to be aware that the feeling you're after doesn't last, you do get used to it. Like you keep referring to your stock turbo giving the feeling you're after, yet if I was to go for a ride in a stock GTT I bet it would feel like I was in a Getz.
Probably the reason why modding is so ridiculously addictive.
My stock r33 felt like a super car web I got out of an auto Mazda 323 into it haha
Cheers for all the info
Heres my torque graph. Never noses over. Keeps climbing. Maybe we should all run small wastegates and let the boost climb the more the rpm increases.
What kind of pussy are you? just weld it shut like all the cool kids whistling.gif
What kind of pussy are you? Just get a eBay split dump pipe like all the cool kids.
P.S. let's be careful not to confuse rear wheel torque with engine torque...
That's... Exactly what I said. Lol.
Most likely because of my lack of VCT, my G3 doesn't build torque very quickly. It still creates a lot of torque, but it's not a steep curve. My mates TD05 actually has a steeper torque curve, despite being more responsive. It makes less peak torque and less peak power, but the shape of his curve gives his car more of the rush.
Kasko, you need to be aware that the feeling you're after doesn't last, you do get used to it. Like you keep referring to your stock turbo giving the feeling you're after, yet if I was to go for a ride in a stock GTT I bet it would feel like I was in a Getz.
Haha ok but not having VCT would make it more of a rush because below 4500rpm you would have less power but the same top end as the ECU turns it off around then anyway.
Seriously though thats what I have always thought it would be good to have boost gradually climbing to stop the torque dropping off.
Obvious problem is though on a really cold night etc because the wastegate is maxxed out the boost would climb higher and could get you into trouble. I suppose if you had the tune allow for this it could be ok.
No it didn't... Power is directly related to torque. If it made 530Nm at 4200RPM it is making 233kw at 4200RPM.
Can you explain????? My car made 625Nm of Torque but my auto could only handle 212 rwkw
No worries, DVS JEZ on this forum tuned it - he has the dyno data for it also :action-smiley-069:
As has been discussed many times on this forum; "Torque" generally can not be compared between Dynos as they measure tractive effort and the torque reading depends on the calibration of the Dyno. Hence saying your 207rwkw SR20 has the torque of a 300kw RB25 is not correct. As you can see from Jez's graph on the previous page, his 300rwkw produces "700Nm" of torque on his Dyno.
A reliable way to calculate actual wheel torque is to use the Power and RPM readings:
T = (Px60x1000)/(RPMx2xPi)
See the way I see it if you are running the max airflow a turbo can provide at redline, then that same airflow at x psi will be x+y psi in the midrange, hence you should run more boost in the midrange to make the most of the turbo.
Like if you look at the compressor map then the same airflow at redline at 20psi is 25psi in the midrange. So if you can get away with running more boost at redline, you should increase the midrange boost to make the most of it.
Which is why I think turbos should be set based on airflow not psi. Though if you do it this way you are always going to have a massive midrange spike and have torque fall off by redline which just doesn't feel as good for some people, though for drifting etc it is perfect.
Thoughts people?
625nm of tractive torque, not torque at the engine, dynos don't measure engine torque they measure tractive effort.
if you are making 530nM at 4200rpm then you are ALWAYS make 233 kw at 4200rpm, it isn't possible to be anything else.
Edited by Rolls
Tomorrow night. A customers tyres got slashed at his place so ive finally got some dyno time to my self. Will post in kando thread
Must have been my exhaust that rowelled everyone up lol
FKN NOISY ASS CAR *slashes wrong dudes tyres*
The reason behind that is because your car is running on E85, High mount exhaust manifold and external gate.
Run pump 98, internally gated with stock manifold. That power and torque figure will drop significantly after 6000RPM. which is like:
There are lot more to think about when building a turbo made to perform on Pump 98 and internally gated. A turbo that can deliver performance internally gated on pump 98, has no issues cracking the extra KWs on external gate with E85.
Thoughts people?
Yeah if your car can put the extra mid range torque to the ground then sure. And that is specifically to do with a turbocharger.
In my previous setup it would spin the tyres when it hit boost in the mid range and then torque would fall off higher in the rev range so when you finally got traction it had lost a lot of torque.
I am more talking from a traction point of view. As speed increases, the greater torque you can put to the ground without wheelspin. Therefore ideally for maximum acceleration given a set amount of traction you would have torque increase with rpm.
From a traction perspective totally agree, in fact you see a lot of factory cars do tricky things to do exactly this, a sharp rise in torque almost always induces wheelspin.
Look at the 3L TT inline 6 BMW engines, all sorts of trickery to keep the torque flatish and not have massive peaks like our cars.
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around with a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
    • It ended up being that orientation of the float hub in relation to the clutch disk, when I installed it, I heard a loud click and being stupid, I decided to not take it a part and check it. The hub didn't properly align with the clutch disk and was causing the issue. Definitely an odd one! Dahtone Racing was able to fix me right up, stand up blokes!
    • Right, but I'm saying on the stock ECU measured airmass from the MAF is no higher than stock. So it's accounting for the higher flow rate iso-manifold pressure. You just have to keep turning down the boost until you're within the stock tune's load scale. If you run off the end there's no telling what will happen. This does mean there's zero benefit to the turbos you're running vs stock, if anything it's just a straight downgrade because the transient response is worse, you don't even get the ECU's boost solenoid helping to pull the wastegate closed during initial spool, and peak power is only whatever the factory map can give you before you hit the R&R corner. On a -9 I would bet that you would have to change out the wastegate spring once you have a real ECU and you're tuning it for real. I'm not saying this is a remotely ideal state of affairs, it's just a way to keep it driveable until you can get a proper tune done.
