Definately. I have another 2 hypergears to tune soon. Well 1 until Kasko buys his ss1
You'll most likely make that 3 soon, I called you Wed night - still pretty keen to let you tune the SS2 on my auto GTT
See the way I see it if you are running the max airflow a turbo can provide at redline, then that same airflow at x psi will be x+y psi in the midrange, hence you should run more boost in the midrange to make the most of the turbo.
Like if you look at the compressor map then the same airflow at redline at 20psi is 25psi in the midrange. So if you can get away with running more boost at redline, you should increase the midrange boost to make the most of it.
Which is why I think turbos should be set based on airflow not psi. Though if you do it this way you are always going to have a massive midrange spike and have torque fall off by redline which just doesn't feel as good for some people, though for drifting etc it is perfect.
Thoughts people?
Well for a start you will have a LOT more cylinder pressure around peak torque, where you don't want it..
cheers
darren
Edited by jet_r31
Look at the 3L TT inline 6 BMW engines, all sorts of trickery to keep the torque flatish and not have massive peaks like our cars.
But the sharp rise is what makes a fun street car and makes passengers grab the jesus handle. ;)
JET 31 - Why dont u want maximum torque? Thats the funnest part, yes its more det prone there but if the fuel is good enough then there is gains to be had, then let the boost build to redline and make crazy power figures.
If only...
Tao i agree, E85 is cheating. 98 is the devil.
I think its more to do with the wastegate gate setup. When Trent did the internal and external gated test, the hug drop in internal gate setup means the turbine is cooping with high exhaust manifold pressure as well as heat after certain rpms.
From experiments that I've conducted a large external gate acts as a secondary turbine that carries out compressor flow only when needed.
So getting good results from an internally gated setup: Comp flow = turbine flow
on the external gate perspective: Comp flow = Turbine flow + External gate flow.
As if I run G3 compressor onto a SS1PU's turbine with a large 60mm external gate, I should get the 300rwkws peek power from the G3 while having the 20psi by 3300RPMs response of the SS1PU. I will do some tests on that when I’m over with stockie boltons.
cheers
darren
You always have peak cylinder pressure at peak torque... that is what peak torque is. What I am saying is you can increase your midrange torque for any given redline torque if you are running flat boost. Assuming of course you are not limited by detonation due to fuel etc.
Tao i proved exactly what u are saying with my old sr20 and .6 disco potato. I changed it to a 50mm external gate setup and made an extra 15-20kw all over. Its amazing how much extra the car can breath
If only...
its a traction thing..its the way the max toque is delivered..
I know my with old turbo came on so much smoother with a factory airbox even ,just putting the pod on it would make it snap noticably harder into boost/max torque making it easier to lose traction ,which is fun but I prefered the smoothness and tractability with the airbox, even if it was making a few kw less...I could feed power on hard without slipping around or kicking out so much..
Guess it depends if you want to slide or drive..
Ur on ur own with that one. I see it as even if u have the power to break traction, with the correct throttle control u can be just as fast
IE me and you testing animals in the rain lol
Im just sayin it was a little easier to drive, not as much skill needed just smash it and go...
Sure you can do anything with "correct throttle control" but hey, if you have skill you dont really need synchros in your gearbox either...but they sure do make life easier...lol
Some Modifications that I've done to a stockie R33 21U turbo:
4inch inlet adaptor with SS3 comp wheel:
Looks all sort of stock I guess.
Would be awsome if I can crack 300rwkws with it internally gated on pump 98. :D
does it really need to be 4"? lol
cant it just be 3"?
Nope, the comp inducer is larger then the 2.5 inch inlet they had there. Had nothing left to clamp hose on after machining. lol
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
