that r33 turbo looks crazy, what size is the inlet on it now?
What are you aiming for rwkw wise with this version of hi flow?
Edited by Mitcho_7
I'm aiming to crack 300rwkws with a stock 21U R33 housings on pump 98. It felt abit too responsive as some thing maxing 300rwkws, can't wait to see how it goes once tuned.
Its a brae manifold. a duplication of my ebay SS manifold that cracked using steel pipe. its apparantly an expansive one time job that I haven't fully evaluate it yet.
I've also got an HKS low mount cast manifold fully surfaced with T3x bolt pattern. comes with HKS 38mm gate for $1200. PM if interested
Isnt 300rwkw on stock R33 housing going to cause the turbo to be running extra hot most of the time due to its tiny size and max flow squeezed out of it??
That can be compensated by machining out the internals of the factory turbine housing making a larger blow tunnel while using an extra large turbine wheel to compensate. Not sure to what extend thou.
Ive been away since the start of this year so did not have time to troubleshoot my lack of power and finish the tune with my SS1PU. Finally back home and having the car sorted out tomorrow. With some luck I hope it wont be too hard to work out the power loss issue before completing the tune.
Has anyone finished their SS1PU tunes and got final results in the last two months? Flicked through the thread but didnt see any.
Edit : Found one in the dyno results thread:
http://www.skylinesaustralia.com/forums/topic/55845-rb25-turbo-upgrade-all-dyno-results/page__view__findpost__p__6189807
Any more? ;)
Another update with the G3's rear housing. This re-makes OEM dump flange from the G3. enables better turbine flow, and increase the boost to power ratio.
This flange can be removed without removing the turbo. I'm happy to have above mod update all current G3 and G4 .84 units free of charge regardless how old it is, and good time to do the fnt mod for 2010 and earlier units. PM for details.
Its got larger opening area then the older model, how ever that would be the absolute of what can be fitted based on stock oem dump pattern. I've managed to get couple made last weekend, I can do it on exchange bases, as you can have the old one send back after the newer one is received. Its just 5bolt on the rear housing. pretty easy to de-tach. best to have it installed if the turbo is not yet fitted.
Edit: sorry I must need the original adaptor to work with as the wastegate wholes are individually drilled to suit the disc. will take 1 working day to have it complete.
Any more? ;)
Won't be much help to you at the moment, but I'm getting mine installed next Wednesday and assuming that all goes to plan, tuning as soon as I can book it in. Will definintely post results in here.
My SS1PU should be here by Friday!
My Nistune chip installed by next week
My Injectors early next week
Things are finally coming together and then I will post results.
Wouldnt mind seeing some good results
http://www.skylinesa...ost__p__6189807
Any more? ;)
Here you go.
http://www.skylinesaustralia.com/forums/topic/390356-for-sale-r33-gts25t-series-2/page__p__6227458#entry6227458
What power are you hoping to get?
Why is the new G3 more popular with u guys than the SS2, the SS2 has slightly more area under the curve (response) for a similar peak power output of approx 300-320rwkws.
I understand the G3 might have a tad more power/ flow potential being bigger? And of course its cheaper. Is that the reason? I seriously see the SS2 as a better turbo with the same power goal. Would compare it with a GT3076 /0.82
I went with the G3 because it makes more torque at each rpm increment than the SS2, and it makes more power under the curve (don't just look at boost or response here, the G3 is making more power everywhere than the SS2). The SS2 only catches up in the higher rpm to make the same power, the G3 beats it everywhere else, even if it's only just.
On Stao's results anyway, I haven't got those results yet.
Edited by Hanaldo
SS2 has better drivability and response. How ever working in restrictive factory setup larger housings definitely helps getting the power goal lot easier with better consistency.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
