Hey guys
Will it do any damage or cause any trouble if I put the SS1PU on without the nistune installed yet?
Trying to work out a way I can get the car to DVS without having to tow it up there.
I was thinking install the SS1PU and then get my brother to wire up a plug for my z32 so I can drive up with the stock AFM then just chuck the Z32 when I get there
how far are you going to be driving, isn't DVS a couple hours away?
It's very possible not to boost lol. If you want to install the turbo before you get it tuned then you don't boost it, simple.
On the stock ecu it will hardly boost before it hits r&r anyway.
I ran my ATR43G3 for a year without being tunned ran it on 7 psi and its ran great just laggy.
Loosen off the actuator so its sloppy comming on boost and you will be fine hitting up to 5 psi on stock tune
Possibly get a base tune by someone in Canberra and let the turbo run in, then go to DVS to get the tune tweaked?
If money is a factor, work out if it'll more $$$ to tow 4 hours or get a base tune here and drive up.
Hey guys
You will be fine. If the turbo is the only aftermarket thing you've got on there, it will be fine. 4 hours of tow truck.... gonna cost you. You can easily drive the full speed limits. Going up to his place is pretty easy, no pressure to floor it or go fast. Once you are on the free way cruise it there. Get all the prep work done before hand(as you are with the wiring) so when you get there and get to the dyno, minimal time is wasted dicking around.
I drove my car to my tuner about 20 minutes away first time. I had all my aftermarket parts in there except my injectors(didn't want to risk the wrong settings). It was running on the base tune with the z32 afm and it was fine. This drive was through start and stop traffic.
I can probably drive my car to the other side of australia at 110km/h without hitting any boost at all. Right foot, control and toot on. You won't hit 6psi unless you actually tried to. You'll be fine man trust me. You will get there faster than a tow truck will and you will have the money in your pocket to pay for the tune or pay for something else when the car isn't making the power it should.
Yeah he is at least 4 and a half hours away which is impossible not to boost
What kind of issues does it cause upgrading from stock turbo with the stock ecu.
Thanks guys
If you boost it you risk detonation, however what you can do is leave the wastegate actuator off so you literally can't boost more than 1-2psi by redline, do this.
ive been driving with my gtx3076 and stockish tune, cant do more than 2-3psi without the engine light coming on, you should be able to baby it around no probs
just change gear at 2500rpm with not much throttle, mine still keeps up with traffic even off boost, just shift up quickly and your fine.
taking the actuator off will make it sound very loud and drive like a dog, atleast thats what happened with mine.:whistling:
The turbo it self acts like a muffler of some sort, bypassing the turbine the exhaust goes through the open wastegate, it will be louder. It will run like arse, but its foolproof and safe if you are worried about foot control.
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
