Anyone wanna change my clutch so I can join this race :(
Got quoted $500 for the change
How much do you want to pay brosef?
I'll tell you if I am willing to meet your offer ;)
bummer u too hey...think I will have to get down and dirty and do mine the hard way in the carport..
If you were in Melbourne I could get it done for around $300-350 + $40 for machining the flywheel.
If you bring a flywheel and clutch with you, ready to be installed, I will do it for you for $250.
Im not a mechanic, but feel free to speak to Jez about if Im capable of or what not.
Am in Bankstown, just PM if your interested.
Yeah Canberra sucks price wise
But it makes up for things such as not many defects etc.
Birds and ARTZ we could always have said race in Canberra and at the same time do a 3 way......clutch change
Sorry, my hoist and workshop aren't exactly mobile lol.
Agree with Rolls, you won't find any cheaper than $250.
Birds come and get this part after clutch change. The turbo will be able to hold 20psi straight to 7000RPMs with it using a EBC. Should get around 280rwkws with extra 3psi of boost.
That part is $35 delivered. It's best working with the 14psi actuator and ebc. It will only work assume the cause of the drop is the strength of actuator. Will have no affect on retriction related boost drops.
Does that include the clutch or is that just fitting?
Love to man, but I can't run more than 16psi anywhere in the rev range at the moment...anything more and my motor starts pinging past what my tuner is comfortable with. So it'd be wasted on me cause I'm not even seeing 20psi in the mid range for it to drop off in the top end. It just runs 16psi all the way to red line.
Better off getting Kasko to try it as he is experiencing exactly what you're trying to fix. Once I convert to E-flex and can safely run 20psi I will look at doing it, if I have the dropping off issue.
Also, I don't have clutch issues, maybe you're confusing me with Kasko :/
For canberra, i think $500 is pretty competative. Does that include flywheel machine for the clutches which keep the stock flywheel?
I'd definently drive the 3.5hrs to sydney for $250 though.
Edited by Mitcho_7
Joined the hypergear club recently thought I'd share my story. After finding my previous highflow too laggy for my liking I went to stao and asked for response so he put together a turbo with SS1 compressor wheel.
Went to install it last weekend. When i finished fitting the lines and intake I spotted missing manifold studs. First and last. I went to tighten up the remainder in the hope i could still drive my car. Found 2 more broke and another seized up. fark! decided to rip everything off..
Called thread doctor but he was too busy, so i searched the internet for left hand drill bits and ezouts, couldn't find anything local (wanted it fast). wandered into a tool shop and found this:
An hour plus later....
got charged 120 for manifold gasket from nissan... crazy oh well needed it. $2.50 per stud wasn't too bad though
Anyway I've effectively changed turbo 3 times now. Getting real good at it lol. Hope that makes anyone struggling with their turbo install feel better.
Wonder how much the exhaust leak contributed to the lag and if i even needed to get my second highflow. Feels good so far anyhow. Not quite stock response still but heaps better than before. Would be interesting to compare to Bird's turbo since you have an actual SS1
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
