Update some results from the ATR43G2.5 internally gated.
This little turbo has pretty much all the big features from the original G3, It is 30kws short, with 300RPMs better response. It makes just under 300rwkws @ 20psi on pump 98 and 350rwkws @ 20psi on E70.
All runs are done internally gated using a soft 14psi actuator and EBC. The Lever mod works perfect on a .82 rear housing.
We've also trailed the Electric turbocharger, and surprisingly it made 2.1psi of boost, made a difference of 20HP and 44Mn of torque.
Stao that E-turbo is only on your DET motor, it will probably work better on a REAL NA motor. You should ask a customer to test it. With that sort of flow it is possible that it wont need any tuning.
That G2.5 is also a nice looking unit. I would be happy with one of those :)
The G2.5 has stepped down compressor trim from 58 to 56 and stepped down compressor from .70 to .60. Still in a .82 rear housing. This turbo has pretty good down low torque with excellent top. Don't forget this turbo is still internally gated. run external would easily gain an extra 20kws.
Performance was consistently around 285rwkws at 18psi on pump 98, realistically there isn't much of a point engineering a bolton turbo that goes up to 330rwkws while 290rwkws is all stock exhaust manifold can pump out internally gated
(also did you know cyc No. 1 and 6 on the OEM manifold does not line up to the engine head? boggie Nissans trying to cut budget from recall, Abe managed better result port matched)
I run the Echarger on my little Sirion with 1L 3cyc engine and it blew cyc No. 2 as soon as it comes to full power in 3rd gear. 2.1PSI from a 6cyc 2.5L would be about 5psi on a 1L 3 cyc engine. I think they all needs to be dyno tuned and checked before hitting the road. The shaft speed is fully controllable with a speed controller.
How ever E85 is seriously fun. Based on a solid 98 performer, making power out of it is a walk in the park. I keen to see what the G3 can do on E85, might be reaching 380rwkws internally gated.
BAZINGA! You've pretty much just built me the turbo I was looking for :)
You've got me. What is one of these puppies worth inc postage to metro Melbourne?
My intention is this + WMI.
Also what sort of battery/charging system would one require for the e-charger?
The internally gated Rb25det bolton version $1330 inc GST and oil line, and external gated version is $1080 inc GST and oil line.
The current E turbo runs on 44V that makes around 40,000RPMs. I'm in the process of getting a higher KV ed motor and some larger comp wheels. I think the current prototype is plenty for a little 4 cyc engine.
Do it!!!
That graph looks the goods just on PULP, putting out close to 200rwkw at 4000rpm and the difference between e85 graph seems negligible down low.
WMI should put you up near the e85 power up top as well!
It looks like a good balance between response and top end with limited boost bleed problems.
Stao, is the boost graph the same for the 98 tune and e85 (full boost by 3900) because it seems you only posted the e85 graph?
Edited by Mitcho_7
The E85 and Pump 98 made no difference in response. was getting the exact same response on both fuel, or maybe Trent didn't have enough time to modify sittings down low as we've tuned 98 prior E85, it was about 1AM yesterday when we've finished. There is still abit of work left in the ECU.
On road its mental to drive. it would wheel spin hard (not a the little wheel spin that makes a sound) at 3rd gear (so's every other gears except 4th). Its pretty dangerous to drag off the lights as I can't get the car running straight. I've only full throttled it once in 4th full throttle, didn't span out but its the feeling that I would not take my eye off the road even for a blink.
Its pretty responsive for the power range for every day with very solid power band.
Haha sounds like a ripper of a turbo - with aggressive power delivery and good top end- this could be one of your best turbos Stao :)
So your gonna buy one?
Fixed my clutch (kinda see thread in drivetrain)
This SS1 feels insane with the new clutch
It has no hesitation to spin the wheels in 2nd and even 3rd. Dragged Someone at the lights as well stao and smoked them literally
    • That still isn't a lot to go on. I don't have a Y50 Fuga Head Unit wiring diagram. I can say that a lot of nissans of that age shared head unit plugs, so if you are in Australia something like this would probably help: https://aerpro.com/app091# You plug that into the car loom, then either plug the head unit ISO into that (if it has ISO), or you buy and ISO adapter harness that you wire in. Bit of stuffing around, but once you have ISO its easy to change things in future.
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
