Good luck with everything Hanaldo!
What is a decent low mount exhaust manifold to upgrade to from the stock r33 one? Ideally one that would allow the use of the same dump/front pipe?
Finally started car for first time after installing the ATR43 G2 in the car and I'm a little worried. First turned car on for short period (1/2mins just making sure all intake setup was alright and no vacuum leaks) and saw steam start coming off the turbo so turned car off straight away.
I hadn't put coolant in the car yet so I hit myself in the head then refilled it all waited a little while and started car again. Was letting it idle to bleed the coolant and again lots of steam started coming off the turbo pretty quickly. Am I being paranoid or is it likely my coolant feed has gotten blocked off? I am still using the steel lines and obviously had to 'adjust' them so that they would fit up to the new turbo.
It's more likely to be smoke. You most likely had a bit of oil on your hands or you dripped a bit from the oil line, which is now on the rear housing or the dump pipe. It will just smoke a bit until it burns off, nothing to be concerned about.
Mine bellowed smoke for a good couple of minutes burning all the shit that I put on touching it the whole time.
Give it a few minutes and it will go away.
If it doesn't then check all the water lines going to it.
99% it's going to be the dirty turbo
Yeap. Every time I do a turbo on my own or another car I get lots and lots of smoke as it burns off my grubby paw prints.
Just make sure you are checking for liquid leaks. No leaks, no worries, let it keep running.
Awesome thanks guys I know i def got oil and such on the turbo my hands were covered in crap haha. The turbo shouldn't get hot enough to damage it on idle even if it is getting restricted water going through to it do you think?? I mean the oil is still flowing through it and some turbos are oil cooled only.
I looked for leaks and didn't seem to be any which I was happy about
Just make sure the oil line supplied with turbo is used and actuator is tightly shut with preload. Then that will he fine. Water is optional, they also works fine with no water.
Check your heater drain hose isn't fouling against the turbo too, this will give you a burning rubber/mechanical smell when the turbo heats up. I tied my hose back with a cable tie and it's been sweet since.
could have also cracked a water line when manipulating it, pissing a small stream of coolant onto the rear housing/dump pipe
easiest way to tell: what does it smell like?
S1 R33
3 inch dump,high flow cat, 3 inch exhaust
Apexi metal intake pipe with pod --- problem?
China fmic --- problem?
044 fuel pump
660cc high flow injectors
Superspark coils with copper plugs @.8
Nistune ecu
Eboost street
SS1pu
277.0hp @17psi
There isn't any boost leaks, we checked while there. I also double clamped all the pipes to make doubly sure.
I did check at the time whether i pulled all the rags out as well.
It's got me stumped, any ideas??
Drop the exhaust, that seems way too laggy.
Brand spanking new Apexi n1 pro installed on saturday.
I know whats wrong. Because he's from Perth. :D
Could be, could be ;)
Although last week the egt light came on for 2 minutes, then went away. But i checked out the cat when i put the exhaust on and it looked ok (3 months old)
This turbo generally makes a responsive 260rwkws with 18psi of boost, confirmed by couple of members.
Pre-dyno tuning you should have:
Proper aftermarket ECU that is designed for the model of engine
It appears to me like a R32 ECU + Nistune with no VCT activation.
Mechanically sounded engine
Make sure compression are good, base timing is correct and matches with ECU data.
Spilt fire coil packs with correct “copper” spark plugs
Good quality fuel injectors and a good fuel pump with a new fuel filter.
Good and effective 600x300x75mm intercooler, that excludes most of return flows.
Have a feel on the cold end with your hand after each dyno pull. Good cooler remains cold.
At least 3inch “metal” induction pipe with a free flow pod filter. This excludes:
Re-enforced or modified based on stock rubber intake pipe
Random ebay cast metal pipe made for factory turbo.
Custom pipe that goes into a sealed factory airbox.
If above is what you have make sure you change it refer to working examples from this thread.
At least 3 inch free flow exhaust
Excluding certain restrictive cats
Excluding restrictive mufflers
Good way to test it is by dropping off the exhaust pre-cat. substantial gain means restrictive exhaust system.
The last thing is the Tune. There are bad tune related examples from Perth, and there is very little that I can help with, apart from sending you a Nistune map based on the same turbo for reference. Give a try at "All star garage".
If there is a sincere believe of a fault on the turbocharger, then I'm happy to have it fully tested on a good setup in return of testing result and tune map, any defects found will be repaired.
No way am i disrespecting the turbo, i'm just after peoples opinions as to what could be the problem.
I will try a new fmic setup and a 3 inch all the way intake though, the apexi one is 4 inch - 2.5 inch.I'm starting to lean towards the cat at the moment tho.
As far as the Nistune, it's out of a zx and vct is fine, timing was also checked at the tuners.
I'll keep scratching my head, i guess i was hoping for someone to say "that's what's wrong you f***ing idiot"
    • My apologies. I forgot we were talking about weird beard M series stuff. Had been talking elsewhere with someone about an R33 with similar subject and got confused.
    • Nope, I don't like the look of ND RF, or any ND really, I don't like their faces or arses, why, because of their "modern" lines, the NC, whilst "modernish" has a more rounded shape that I like Well, that's how my overly judgemental eyes see it anyway
    • Should be more than fine, especially the overall fuel pressure would never exceed 3.5bar (assuming that thing never gets more than 0.5bar of boost in stock form). According to the chart, it's 11amps.
    • I definitely know the first rule here, look first, ask second. I've seen many people get roasted 😂 I found a few diagrams for the RB, but I'm yet to come across one for the VQ. From what I have read, the pump gets the +12v along with the FPCM, and it's the negative wire that gets passed through the resistor to regulate the voltage. So I assume I can just ground the negative wire at the pump to eliminate the FPCM control. But I really wanted to see the VQ circuit diagram first to make sure I understood it correctly. Once the new pump is in I'll do some testing to see how it behaves, and in the meantime, I'll keep looking for a wiring diagram. Thanks for your help mate, your time is greatly appreciated.
    • Maybe? I have the Supercheap ToolPro low thingo. It has a somewhat smaller diameter lifting "bowl" than you would expect on a workshop grade trolley jack, and a split rubber pad to suit that diameter. It clears the "N1" style skirts I have. Probably wouldn't if the jack's bowl and a suitably larger rubber block were in use. Having said that though.....you only need the rubber block to exist on the inner side of the pinchweld, so could carve away any rubber that fouled the skirt, leaving some there for "insurance" </simples>
