both those clutches are cushions. the way you tell is if there is a full disk or if there are paddles.
full disk are cushion (theres a wave plate between the two outer surfaces), paddle clutches are the non cushion type.
my favourite type of clutch are the multi paddle ones, sprung centre and 6 or more paddles. they are rarer, the exedys are usually 3, 4 or 5 paddles as a maximum. the more surface area you have the friendlier the clutch is to use. I think thats a better way of making the thing manageable than a pissy wave plate.
that being said ive got a pissy cushion button in my car too :P
cushion apparently, but it was TERRIBLE to drive, shuddered and f**ked my gearbox, in the end it still had massive bite and shudder but would slip on hard changes to 2nd.
I am renowned for having no mechanical sympathy haha.
Those symptoms point to the clutch being highly glazed.
you should order an organic HHHD next time. high clamp load but a forgiving material.
Yep that is what I put it down to as well, too much trying to slip it in traffic driving to work no doubt caused half of that wear opposed to actual abuse.
I ended up getting a Jim Berry organic after that, was much more appropriate, nicer to drive and held the power/abuse just as well. Have a similar thing in my r32 now, organic exedy HD I think with uprated pressure plate, holds 260 no problems.
yeah an organic isnt as bad as people think they are provided the pressure plate has the right clamp load.
i tend to recommend them over buttons in most applications.
I raise you my button clutch, I did this just daily driving the thing ; ) Totally destroyed it, you can see the heat discolouration and warping of the rivets, with only 150rwkw as well lol.
I did nearly exactly the same thing to the same clutch with just shy of 200rwkw. Didn't get thrashed to often and one day just started slipping. No such issues with the NPC :)
lol Dan, yours makes mine look like a brand new clutch. Speaking of which, reco gearbox and new clutch are in. It was dragging at first, so I swapped in a longer slave pushrod and adjusted the pedal. Now the take up point is a little too high, so I have to adjust the pedal again -_-
Only been on a short test drive, but she feels great so far - no more crunchy gears and the organic clutch is very friendly. Can't wait for my 1000km run-in period to finish, then I can see how this NPC holds up to the SS1PU...AND GET AN E-FLEX TUNE!
you should order an organic NPC next time. high clamp load but a forgiving material.
fypbrah
Yeah the poor thing took a beating!
So I found the rattling noise in my clutch goes away when I slightly touch my foot on the pedal this is before the pressure point.
Should have it back out in the next week and then we will know what's going on.
Can't wait to see your 85 tune and what power it makes! As soon as tax comes im hitting it up and also going to get stao to swap me a 14psi actuator
Lmao kasko the clutch killer.
never driving my car, good effort tho :P
Oi shhh! Don't tell people or I will never get a drive. Nah but honestly it was my first manuel car I have ever driven and also couldn't handle the SS1PUWERRR
Edit: I blame the SS
For anyone interested this is my setup that will be installed by the weekend, ss2 0.82 type b rear, ext gate 44m tial with screamer
and a comparison of the rear housing and wheel from factory
According to stao I have the most recent one. So not the lightweight one but the one after. Lol. Too many to keep track of.
Pretty sure the last 2 weight the same it's only design that is slightly different. I'm also getting most recent version
cool, what fuel will you be using?
You got both internal n external gates.. What the.. Welding the internal gate shut?
    • Nice, thanks for sharing your progress....that's a pretty long list you are putting into it!
    • Decided to upgrade my pressurised plastic coolant expansion tank for a fancy pants alloy version The OEM versions can get brittle, even the new plastic one I got when I first got the car is a starting to show signs of "stress" I wasn't cheap, but it is basically unbreakable
    • Morning all, I have an RB25DET Neo that's in need of a rebuild. Will need new pistons etc due to detonation damage. Would anyone be able to recommend a shop in Southeast Queensland who I could bring my long motor to for a rebuild? Just want someone who knows RBs and whos built a bunch of them before. TLDR - recommended engine shops for RB rebuild.
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
    • Losses have to be less with DC coupling. Provided the battery inverter has decent MPP tracking ability - which really shouldn't be a problem. It's not 2005 any more.
