I'll be be keen on seeing results for the td06sl2 int gate billet wheel as Im intrested in one but the kando ones have boost creep issues cause the wastegate hole is too small so hopefully this one outperforms it
Will you have them in t2 aswell ?
T518 style T28 internally gated patterned turbine castings are available. re-make another wastegate port and disc isn't much of a problem. How ever those turbos don't perform an where near to what they do externally gated mainly due to its turbine wheel and housing design.
I think there would be some money to be made if you could make a decent rb bolt on td turbine housing. Seems everything out there is pretty crap
Our current ATR28xx and ATR43xx Rb25det and SR20det internally gated bolton options are pretty mature, they would out perform most of TDxx turbochargers internally gated (and some externally gated). No point going over what ever already done. Do check them out for a bolton internally gated option.
Our Billet TDxx series will be engineered for externally gated purposes.
All turbochargers will be made to order in strict time bases, great support and customer services as always, and we won't be blocking any one on ebay.
Haha thems fighting words. Good work Stao!!
Stao, the nipple that goes in the top of Ss2 cartridge, do you just use a bit of thread sealant on it? The nipple looks like its supposed to have an o-ring on it but the chra is threaded right to the top with no recess for an o-ring. After a drive the top of the chra is damp with oil. Must be loosing 2-3mL each drive.
Putting loctite thread sealant on it now and will test drive again after lunch
Cool that's what I ended up doing earlier on. Just finishing oil pressure sender fault then I'll degrease it and go for a drive.
3 sleeps til it's tuned
Gahh im so impatient!!
How long did it take for people in perth to recieve there kit from over east ?
Its only been 8 Business days but it feels like a eternity!!!!
Looking forward to what it can do with my 34gtt :)
7-9 consecutive days. Mine has been over n back n over
My SS2 goes on dyno in the morning. Unfortunately the exhaust isn't as free flowing as I would like with a cheap Catco Cat on it. Will change it when I get back from Japan next month
What mods? Int or ext gate? 98 or 85?
I've already bought my ss2 int gate but won't be putting it on till next month
So a little eager to see someone elses result!
In gate, standard manifold port matched n opened up. 98ron. Poncams, port n polish, head chambers decompressed, power FC with nismo 740's,z32,3inch scotty intake,bell mouth dump to cheap cat to single muffler. Hypertwin. Freshly rebuilt engine
Edited by t_revz
Maybe just for the tune get a straight through?
You dont want to have factor in there that will limit your max output
Unless your tuner will do a touchup for cheap when the new one arrives?
Lol @ smash cat.
do it once do it right Trev, don't pay for 2 tunes coz you couldn't afford a real cat. You will need to retune if this one is a restriction and you change it later.
and yeah, you can YOLO it and smash it out. Mines permasmashed lol
I would have if it wasn't already so noisy. The plan is to smash it later and put a Varex mid muffler and retain oval rear muffler I have on it
    • I'm normally copping my own abuse from neglecting my daily drivers. "Those suspension bushes will last a bit more", "Don't worry about the oil leak, just keep topping it up". The project cars I'm always doing things slowly on them as I'm wanting them to be done better, and neater, and nicer. Luckily I don't have to deal with 18 year old Matt's "Learning to wire" stuff in the project cars. And there's only one piece of wiring I'm displeased about in the Landcruiser, and it's about to be cut out... However, the box loads of parts that have been going through this place lately for the Landcruiser... Brake pads Brake Rotors Full handbrake overhaul Wheel Bearings Seals Swivel hubs Steering Boxes Half the suspension joints Shocks Air bags (Ones to go in the rear springs for towing) Water pump Timing kit Lower timing case Harmonic Balancer Radiator Lots of other little seals and shits Gas struts for the bonnet New power window switches And god knows what else I've forgotten... Ha ha ha I have my fingers crossed the pinion seals don't start leaking on the diffs, that the transfer case doesn't leak, and the gearbox input shaft doesn't leak, nor the rear main seal. As they're about the only seals I haven't replaced in the driveline! I'm seriously eyeing off buying new caliper rebuild kits front and rear brake calipers... I'll probably recheck all the valve clearances soon too, and hopefully, it should be all good and sweet to haul some long distance trips again!
    • Every time I pull my 3x gauges out of the console and see the crack-addict way that I did the wiring, and I just can't bring myself to tear it all apart and "make it nice", because it is currently working. In fact, the last time I was in there I probably made it worse.
    • The best part is when you own the car long enough that you look back and find your OWN ham fisted amateur shit!
    • The annoying part about neglect, is when you start to replace one thing, and find ten more broken things. Ham fisted monkey repairs you normally only find out about when trying to do something unrelated! Ha ha   Neglect you can kind of anticipate the huge costs to fix it all. Ham fistedness is normally a shock the first time your work on a new old car, as everything "looked" good before.
    • For DBA, check out their guide table here. https://dba.com.au/wp-content/uploads/2023/01/Direct_Replacement-Guide-2021.2.pdf   Additionally they have some other guides and info on how to make sure you choose the right pad.
