Stao why don't you try make the TD06 work with you .82 type B housing?
with a little machine work you could be adding a whole new product to the market.
The SS1PU is not a GTRs.
2ndly if you are comparing td06 to a GTRs its never been compared on fair grounds. Install your td06 internally gated in a stock rb20det manifold plus all the EGR and road legal crap you would normally expected to run on a stock setup, The TD06 would not perform any where near a GTRs or a SS1PU.
All supporting mods counts, The turbocharger does not take all the credits.
I hear what you are saying. SO many people carry on that the std manifold is good for 300-350rwkws etc, I have long been an advocate for binning exhaust manifold asap...but others are happy to use it and hold back the performance gains available to them...combined with the fact for the same price of the HKS GTRS you can buy a complete TD06 setup. So based on dollars spent it is a fair comparison.
Anyway , interesting to see more billet results
So I received my JJR 3inch dump today.
It appears that the inlet area of the exhaust is smaller than the outlet area of the turbo. in some places about 0.5cm in width and length about 1cm. I'll try and machine as much as I can but doesnt appear to be that much room.
Thoughts? Will it be much of a restriction?
Heres a pic, not the best
It needs a little die grinding by the looks of it, as does the adapter Stao machines up imo.
Can't the machinist at least round the corners a little Stao? Is it a CNC mill?
All the corners in the .82 B rear housing has been rounded off, The flange area can't be any bigger, its been traced through the gasket.
For the Billet TDxx series to work probably there is a need for a proper exhaust manifold, external gate, and a front pipe. I'll get them sorted very soon.
Stao why don't you look into getting a spacer plate made which accommodates your external gate?
that way you can offer the turbos in external format and the user just needs to make a dump pipe, which you can supply a v band ring and clamp for.
Yeah will def be fixing up the dump pipe
Want everything perfect before I fit it all up and dyno it, rather than going to the dyno and finding out all these restrictions
Stao why don't you look into getting a spacer plate made which accommodates your external gate? that way you can offer the turbos in external format and the user just needs to make a dump pipe, which you can supply a v band ring and clamp for.
I should imagine that a spacer between the manifold and the turbo that is big enough to have an outlet for the wastegate will start causing problems with pushing the turbo outward/upward/downward enough to make it start hitting other stuff. Certainly on the factory turbo manifold you'll hit the strut tower after only a smallish push outward.
Ive seen one of those ebay spacers with the 2 bolt flange plate used to mount a precision turbo on a skyline before. It certainly can be done, and if Stao makes the spacer himself Im sure he can also make sure it fits well.
Then again he can just supply housings with a gate port
Dimensionally (in/ex) its the same size as the existing 20g, its blade design that changes. Front cover is the trust style .60
if changes have been made to either inducer or exducer I'm sure stao will correct
Updates:
I'm getting some steam pipe bolton manifold and high mount manifold made overseas as I'm typing. I should have a prototype received by mid next week for trailing and testing. Those manifolds will be available for $300 to our customers assume they perform as expected.
It appears a larger turbine setups would perform better on factory manifolds, I will trail a SS2 in a .82a rear housing on current std manifold for some comparison.
how these going stao.?.are you still going ahead with a cheap steampipe bolt on jobbie?
i'm keen for another turbo, probally a ss2 with the steampipe bolt on if it goes ahead, and stick a gate on the exhaust
housing, just waiting to see how it pans out
cheers
darren
Edited by jet_r31
Yes I've fitted the prototype manifold. It is awful, lots of dressing up work required and i'm certainly not impressed with the level of workmanship, the final product I will be selling will be a steam pipe manifold with every thing done to specifications. it will definitely flow much better then a stock Rb25det manifold.
I've re-enforced the the joiner, that is where its likely to crack.
I'm pretty sure this is what some people sales on ebay. The bolt pattern on the flanges for cyc 4 5 6 are all out. it won't fit unless dressed up.
Finally fitted:
By the way any one needs their wastegate opened up? we can perform this service for $120.
    • f**king around with the bro
    • Ludenham   44.2 tops day no issues
    • Then today, I went to visit a man with an r33 hat Peter and Road and Race sorted the alignment. As it is being set up for general track/hillclimbs etc it has a heap of caster (7o), less camber than I am used to (1o front and 2o rear, as the caster looks after that in turns without the braking downsides), 3mm front toe out and 0 toe rear. Will see how that goes and track tyre wear to see if it does need more camber, but adjsustment is also limited with nismo arms and adjustable bushes at only 1 end. It does have a bent inner tie rod on the driver's side front but as it came up within spec I'll just leave that as is. So, that is getting close to my chapter of this story....could of tidy ups then a shakedown in early October before it finds a new home.
    • So, it went to Unigroup for a run in and tune on Friday, everything went (generally) well. In terms of fixes, the engine was good and there were no leaks. It needed plugs (I hadn't checked them because the coil pack cover was on a new engine and I couldn't imagine they weren't new.....but turns out the temporary plugs to just keep it sealed up were in there.....new plugs gapped to 0.8 and it was fine from there. Also, there was a little preload on the clutch slave which caused some slip. I haven't had the box off so I don't know what the clutch looks like; my guess it is brand new and the pedal had not been adjusted....backed that off a bit and it held fine. Last thing will have Dose crying....the idle especially when cold is a bit difficult between the cams, forward plenum, atmo blow off valve and an 80s air management system. It is fine when hot but a little uneven when cold, will see if I can sort or at least improve that one cold morning. Other than that, tuning went fine. It made 245 but was pulled back to 227 which 2 opportunities to improve in future. 1. The factory CAS is not great and was jumping around at high RPM, so Mark took 2 degrees out up top (that is why it stops making power and lost 20kw). Very safe this way and the extra power is available but will require a more modern ECU and better cam (or even better crank) sensor 2. The 2871 in factory housings is very big for a low mount, and the internal wastegate is too small, so it was creeping from mid range all the way to redline....the duty cycle on the boost controller is turned down a little for safety. That is much harder to fix, it would need a large external gate and that would require a whole bunch of other changes, so it will go as it is for now. It feels nice and healthy and safe, so should be good for about a billion laps like this.
    • what sort of caliper are they? If they are a slider and you gave everything a good clean, you might need to regrease the pins. My guess though is they will come good after some abuse as suggested above
