Ah fair enough. I did actually consider it, I was tempted by the price. Unfortunately I'm in the same boat as Trev in that it's not my preferred kit. In any case, I should get my setup working correctly without WMI before I start using it as a bandaid.
What's missing from your setup hanaldo? I saw your powercruise video (sounds great) and can see your mods/output in your sig. Looks pretty good to me, just not running as much boost as some of the other guys are.
When he runs more boost it doesn't make more power unfortunately so he has to find what's causing that
Some further evaluation on a ceramic roller bearing PU high flow running stock compressor housing internally gated. The profile of this turbocharger is identical to a G2.5.
I've bought some actuators casings from Taiwan (probably same as Kando ones) and used 18psi high pressure actuator springs in it and it worked well. Best part is that I can add few washers under the diaphragm to load the springs to where I want it to be.
It made 341rwkws on E85 with the current manifold. It is 10kws short and 100rpms laggier compare to when it was on the Brae manifold even with more boost. How ever pretty good result from a stock looking turbo.
Haha thanks for that Kasko, pretty much on the money. Haven't looked into it a lot yet to be honest, graduate from Uni next week and fly out to Europe in 3, so been a bit preoccupied. Intention is to get into it once I get back from Europe next year.
Realistically those actuators are just big casings, the actual diaphragm and spring setups are identical to any other actuators. The best part of it is it allows you to change springs easily and preloading the spring by adding washers under the diaphragm of where the two bolts comes out. But apart from that its no differences to metal casing actuators.
Its probably good for turbos with small compressor housings, But It does run out of room when I tried to use it with a .70 comp housing.
Also our billet 18G compressor is ready, The profile is identical to our SS1PU compressor wheel but smaller in diameter. This wheel is made to flow about 10% higher then original cast wheel, while producing very dynamic on road drivability.
Our compressor casting has also arrived.
Tomorrow I will machine it up alone with turbine casting to have the turbocharger produced. It is currently available in 8cm rear, with 18G or 20G comp and TD05H and TD06SL2 turbine wheel. Price is still at $800 each. PM if any one's interested.
Also I've re-engineered the sleeve bearings with different oil grove for the ATR43xx turbochargers, tested today, which made them have similar boost building behavior as the ceramic roller bearing CHRAs, will get some dyno readings mid week against my CBB result. Free upgrade to all customers.
This project is mainly for Greddy turbo fans, but I don't like copying them in OEM specifications, so I will mix and match wheels plus some customized profiled billet wheels for them to be different. The goal is for dynamic drivability, Modify housings to fit different types of vehicles, and perhaps adding ceramic roller bearing cartridges.
I've had the T518Z billet version finalized today with every thing machined up nicely.
It is currently on 18G compressor with a TD05H turbine. I will machine one more housing using SL2 turbine tomorrow
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
