Technically assume the exhaust end can match the flow of the compressor it will produce the same power. I think the SS1PU can possibly produce around 340rwkws on my high mount setup.
We've tried 25~26psi it didn't make many more power and started to surge. So 22psi is about the sweet spot for this turbo.
Other thing to mention is how much power and torque it picked up comparing to when its internally gated and fitted to a ported stock exhaust manifold.
Yellow / (pink due to no ink) is SS2 on high mount ext gate plumb back @ 22psi
Red is SS2 on ported stock manifold @ 22psi
Blue is SS2 on high mount ext gate plumb back @ 20psi
Those results actually make me consider moving house so I can get a permanent garage space for the Skyline and be able to work on it!
It shouldnt cost much to convert your G3 to an SS2.
Doo eet.
Doo eet.
Well I'd definitely swap out the stock manifold for at least a Brae style low-mount external gate if there's such thing....so there's some more money. And a retune. And e85. lol.
However like I said, nowhere to work on my car :(
Well, if you do decide to do it at dont stop at the manifold and gate alone. Get the turbo done too.
To convert it to SS2 ex gate it would need a new compressor wheel, new front cover, and a new 5 bolt adaptor for the rear of your existing housing. Core, turbine and rear housing will stay the same AFAIK. That should be cost effective to achieve...
Kind of makes me wish I still had a skyline, or at least an RB25 in my 200 lol
But I do have THIS!!!:
happy for you to use my garage but you must help me take out my motor when the time comes and also get rid of my mate's shitbox lancer with a some ghey mivec motor.. it's been in there for over 4 months.
lol don't read this in the wrong tone, but uhhh yeah my whole point was swapping the turbo which would also result in me swapping the manifold too :P
I have the old .82 non-FNT turbine housing though, I doubt that's what Stao uses for his ss2...wouldn't he at least use an FNT housing?
LOL yeah, cars and money... What more can I say. I do understand.
The SS2 would be the .82 Type B housing. Im not sure if thats the same housing as yours or if the older spec is based on a Type A. Either way it would also have FNT, yes.
That older None FNT G3 should produces similar power as the SS2 once put on an proper manifold with external gate, won't be as responsive or have as much mid range. but I can always add the the FNT nozzle later to make some differences. The current 58T G3 would make towards the 380rwkws mark with E85 on the same setup.
The beauty of a high powered stock bolton turbo is they makes the differences once freed from OEM restrictions. The turbos are engineered to adapted on different types of assemblies, so they can be altered to suit OEM IWG, Vband IWG and EXG very easily.
This is my result using the .63 G3 turbocharger with Brae's side mount manifold but internally gated pump 98, But if its going to be on stock manifold I would strongly recommend a .82 turbine.:
Fair enough Stao, thanks for the info :)
If my turbo ever does come off, I'll likely have it modified to fit your most recent SS2 specs for external gate, and then I'll try to get an appropriate low-mount external gate Brae manifold made up.
Then 22psi. And e-flex sensor setup.
GAAAAAAAAAATE!
I haven't read this topic lately, in terms of using a standard exhaust manifold and standard comp and exhaust housings is there anything new to offer lately? Using that what power can be expected with full boost around the ~3500-3700rpm range?
I think I've done enough for standard high flows, The best you can get would be a SS2 core in stock housings, while we can run G4 turbine wheel that would probably make into the 280rwkws mark for the 21U / OP6 turbine housings.
I'm currently working on SS1PU turbocharger for external gate Vband. will post photos as its been developed.
Also I will be starting our face book blog which I will load in my turbo build as well as car modification with as much information as possible. I should've done 10 years ago lol. Please add us to your friend list
This is In relation to some of you whom has boost drop issues. Lot of that has some thing to do with how free flow your exhaust is. This is a reading of mine with a quite exhaust and cat, VS exhaust and cat dropped out from the front pipe:
Red = exhaust and cat on
Blow = exhaust and cat dropped from front pipe
Note the dropped exhaust is slightly faster in down low response with 1.2 psi less of a boost drop.
Can't remember whom it was, for the member whom had a G3 with 7psi boost drop, when hitting the dyno next, do a run with exhaust dropped and see if that fixes your problem.
Stao, I've got your PU high flowed R34 turbo close to 2 years now. its still going strong, what would it cost to upgrade that to your SS2? and do you have any results from this turbocharger on stock exhaust manifold internally gated?
Ss2 results on 98. Pretty sure all were on stock manifold or ported stock manifold. Also pretty sure everyone has the update 2 profile including me. Mine is the red line when it had a cam timing issue which is now fixed but hasn't been on the rollers since. Pictures are pretty shit but you get the idea
Well its pretty certain that this turbocharger it self is capable of making around 310rwkws peek on a Rb25det P98. Have a look into the index page there are couple of P98 results used as a stockie boltons. All results from test car are with aftermarket manifold or fully ported stock manifold.
This is 259rwkws out of a Auto, add 20kws auto transition lose, so this should be just under 280rwkws in manual
stock manifold but external gated from turbine housings (orange and blue lines):
And this is with a cheap $200 SS manifold:
In conclusion assume you have good mods, using this turbocharger as a standard replacement on factory manifold internally gated, the maximum you will get is 280rwkws, it will get around 270rwkws fairly easy, from 270 and on wards will be a challenge. Happens to all other G2.5, G3 and G4 regardless of how big the turbo is they all stops around 280rwkws with 18psi of boost. Their true potential unleashes once high mounted externally gated with a proper tune and good supporting mods.
To alter a PU high flow to a SS2, pretty much every thing is re-usable except a comp housing and a back plate. Cost will be roughly $400, from memory you are already making 280rwkws out of the high flow, it won't be making any more power, but will get your better mid range. Or high mount your high flow with a Brae manifold with a 50mm gate and bit of jungle juice, you will be hitting 350rwkws+
Other thing I need to mention is by increase the ID of stock exhaust manifold log didn't gain as much power as I've expected, and that is with a 45mm ID pipe. I'm going to try 60mm ID next and hopefully it can match the performance as my Brae side mount.
Its been a while since this turbocharger has been developed is any one with a SR20det interested of trailing? The evaluation price on it is $750, and I will refund $100 once receiving your dyno reading so it will cost only $650. I would prefer a SR20det with injectors, pon cams other supporting mods in Melbourne. PM if interested
    • Neg, the top one is actually for the front. The sizes are 18x10.5 +18 and 18x11 +32.   I measured many times but I'm sure I'll have problems as this is the thread for problems.
    • Just one thing; tapping tapered threads is tricky. Taps are always tapered and you would generally run it as far as you can, but with a tapered thread you have to stop much sooner otherwise the wide part of the taper will run in too far and you will have to thread the sensor in too far too as well (possible that it will never make a good seal) BTW nice wide wheels, I guess the top one is for the back!
    • Welp, good to know. Will have to wait awhile until steady hands with drills and taps are available. In other news, these just arrived! I will weigh them for posterity. Edit: 11kg each (or 10.9/11.1 depending on what my scale decides over multiple tests, the 18x11 don't seem to weigh noticeably any more than 10.5)
