Had a big day yesterday. I've had both new comp wheels trailed. Both of them are super responsive, feels like stock turbo pulling big power. Results are based on E85 fuel, high mount and plumbed back external gate.
The new billet SS1 with 60mm wheel:
Maxed out at 276rwkws, made 20psi by 3500RPMs. This turbo is bit small for a Rb25det, it is perfect for a SR20det and Rb20dets. when used as a bolton turbocharger internally gated with pump 98 it is good for around the 220rwkws mark.
The SS1.5 made 298rwkws peek, also 20psi by 3500RPMs. This turbo can be used on Rb25det, Rb20det or Sr20dets. Used as stock bolton on pump fuel, it is capable of around the 240rwkws mark.
Stao I had been waiting for these results for some time now, but I can see that the SS1PU on 98 fuel is still trumping them in every way?
On 98 the SS1PU (71mm) has more power and torque @ 3000 and 4000 RPM than both. In theory the 60 and 64mm compressors should at least have more @ 3000 and I would have thought the 64mm would have more at 4000? Especially considering the 60 and 64 were tested on E85 and highmount and the SS1PU was not.
Ultimately I cannot see the SS1PU doing anything but smashing these turbos in every way once on par. Considering your SS1PU result was on the stock manifold and 98, and these are on a highmount EWG with E85.
Any thoughts?
Maybe that turbo combo is just in a sweet spot for diminishing returns with the engine & setup you mentioned. Not too small to choke the setup, not too large that heat or other inefficiencies become apparent? :blink:
Yeah, I'm wondering if its something to that effect or if the SS1PU is just superior.
By COB next week I will know just how well the SS1PU performs on my SR.
What trim is the 60mm compressor wheel?
It doesn't show much on the dyno as it is 4th gear 100% throttle. But through every day driving using 20%, 30% or 50% throttle the difference is very noticeable. And this is probably as responsive as it can go in terms of not chocking the engine.
I've also trailed two bigger turbos yesterday, while the maximum that I could reach was 370rwkws regardless size of the turbocharger. Which is probably at factory cam shaft's limit.
Below is G3 in Type A rear housing:
and SS3 in Type A rear housing
After comparing results it appears the SS2 is probably one of the best turbos in its range for Rb25dets with factory cam shafts. It can perform reasonably well internally or externally gated and used as a bolton turbocharger.
While the SS1.5 and SS2 are the best turbos for people chasing mild power while maintain factory's driving ability.
The Billet SS1 and SS1.5 would be an excellent upgrade for factory Rb20det and SR20det's interms of mild power and response.
Also is the ss1pu overlayed in those results in pink or not if so seems to make more power and torque nearly everywhere down low there's barely any difference seems the better choice
If the ss1pu result was on e85 aswell not 98 should have made up for the power and response down low
Edited by hy_rpm
Pink is also ss1.5 the whole sheet represent the 1.5 with different boost levels. Also it could because the SS1PU was trailed on a stock manifold, the billet SS1 and 1.5 is definitely more responsive.
Turbine side of the SS1xx is identical, only the compressor size is different, theoretically small comp wheel deliver better response. I've used a large .86 turbine for the Rb25det, Smaller .64 turbine housings are used when configuring SR20det and Rb20det engines.
Because I didn't have a ready built SS1PU on that day other wise it should make very decent power on the high mount setup. Will trail that on my next visit to Trents.
With the SS1PU If you can run 23psi of boost, they can make up to 280rwkws on stock manifold internally gated. Other wise they generally be making around the 260rwkws on 18psi.
I'll see how gtscotts car goes what cams you running in your sr20
Mine is running Poncam type R's 256/11.5
Also a freshly built motor, bc springs/retainers/gears, cp pistons, manley rods, 850ccs, the works. The only thing im worried about is my HD clutch, fingers crossed on that front.
It will be dropped off at unigroup on Tuesday and ill be telling them to put my backyard skills to the real test.
Haha I know that feeling. Goodluck mate
lol thanks man. so far so good, it runs well and sounds solid without a drop of oil or smoke.
Its taken me 6 months to build it, funds permitting, so Im really looking forward to a rewarding result wherever possible.
Sweet same place I get my car tuned Unigroup yavuz is a great tuner
Got the same cams aswell buts yours has VCt as if you had larger cams would be laggier but more top end
What boost you going to run ?
Are you going to test it out at wsid after ?
Edited by hy_rpm
Non VCT man, I ditched the VCT because its too problematic in the SR's. Went with S13 type cams and got adjustable gears instead.
I'll just let them boost it till it stops making power to be honest lol, yeah I will get out to the creek once its all done for sure. Never been before though so for the first few times I plan to be just watching the traps to see if it backs up the power. Dont have any bags either so a little worried about what tyres to run too.
Further update: This is SS2 turbocharger have trailed of our newer brass bearing setup with alternative oil delivery gallery. Video shown turbocharger after the car has been shut from idle. On road it starts building boost and build boost to full just noticeably faster
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
