Stao is it possible to fit the SS1PU with the TD06SL2 turbine?
Spool doesn't appear to be any worse, I may consider trialling this on my SR...
SS1PU and SS2 all share the same comp wheel so identical to whats on the TD0620.5G
The SS1PU SR version is in .64 while the 10cm is in .73, The 20.5G can only preform in a high mount externally gates setup, I think you really need to have the car returned in a normal day for the correct power and boost correspondence after run in.
I haven't done the SS1PU RB version against SL2 turbine yet, that should give me an indication of which turbine is more responsive, how ever also need to be taken into consideration that the SS1PU does not require external gate.
I'd be keen to see the difference. I have always been confident that the SL2 turbine is the right way to go on the SR.
I am really happy with my SS1PU, but who doesnt want more! lol
I love you work Stao...own a big share of the bolt on turbo skyline turbo market and a good product at a good price, gets his reign threatened by a another product
buys same product and redesigns it better, effectively taken out his competitor with one foul swoop and in turns merges 2 popular
sau threads into his both of his..roflmao ..well played sir..I tip my hat to you...
(yes im joking, but its still funny)
cheers
darren
Edited by jet_r31
The kia made 110fwkws from 73fwkws on stock injectors and it appears the stock cat back is also maxing out. I've fitted a ATR28G1 on it with high comp engine it has no lag, very fast off the lights. Its at Adaptronics making plug in ECU at moment and its been there for almost 6 month as he has issues getting stock auto to operate. This project is made for a Chinese 4S Kia dealer, Detail write up and photos has been posted at their forums. You might need google translation to read it, but photos are fine.
http://saa.auto.sohu...4673727-1.shtml
Also for people whom's interested in to twin pulse turbine housings. I'm in the process of making one that has a working VNT valve. It is made to work with a single or twin pulse manifold. Designed to switch a .41 A/R turbine housing into .82 after boost pressure rise beyond 12psi, it should dynamically advance down low torque and power while not hurting mid and top end.
will post up photos once its complete.
Well, work wise its all about the amount of time invested, Like I've be in my shed building and trailing different turbos while most of others are out with Mrs lol. All make of turbochargers has its strength and weakness, I don't have a Bias for or against any, but do enjoying improving them as well as putting new ideas into inventions.
Taking my car to the quarter for the first time tonight, see how it goes. Will also get to a weighbridge today sometime.
Ahh spewin I would have come straight from work if I saw this before leaving. Good luck
Stao do you have cam gears in your car? Power peaking in your car at 6800 is unusual for a T67, all the other results have made power right up and past 8000rpm. All your results seem to have strong late mid range and then fall over top end, cam gear timing is the only thing I can think of? Have you talked to Trent about it, I do remembering him commenting on something similar in the past
Good result, would hammer!
for the big turbos playing with gears may help extend the top end but on this car it always trades off low and we are chasing results which fatten the low to mid... aimed at average setups with std cams and 7650 rev limits.... no need for more top end.
For those who want more a set of drop in cammtechs on this 390rwkw will go 420-430rwkw with no changes to mid range as we did one not long ago.
Going through books, The wheel dia of the 20G is in 68mm while the 25G is in 78mm. 10mms is a pretty big jump in terms of compressor wheel dia, I'm wondering what happened to the 21G 22G 23G and 24G if they were ever existed. I have some plans on making a 73mm wheel to run the SL2 turbine on, making size wise a 22G.
Make a 73mm billet wheel with a modified stage 3 sierra wheel and somebody in the US might be calling you about some patent issues lol
Hahaha maybe he could be FORCED into it huh :woot:
So, went and had a bit of fun last night. First time down the quarter, shit is hard :glare: Got 5 runs in and got better each time, first run was a 16.55 missing 2nd and 3rd :P PB was 14.1 @108.5mph on my last run. I think I could have got into the 13's if I could have had a few more runs, and possibly matched Luke's 109. I need a lot more practise though, and shift lights now make sense to me. Was hitting limiter in almost every gear :/
??? some one already done a 73MM? The blade profile will be totally different either way, but thats ok, I can make the exducer into what ever dia to archive the same goal. Sierra wheels are bit old school, they were retired from our turbos since 09.
Using Brae high mount now. Ebay manifold is off the car.
Saw it on Facebook mate and was wondering how long it was going to take for you to post lol.
Close result to me on the airport run
Got a glance at my results at the dinner and it was 14.3 but don't know the kmh
    • Agreed, I've never seen a 260RS specific manual. As GTSBoy said it will mostly be stagea other than the engine loom https://www.hgeconsulting.com.au/stageaservicemanual.pdf
    • You'lll likely have to make do with R33 GTR for engine/tranny stuff, and Stagea for the body. I don't know that there's even been an actual diagram seen in the wild.
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
