Driver fail.
Pretty much! I'm sure it has the potential to break into the 12's.
One day when im bored i might get hold of some stock rear shockies and dampers. Instead of either bogging down or lighting the tyres up every time, it might absorb some of the initial shock and grip a little better.
I need to also get some new bushes for my diff, helps with dreaded axle tramp apparently. I know for sure one of them are knackered.
Years ago my sil180 with 230rwkws got up to 13.4sec quarter driven by dr drift.
I'm no expert, Just personal experiences, need avoid that big wheel spin in 2nd going fast , ease a little throttle actually get better acceleration time. I got a D-box, its a very good toy for practice launches and quarters.
2ndly a proper manifold and ex gate setup would help heaps with up top torque, I felt that straight way after installation, will pick up more HP too. That top end torque would definitely help getting better times.
Also BB research is so far at a level that I'm pretty confident with. I have 2 more sets of bearings and can convert any G series to rollers for $200. in case of failure I will refund the $200 price difference and rebuild it back into brass bearings. Please let me know if interesting in trailing.
The wheelspin into 2nd won't really affect trap speeds though, if anything the heavier throttle/looser my runs the better the trap speed - big bogs were the main thing that seemed to cost me mph
Yep I also think a slippery launch still nets decent MPH, bogging out is more likely to cost you speed than spinning a little.
Stao does $200 also apply to my SS1PU?
Usually if you take off faster or your 60ft is lower your trap speeds will be lower
The shitter you take off bad launch high 60ft will net you higher trap speeds Aslong as you don't miss any gears and are flat foot till the end
Further updates:
Today I've trailed our SS1PU and Roller bearing SS2. Both Externally gated and E85 Results are below.
SS1PU maxed out at 322rwkws with peek boost of 20psi. This turbo is super responsive as usual.
The Roller bearing SS2. I believe This is probably the best turbocharger that with the perfect balance of power and response for a stock Rb25det. brilliant on road driveability. It maxed at 374rwkws with 22psi of boost.
We compared few runs against it including our new ATR-SL20.5G, 25.5G, as well as Bush V BB. Will upload bit later.
Awesome results Stao
How do these compare to the Ceramic bearing turbos?
Also let me know about that oil feed fitting from the block to turbo :) Might need it in the next 2 weeks :D
Compare to the older ball bearing setup, the difference in oil drag won't make enough differences that can be picked up by the dyno. I would call the latest more reliable, as harmonic vibration separation has taken into account. means the shaft harmonics is not affected by engine harmonics while both are spinning at high speed. I've spent many late nights and time getting that working.
89cal: The engine fitting has been sent. See how it goes, send it back for upgrade if there are any issues.
This is SS2 Ball Bearing V SS2 bush bearing. Please note today's dyno run used an proper externally gated setup while the older run had an external gate plumb back setup. There shouldn't be any differences in top end assume both runs are based on the same setup. On the same time, evidence in differences between plumb back and atmospheric ventilation.
GTScott: Sorry won't be able to BB SS1PU, make no differences either way.
Reading below contains the ATRSL220.5G, SS1PU, STDSL220G, and SS2BB.
What were the rear housing size differences and what fuel?
The ATRSL20.5/25.5/STDSL220G are all based in a 10CM turbine
SS1PU is in a .86 turbine
SS2BB is in a .82 turbine.
All on externally gated setup with E85 Fuel.
I just got my Hi Flow turbo finally delivered, how much shaft play should there be?
I'm used to buy new turbo's, so used to almost zero, I'mm getting pretty much 1mm of side movement, not even the old RB20 turbo I have sitting here has that much, nor the VG30 BB one here either.
Maybe once it's had some oil through it and run up it will change, but it sounds awfully noisy moving the wheel around!
*edit
Ran some Moreys oil stabiliser through the oil feed and sealed it up to stand for a bit, seems to flow a lot better with less movement, forgot a bush bearing uses oil to basically centralise it and float on.
Cary on !
Edited by Brett_J
Yes when they are assembled brand new the bearings are dry. Once oil goes in it will be fine.
This is some modifications done to a G3 compressor housings that is made to accelerate the discharge velocity. Will do some trail on that soon as long with roller bearing assembly.
Photo of SS2 High flowed into M35'S VQ25 turbocharger with 38mm internal wastegate.
Updates on the G3 profile. I've done a trail run with the G3 today using compressor assembly above with roller bearing cartridge I have to say it is amazing. the response is at least 300RPMs more advanced with heaps better throttle response. Any one with a current G3 in Melbourne is more then welcome for a test drive.
Will be hitting the dyno next week for an comparative run against original G3. Once done I will be happy to swap it with a current G3 customer at no cost.
:action-smiley-069: does G2.5 count? more then happy to swing by for hyper wagon fun this weekend. You be working?
For the G2.5/PU high flow I can only mod it into roller bearings but this comp profile is only suitable for G3.
The new G3 has a different comp housing profile. made to accelerate the discharging velocity, I can definitely feel the differences on road. The effects of it on top end power band is unsure so will hit Trents for one more dyno run.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
