sorry, could be stupid question....
if we could make a twin low-mount VNT RB26 setup work, would you modify my HKS 2530's or would i need completely new units?
Thanks for the feedbacks.
I can make it work with the GTR turbochargers, you will need to find room under the bonnet as they will need to run two actuators side by side.
I don't think there should be a reliability concern, concept is pretty solid and working well. I can make it working with your PU high flow as well, once again just need to find room to fit the additional actuator unless going high mount. It should knock lag off by about 500rpms.
Cummins/Holset turbos had a problem with VNT on truck engines. Was something to do with the variable vanes or actuator getting clogged with carbon and not allowing the vanes to fully open or close. The turbos have speed sensors in them so when this happens the speed of the shaft is too high or low and the engine de-rates
Vague random information. But its not a problem when there is no speed sensor, or at least there will be no major problem with the car. You will just have reduced performance or increased lag till its sorted.
This is an issue with specific turbos though and does not necessarily apply to stao's design. Im really looking forward to what happens with this in the next few months. So tempted to trade mine for a VNT still lol
interesting... could you advise on a price please? PM if you want.
would it be worth doing a ceramic bearing change at the same time? were the VNT units that you were testing ceramic rollers?
All sorted
Pre load was never sorted at install as I expected it was already set up, now I have to get it retuned as it's hitting 20psi when it was tuned to 16, lol.
Which means it was bypassing boost before it got a chance to build it, still laggy but not as bad, but now leaves lines at 1-2 change with half throttle :)
  • Like 1
All sorted
not all bad news after all! Small issue easily resolved and find a way to improve the performance also.
good work.
i cant see it fitting package wise on a gtr... would be awesome though.
the bearing in these units are pretty extreme, we compared them to the best available turbocharger units and the hypergear ones are in another league. i cannot divulge the origins of Toa's bearing but they are very under stressed in a turbocharger application... they are originally designed for military aerospace applications and run at around $200-400 per unit... and there are multiple units per Hypergear turbo.
im pretty sure tao was looking to find a suitable test car that sees plenty of circuit work to complete proof of concept.
Again i am not endorsed or ever received anything from hypergear, im just excited about his new developments and i still believe this is the most interesting turbocharger to ever grace my shop.
Thanks for the feed backs.
I will be back with the SS1PU with VNT turbine next week, if test of it goes well with the Rb25det then I will leave this turbo with Trent for his Cefferio for some track work and in comparison to his current TD05h.
With the GTR I can modify the original -5 turbine housing you have with the VNT setups, the only problems is fitting 2nd actuator and bracket, which you might need to make some alterations under the engine bay to make extra room for. But apart from that it shouldn't be a issue.
Stao, i'll PM you
my ultimate setup
Super high compression 26
pistons to allow for the upgraded V-cam gear (more timing advancement)
Chequered Tuning V-Cam
Twin Hypergear 2530 VNT's
E85
add boost :D
bah!!! soooo tempted...
  • Like 1
If I ever own another GTST it will have a Hypergear 2iu highflow.
That car is incredibly fast. 1:04 is incredibly fast. I am blown away.
That turbo has done a lot of track work now as well. The response and the way it delivers torque is amazing.
It does lack power in a straight line, but what can you expect for a little 21U housing.
Tao has tried many times to tempt me off this turbo. But I love it too much.
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
