Any updates on the SR motor of yours Stao? my brother is looking one for his 180sx, tossing between one of yours, and a 3071.
Well 3071 is very laggy on my SR. 180sx doesn't have VCT so it won't be much better then mine.
Getting things to work on the SR is much harder then on the RB. The current VNT turbine system have only made the car hitting 1psi much quicker, at 5% light throttle I can hit 1 psi. from 1psi to 20psi still takes for ever, there for, no end result differences. Doing some evaluation on SS15 on .64 rear at moment and it drives nicely. So further evaluations to be conducted at this stage.
One of my FiveO motor sports's 1200 injector gave up the ghost last week after 5 dyno runs, which is abit disappointing. getting replacement installed shortly for SS Alpha bolton series evaluations soon.
So, my r33 turbo is getting highflowed at the moment, (thanks Stao!) what are peoples thoughts on what power it will make on an rb20det on 98?
Usual support mods, nistune, z32, 800cc sards, return flow cooler, 3 inch turbo back, metal intake pipe
Have seen results of previous highflows, but not results on the current profile on a RB20.
Cheers
lucky you've mentioned it, I didn't take a note that it is for a Rb20det.
The current R33 profile would be able to support roughly 250rwkws while older profile would be more responsive maxing towards 230rwkws. So would you prefer power or response?
Some updated photo of the SS2 M35 Stagea high flow with our latest SS2 compressor wheel, and latest SS2's turbine wheel which is 3.5mms larger in diameter to the older version with a 2 degrees difference in blade radius. Please note the internal gate is to be enlarged which didn't take place when this photos were taken.
And of course never stop trying. Here is a newer version of a ATR43 prototype, aimed at high 300rwkws with optimum response. It is for Mr Hovic's drift car.
Updating some results:
SLSS2 as some have already seen. Final result of 356rwkws @ 23psi factory engine stock cams E85 fuel.
Brae manifold, Externally gated.
21U high flow on a R34 Skyline, final result of 266rwkws @ 17psi Pump 98 fuel. Going with high pressure actuator for 20psi, hopefully be seeing close to 300rwkws soon.
ATR43SS2 factory Bolton Turbocharger on a stock Rb25det powered R32 with No VCT. Final result of 328rwkws @ 21psi E85 fuel.
My brothers evo booked in for a tune next week
Stao fitted a slss2 chra to his evo 9 turbo
Hoping for 280+awkw on 25-27psi
Dives nicely on current tune gate crackes at very low 4000rpm untuned won't let it go over 20psi on 18psi actuator
  • Like 1
I would be interested to see the graph as I have the same highflow in my evo7, just waiting for the engine builder to finish his work.
Stao I'm curious to hear what you think of compressor housing size and power levels , where you think the cut off points are for the 0.60 T04B , the 0.50 and 0.60 T04Es . The T04S is usually as big as most go and I'm curious to hear how much difference you think there is between it and the 0.60 T04E .
Also can you supply a T3 spacer plate in 15 to 20mm because I can't easily get one , GCG advertise a 20mm one but they don't have them and don't know when ...
I have their longer studs and I want the thicker spacer to cover any future updates , do once do right .
It's no secret that I don't like the S covers mainly because they look bigger even if it's not much over the T04E port shrouded one . I just can't get my head around using a supposedly 700 hp comp housing on a 4-500 hp compressor .
There are a few less common compressor housings floating around like the 0.70 AR T04B and there may even be a T04S 0.60 AR . I remember Brett telling me years back about a 2" outlet comp housing they used as an upgrade to the XR6Ts T04E one so there must be a few odd ones out there .
Thanks Stao , cheers Adrian .
Edited by discopotato03
Hey Stao,
Was there boost controller issues on the 21U highflow on 17psi?
I'm going to be going E85 on my R34 in the near future with the same high-flow and will only be looking for a high boost setting of around 18psi
Just dynoed the atr28ss15 on my sr. Made 270rwkws on pump with 22.5psi at 4000rpms. Will upload sheets and attend questions when I get back home.
What turbo you going now gtscott
Cashed in on the MTQ GTX sale, now have a GTX3071 and will be installing over the next couple of weeks.
Picking it up tonight to start rigging it up.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
