Evo 8 stock block
Fic 1120 cc injectors
Deatchwerks 300 fuel pump rewired
Caltex eflex
K&n panel filter std airbox
Ces racing exhaust turbo back split dump pipe screamer
Gsc s1 cams
Hypergear slss2 hi flow evo 9 turbo 25.5 psi 4400-4500rpm
SLSS2 is making 285AWKWs so far. I think it will stop making power just under 300awkws at 29psi.
Stao what about run a big compressor wheel in a small turbine housing then use a large internal waste gate to compensate heat and flow? I have seen few turbos from Euro cars been made that way like the Audi K03 and K04. Might be a good thing to try on.
They only work with low boost level applications, some thing under 16psi would work great. The compressor and turbine end must be welly balanced. As in the back pressure needs to be similar to boost pressure so forces generated naturalizes.
At moment with the SR its matter of evaluating different wheels and housings for some data. Once the limitation of compressor and turbine is determined, I can then mix-match or make some thing very specifically to suit either end of the turbocharger. That way I have a balance flowed turbocharger that makes good power for its response and last.
So this is the turbo I bought for my 2.3 stroker evo Stao? I was hoping for a little more than that... :P
Stao,
have there been any updates for the CT12a turbos, one of mine pissed its pant suit on the way to work this morning.
Just looking at options at this stage...Is it possible for you to supply a manifold, gate and TD06 or similar turbo to suit a 1J?
Thanks
Zeb
For reversed turbine wheels there sin't that much of option yet available. Need to see what I can find.
KAMAK make a 9 blade SL2 wheel, I believe they call it their STS wheel. Why don't you guys try this? No machine work required, just assemble and balance.
Its meant to be a much lighter wheel, too. It has the potential for very snappy throttle response with the billet compressor.
We can high flow them and they will be good enough to support 300rwkws on a manual with supporting mods. Lot of work is involved in doing it how ever. So it might be working out cheaper with an high mount, but depending on what it is.
The cost to high flow both CT12As is $1800 and they needs braided oil and water lines after high flowing.
Alternatively, you can use our ATR43G3, SS2 or SS3 depending on what sort of power you are after. G3 is $900, while SS2/3 is $1150. 50mm HPVA gate that Ive been using on the R33 is $300 with the turbocharger. and Brae manifold is $1100.
There not reverse rotation only very few people sell reverse rotation turbines in the us
Kamak definitely make a 9 blade reverse TD06SL2, just need to ask.
Need to ask brae on this. Usually about weekish.
Cool
So, If I said I want a turbo with a big midrange, going on to make around the 300rwkw mark on 98 what would you suggest? the SS2?
Would be after something with a V-band dump pipe set up preferably.
The SS2 would be the most reliable turbo for this setup. The externally gated version usually comes with a Plate which a 3 inch metal pipe can be attached to as the font pipe. Or a Vband assembly extension that cost $100 additional.
details are at:
http://www.hypergearturbos.com/index.php?route=product/product&path=72&product_id=54
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
