Yes definitely can. Its not so much of a turbine wheel, the rear housing doesn't have enough materials in side allowing the correct blade radius. I'm in the process of custom making a T3 .58 turbine in to a SR's T28 pattern. Once proven then we can technically custom any T3x printed turbine housings and use any of the customized wheels made so far.
Further evaluation based on the ATR28SS2 Based on a s14 sr20det with bc stage 2 cams, int gate and 98 fuel
I've kept the compressor and grinned down the trim of exhaust wheel radius, So now its the biggest exhaust wheel that can be fitted into a .64 turbine housing with the correct blade radius inside turbine housing.
Car made a final of 308rwkws on pump 98 fuel, and 20psi made by 4000RPMs. This is an excellent turbo, managed to take timing and held boost pretty flat as internal gate. Doesn't chock the engine, no power tapering in upper rev, and drives very nicely on road. On paper it was identical in response to a GT3071 in T3 .63 turbine, make 30 extra kws, and direct bolt on.
20psi by 4250rpm and 292rwkw is a very impressive result
Spewing I already swapped my ss1.5 to .86ar and booked a tune for Tuesday should have waited
I think that turbo is maxxed now as on 25psi it only picked up 14kw from 5psi extra but still the ultimate bolt on lowmount turbo for sr so far as it's making gtx3071r power but more responsive by 250rpm
A gtx3071r is usually at 20psi by 4500rpm
All you need is to machine up a t28 bolt on fr compressor cover and will become a full bolt on turbo and look std but pumps out 300kw
Should sell like hot cakes
Now you should enable VCt and unleash the power with e85
Or is VCt active now ?
The compressor is maxed, and the turbine is just right for this compressor. Its is a perfectly matched turbo flow wise.
I had a closer look, it reached 24psi by 4150, 20psi was at 4050RPMs. It is currently the most responsive turbo for any thing that made this sort of power internally gated on Trent's dyno.
Car is now with VCT enabled. Can probably reach 340rwkws on E85.
25psi is a MEGA amount of boost on 98. What injectors are in this motor?
My GTX will be finalised soon and I will most likely be making a road trip to Melbourne. I will have to stop in for a comparison run ;)
Tao that's looking similar in size to Garretts GTX3067R comp wheel and housing wise . Does anyone have graphs of the baby GT30 on an SR20 ?
I really want to see someone use a copy of a TR30R turbine , NS111 60mm 76T 9 blade , since the pricks at Garrett won't use it in production turbochargers .
A .
I have original's GT3071's result from this car:
http://www.skylinesaustralia.com/forums/topic/261613-hypergear-hiflow-service-continued/page-457
Its not running VTC, so with VTC off those two has the same response. Based on same boost level the SS2 have made an extra 35kws.
Here's a Rb25det Auto Skyline tuned by DVSJez yesterday based on a bolton version of an ATR43SS2. made 271rwkws @ 20psi with a very quite and restrictive exhaust. Still excellent result for Auto:
But it's not, is it. The dyno only calculates RPM from the diff ratio correct? The stally would have it on much earlier than it should be due to slip, unless it was locked...
just wanted to say thanks to Stao from Hypergear for my hiflowed r33 turbo he did for me 3 or so months ago which still is going great with no troubles thanks heaps, and soon I'll be geting more work done to my 32 and tuned by dr drift.
Probably best get Jez's input about the dyno. Its on his and my facebook page (click on banner below). The owner did mention the car is very drive able. Not sure if this is a GTS-4, because the customer mentions AWKWs instead of RWKWs.
Cool, Sam is a good tuner and knows what he's doing, please post result once tune is complete. Cheers.
Got 355 HP atw with a 15 minute tune after having fuel pressure problems for 3 days, replaced fuel pump and started working.
355HP with the SS2 got me just under 240km/h in a 1000m run.
Will be gunning for over 400 next month.
e85
16 PSI
255 walbro
1000cc ev14s
External Gate
For comparison,
My atr43g2.5 made 340 with 22 psi 98 fuel
Edited by jay-rod
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
