^ just rips some skids, if the car doesn't kick like a mad man when you're going sideways you know it's not a VLSD.. and before anyone goes "just shim it" man a real diff vs. a shimmed diff are light years apart :)
I've done the shimmed business, locked weldy crap, to a 1way and now a 2way.... a proper diff goes a long way!
So what are then lengths of the 1/2 injectors do they fit under the intake or still need to cut stuff, are they shorter then the xpurt 40mm ones?
Edited by boostn0199
The 1/2 length ones are the ones ARTZ used to do his top feed upgrade, from his photos he had loads of room without needing to grind down the plenum like the US kits I've seen which use full height top feeds.
I've emailed the site and waiting for a reply. I'm a little pissed off at the Five O Motorsport injectors, they've pissed me off since I've used them on my car whereas on a mate's car o had pretty good control over them.
I have never seen the Siemens copy EV14's. Good prices too, although the rail won't support the 3/4 length injectors like the Proflow/Aeroflow rails do. They look to be the same length as the 40mm Xspurts, (1/2 length.)
I would still recommend the ethanol rated injectors for anyone running e85.
Also note, don't ever buy used high flows.. I made that mistake, ended up with 1x dud and bought 2 brand new ones.... can't really blame the seller either, but hope he didn't sell me known dodgy ones because I would loose my shit if he did.
Or at least get them flow tested ;) Cheap insurance.
I did haha, backyard styles
Also swapped to my old rail, does have that rubber hose on the return.
Finish off my head install and turbo the atr28ss2 comes on fullboost about 4000rpm but has that large gtx turbo howl and mad slow vl echo dose
Book in for a tune this Thursday
My brothers s13 drives a lot nicer down low and more responsive maybe due to s15 motor and VCt but top end power is amazing
What is the spray pattern on these like? like a hose I'm guessing?
Looks like a $2 reject shop water pistol LOL, at least they're "matched" hahaha
If anyone wants a rolling review/discussion(s) about Five O Motorsport 1000cc and 1200cc Side Feed Injectors go here:
http://nissansilvia.com/forums/index.php?showtopic=2441472
Talks about 98RON and E85, SR20DET and RB25DET usage and both 1000cc and 1200cc formats.
New Result sent in. This is from our TD06 SL20.5. Final result of 358rwkws @ 19psi. On an R33 Skyline unopened engine, 40mm external gate, fuel and ecu mods, E85 Fuel.
The same car had an Kando's TD06 SL2 20G before turbo change. This is an direct comparison between the two.
Can you confirm there are no other changes between those two runs? And was the lower boost on the 20G due to not being able to flow it? It's quite a different power curve shape, good power etc however :)
Far as I know it was old turbo off, new turbo on. And every thing bolted back in place.
The 20G started to run out of puff around 5000RPMs as the boost curve started to decline. This is the latest version of of the SL20.5 also, with SS2 compressor wheel, It should crack 380rwkws towards 24psi.
Some updates. This is in reference to our CT15B 1JZ VVti high flow.
Quoted from: Eyebeclubin from JZX World:
Vehicle: JZX100 Chaser
Transmission: Manual - r154
Turbo: Hypergear CT15b High-Flow 3076r spec
Fuel: BP Ultimate 98ron
Supporting Mods:
- Power FC
- Denso 850cc Injectors
- Walbro 450lph pump e85 compatible
- HPI Dump pipe
- Tomei cams - intake 250deg, exhaust 260deg
- HKS EVC 5 Gold Edition
- Pod filter
Power & Torque Curves
Sad motor with Tomei M8280 Vs Hypergear High-Flow With happy Motor + Tomei Cams & BC Springs
Thin curve Tomei arms m8280
Thick curve Hypergear + Tomei Cams
Low Boost @ 15psi 250rhkw @ 6620rpm, 437Nm @ 3360rpm
High Boost @ 20psi 278rhkw @ 6463rpm, 510Nm @ 3495rpm
Tomeim8280VsHypergearhi-flow_zps114b65ba
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
    • Yes it is ATF. I quote @Duncan "it takes a good synthentic auto trans fluid like Castrol Transmax Z" It's not a diff. It's a transfer case. Totally different thing. Yes, fluid will come out the sender hole. No you do not really need to drain it. Just pull the old, quickly poke the new, clean up and top up. But realistically, you should probably take the opportunity to change it anyway.
    • Hey all. I’m looking on replacing my speed sensor on my R33 GTR. Will the center differential need to be drained, and if so, the center diff uses ATF fluid D? I found information on the transmission, front diff and rear diff. Can’t find a for sure answer for the center diff. Any help will be greatly appreciated.
