ATR43 SS-2 Rb25det Stagea. Externally gated from stock exhaust manifold E85 fuel. Final result of 356rwkws @ 22psi on Dyna dynamic dyno:
Further testing and evaluation on the SS2.5 Alpha turbocharger, now using an 600x300x68mm tube n fine front mount cooler. I've attached two photos, note the tubing size inside the aftermarket cooler and factory cooler.
Aftermarket cooler:
Stock cooler:
Using the new intercooler, boost tapering issue was resolved to some extend and the same turbocharger managed to pickup more power. Cooling ability however is not as good as standard, under comparison my intake temp rise by 10 degrees. I will be fitting an thicker 600x300x100mm cooler for further evaluations coming week.
Turbocharger wise, it is matching factory N1's responds but a lot more power. Pretty good to drive at this stage.
ATR43SS2.5 Alpha, externally gated on pump 98 fuel. Peek 330awkws:
Vs stock cooler using the same turbo:
In conclusion based on test result, the factory GTR intercooler is only good for up to 320rwkws on pump fuel, for upgrade, I would be recommending a good cooler that has a core size of 600x300x100mm.
Tuned by Trent Hewitson, Intercooler piping and related fabrication done by Havoc Fabrications.
  • Like 1
All three GTR coolers are different, the 33 is best for cooling efficiency but worst for outright flow
My 105mm ARC cooler ( the best in the business) is about 4-6deg hotter then the factory 34 cooler but will happierly flow 1000hp
As I mentioned to Tao yesterday, Daz has made 500kw on a stock cooler and is heading for more. Not sure yet if he plans to upgrade his cooler this time around.
Yeah Ive heard of 450kw before
It isn't stock, it's 90 mm thick.
Weird that they're all different. How does the 32 cooler go?
And for people whom are switching to the ID 1000 injectors. The resister pack made for OEM injectors has to be removed. Big thanks for M35scotty on solving this issue yesterday. I believe he has some technical details to share.
The 32 is the best for flow but worst for efficiency, it is extrude honed and doesn't have the little fine fins inside the runners
You can tell the difference between 32 and 33 by the front of the runners, the 33 has a grove that runs along the runner which the 32 doesn't
That is something very simple and well known, simple cut the resistor off and solder the seven wires together then a bit of heat shrink and electrical tape and bingo high imp injectors working
  • Like 1
One of his injectors had stopped working, after testing it I realised he hadn't cut the resistor pack off, one resistor had blown taking the power from that injector.
The resistor pack was much hotter than usual. Obviously it runs fine on the Haltech without modification, but overloads the resistors. Goes to show the Haltech runs some great output drivers.
Um, aren't the injectors on a GTR a negative trigger, so all the ecu has to do is earth them
That's the reason you remove the resistor, cause it's no longer needed and the high imp injectors will fry it
Sweet it should be better for e85 to a certain extent then as it doesn't need the efficiency that it would for 98
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
