Have a feel of shaft play, there should be about 1mm side to side and nothing in / out. If that is the case check for lose bits thats bolted to the turbo.
Noticed you are in Melbourne, Call and drop by for a quick inspection when you are free.
  • Like 2
Thanks Stao PM coming your way.
Just finished installing my 21U high flow and had it tuned by Trent:
Much happier with the performance of this turbo compared with the OP6 variant I had last time.
As you can see, full boost is achieved by under 3,500rpm and I got 100rwkw at just over 3,000rpm.
My car's clutch began slipping towards the end of the tune, so Trent backed the power off; it could have made 260-270rwkw with more boost.
It's currently making 248rwkw at ~16psi. It feels better than my OP6 did at 20psi and 270rwkw, probably due to the wider spread of power/torque.
Big ups to Stao for this turbo and for putting up with my constant calls,visits and questions! :thumbsup:
Edited by colourclassic
  • Like 3
Thanks for the feed backs, always happy to help and the power curve looks great.
For 200rwkws by 4000RPM, the SS1PU would do it pretty well, or the 21U high flow can also do that assume you run enough boost at it.
11042955_864656746927801_611170638299213
10429303_864656813594461_292470324094080;;
11034300_864656860261123_504551220440252
Installed, housing mod by scotty, rest of welding im finishing up now myself. screamer is done, just gotta lengthen cooler piping to joiner and weld on a nipple for wastegate reference and we're good to go. can't wait to see how the SS2 goes.
They stops making power around 23psi. I was getting 327rwkws internally gated, but 367rwkws externally gated.
I completed a turbo install plus few other bits on the R34 today. They do give you a lot more useless stuff then they've done on R33s. Few things to point out:
I usually preload my actuators to 4mms. if for what ever reasons it has been removed and re-installed, please make sure it is loaded to where it was. More preloads can be added In case of boost tapering at high RPM on big boost.
The oil feeding line sits in between the turbo and chassis, do not fold them in between the turbo and manifold. The braided oil line is standard with and high flow services and is usually supplied with an ATR43 series turbochargers. Make sure you do get one if a 2nd hand turbo of ours is purchased.
Split fire coil packs are must in most of cases for high boost:
Most of people uses a JJR bell mouth front pipe, so I've bought one my self.
and its not quite right, but for the price I won't complain.
and gasket on our turbine housing is perfect:
Give it a little die-grinding and its ok.
The turbo in there is a SAT version of the ATR43G3 with a factory housing machined to suit. This is also the first internal gated version of that model, turbo comes in smooth and responsively. Still need to get a metal intake pipe made, the car will be running an Adaptronic plugin, hopefully hitting 300rwkws on pump fuel.
  • Like 1
Can you keep the AFM, as most people do. So if you are doing more like for like testing it would make sense.
Some feedback for you stao.
> Stock untouched RB30E bottom end
> Stock untouched RB25DET Neo head
> VCT
> Hypergear ATR43SS2 (mid 2013 model)
> 6boost exhaust manifold
> Turbosmart 45mm hypergate (7psi spring) venting to atmo
> 3" straight through exhaust
> E85
> Adaptronic R34 GT-T select plug in
> X-Spurt 1000cc injectors
> R32 GTR intercooler
First impressions are that its so much fun everywhere in the rev range. Comes on to boost very fast in the upper RPM as you would expect, lower RPM is still pretty quick but has room to improve.
The cam timing is slightly out and I didn't have time to get a degree wheel and set them perfectly to zero, the gate is only running a 7psi spring at the moment which makes it a little lazy also.
Once I get back on the dyno and fiddle with both intake and exhaust cams (both are now adjustable from the front thanks to Ben C34) and chuck a 14psi spring in the gate it should be quite a monster. Can't upload the boost graph for some reason. 10psi low boost and 13psi high at the moment. I assume this is not even reaching the turbos efficiency range yet? I haven't seen anyone run such low boost using one of your turbos haha.
It's quick enough for me already but I really want to go back fix the cam timing, bigger gate spring and chuck 20+ psi at it and see what it makes hahaha.
nice, what do you think is causing your waveness on your graph lines? if thats only 13psi then thats pretty awesome! what power is normally achievable with GTR intercooler?
Edited by Badgaz
> VCT
> E85
> R32 GTR intercooler
Looking promising so far will really come on when you wind a few more psi in.
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
