This turbo is current produced.
I've trailed the ATR45 SAT on a RB25det Neo today. With 0.1L of a difference in capacity those two engines are very different. The Rb26 SAT version didn't work on Rb25det, which I've had to make a new rear for. the result was 421rwkws out of a 120,000KM stock motor. Will upload result tomorrow.
How didn't it work? Interested in your findings
Based on the same configuration It was super responsive but didn't make expected power. Same CHRA with a SS2 turbine and it worked. Response wise It made 20psi by 4200RPM and 25psi at 4400RPM. Because the owner was looking to rebuild this engine so he didn't care if it blows and decided to max out that turbo. The final run was 421rwkws peek 28psi, He been thrashing the car on daily base, its a 120,000K unopened motor and I'm surprised of how well built stock Rb25det Neos are. Perhaps that is why Nissan never released GT-Four with a Rb25det Neo motor in it.
Its not the most responsive result I've had but good enough for a daily and not too bad for the power level its reached.
It was making 20psi around 3800RPM, which is close to 500RPM more responsive then the GTR. but stopped making power at 370rwkws. I don't have that sheet but I can see if I can get one from the tuner.
  • Like 1
Hey guys and gals, just a few questions.
This is a quick run down on what I already have
740cc nismo injectors
Z32 afm
Walbro fuel pump
3 inch exhaust
Apexi power fc
Npc clutch
Manley rods
Pod filter
High flowed rb25 turbo
All making 215kwatw
My question is, I'm buying a hyper gear turbo very soon and I just wanted to know how much power roughly would the hyper gear turbo achieve? I can only run on 98 as we don't have it on pump in my area!
Thanks in advance for your reply
Yes, I'm mainly looking into making power and response based on unopended engines.
For internally gated options.
A high flowed R33 turbocharger that is done by us, you will be looking roughly into the 260rwkws mark. Or 270rwkws for a R34 turbocharger.
G3 and SS2 would be making around the 280rwkws mark with supporting mods.
Z32 afm
Walbro fuel pump
3 inch exhaust
Apexi power fc
Npc clutch
Manley rods
Pod filter
All making 215kwatw
Hi Ryanh2512,
You have pretty much the same mods as me, I just got my Hypergear Highflow from Stao installed and tuned yesterday. My car made 250rkwk on 18psi with the R33 21U Highflow very responsive and nice on the street. You may want to look into getting a 3inch metal intake pipe made up as well.
Also thanks Stao for the turbo :)
Yeah definitely look into a metal 3" intake pipe.. mine was sucking closed after just 220kw so its a no brainer if your wanting more then that. i would recommend 21u if you want good response. But if you want a kick in the face at 3.8-4k rpm definitely go ss2 without a doubt
  • Like 3
Stao - was that last Dyno graph you posted supposed to be blank?
Also, how do your latest ATR45 results compare to the Neo Stagea result a couple of pages back? Are they similar, but different dynos? It was over 400kw..
Sorry - last question! Can you provide an Adaptronic e1280s along with your turbos, rather than the Select model? They have full sequential ign and injection, more flexible, and still have the rb25 style ecu plug.
The following is about the boost drop with few customers cars. The ability of an internally gated system holding boost through the rev range is crucial in building HP and torque in mid and upper rev range. Making sure our turbochargers are able to hold boost, our internally gated systems has been engineered to performing a very slight creep. Most of guys that uses high flows or a simple boltons tried to obtain legal appearance while keeping the amount of fabrication work to minimum, that in most of cases have to deal with restrictions. I've been building turbos for RB owners for a number of years and there is a pretty clear pattern emerging, The most people whom experience boost dropping issues are fitted with some sort of a return flow cooler. I was curious and undecided wither if it is an intercooler issue, there for purchased a car with a genuine Blitz return flow cooler fitted.
Today's run, I'm using a high flowed OP6 turbocharger with a high pressure actuator. Maps sensors were tapped from both sides of the intercooler and results was some how expected. Running high pressure actautor with no boost ebc connected, sensors is reading a 3.7psi drop across the core, and which I'm sure if EBC is adapted, the percentage of drop will be much greater.
Didn't make expected power:
So Return flow coolers should not be used when expecting beyond 250rwkws. And in my personal opinion it should not be used at all. 600x300x100mm cooler will be installed next week to complete power run above.
  • Like 1
Stao, do you think it's only the core that's the problem or does the return flow piping also play a part in the pressure drop? Do you think replacing the core in a return flow system would alleviate the problem?
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
