This turbo is current produced.
I've trailed the ATR45 SAT on a RB25det Neo today. With 0.1L of a difference in capacity those two engines are very different. The Rb26 SAT version didn't work on Rb25det, which I've had to make a new rear for. the result was 421rwkws out of a 120,000KM stock motor. Will upload result tomorrow.
How didn't it work? Interested in your findings
Based on the same configuration It was super responsive but didn't make expected power. Same CHRA with a SS2 turbine and it worked. Response wise It made 20psi by 4200RPM and 25psi at 4400RPM. Because the owner was looking to rebuild this engine so he didn't care if it blows and decided to max out that turbo. The final run was 421rwkws peek 28psi, He been thrashing the car on daily base, its a 120,000K unopened motor and I'm surprised of how well built stock Rb25det Neos are. Perhaps that is why Nissan never released GT-Four with a Rb25det Neo motor in it.
Its not the most responsive result I've had but good enough for a daily and not too bad for the power level its reached.
It was making 20psi around 3800RPM, which is close to 500RPM more responsive then the GTR. but stopped making power at 370rwkws. I don't have that sheet but I can see if I can get one from the tuner.
  • Like 1
Hey guys and gals, just a few questions.
This is a quick run down on what I already have
740cc nismo injectors
Z32 afm
Walbro fuel pump
3 inch exhaust
Apexi power fc
Npc clutch
Manley rods
Pod filter
High flowed rb25 turbo
All making 215kwatw
My question is, I'm buying a hyper gear turbo very soon and I just wanted to know how much power roughly would the hyper gear turbo achieve? I can only run on 98 as we don't have it on pump in my area!
Thanks in advance for your reply
Yes, I'm mainly looking into making power and response based on unopended engines.
For internally gated options.
A high flowed R33 turbocharger that is done by us, you will be looking roughly into the 260rwkws mark. Or 270rwkws for a R34 turbocharger.
G3 and SS2 would be making around the 280rwkws mark with supporting mods.
Z32 afm
Walbro fuel pump
3 inch exhaust
Apexi power fc
Npc clutch
Manley rods
Pod filter
All making 215kwatw
Hi Ryanh2512,
You have pretty much the same mods as me, I just got my Hypergear Highflow from Stao installed and tuned yesterday. My car made 250rkwk on 18psi with the R33 21U Highflow very responsive and nice on the street. You may want to look into getting a 3inch metal intake pipe made up as well.
Also thanks Stao for the turbo :)
Yeah definitely look into a metal 3" intake pipe.. mine was sucking closed after just 220kw so its a no brainer if your wanting more then that. i would recommend 21u if you want good response. But if you want a kick in the face at 3.8-4k rpm definitely go ss2 without a doubt
  • Like 3
Stao - was that last Dyno graph you posted supposed to be blank?
Also, how do your latest ATR45 results compare to the Neo Stagea result a couple of pages back? Are they similar, but different dynos? It was over 400kw..
Sorry - last question! Can you provide an Adaptronic e1280s along with your turbos, rather than the Select model? They have full sequential ign and injection, more flexible, and still have the rb25 style ecu plug.
The following is about the boost drop with few customers cars. The ability of an internally gated system holding boost through the rev range is crucial in building HP and torque in mid and upper rev range. Making sure our turbochargers are able to hold boost, our internally gated systems has been engineered to performing a very slight creep. Most of guys that uses high flows or a simple boltons tried to obtain legal appearance while keeping the amount of fabrication work to minimum, that in most of cases have to deal with restrictions. I've been building turbos for RB owners for a number of years and there is a pretty clear pattern emerging, The most people whom experience boost dropping issues are fitted with some sort of a return flow cooler. I was curious and undecided wither if it is an intercooler issue, there for purchased a car with a genuine Blitz return flow cooler fitted.
Today's run, I'm using a high flowed OP6 turbocharger with a high pressure actuator. Maps sensors were tapped from both sides of the intercooler and results was some how expected. Running high pressure actautor with no boost ebc connected, sensors is reading a 3.7psi drop across the core, and which I'm sure if EBC is adapted, the percentage of drop will be much greater.
Didn't make expected power:
So Return flow coolers should not be used when expecting beyond 250rwkws. And in my personal opinion it should not be used at all. 600x300x100mm cooler will be installed next week to complete power run above.
  • Like 1
Stao, do you think it's only the core that's the problem or does the return flow piping also play a part in the pressure drop? Do you think replacing the core in a return flow system would alleviate the problem?
    • Welcome to Skyline ownership. Yes, it is entirely possible parts websites get things wrong. There's a whole world of inaccuracies out there when it comes to R34 stuff (and probably 33 and 32). Lots of things that are 'just bolt on, entirely interchangable' aren't. Even between S1 and S2 R34's. Yes they have a GTT item supposedly being 296mm. This is incorrect. I would call whoever you got them from and return them and let them know the GTT actually uses 310mm rotors. Depending on where you got them from your experience and success will obviously vary.
    • Hi...a bit a "development" on the brakes. I spoke to the guys where i get brakes from...and they are saying that 296mm EBC are for R34 GT-T. I then went to their site: https://www.ebcbrakes.com/vehicle/uk-row/NISSAN/Skyline (R34)/ and search for my car(R34 GT 1998 - it has GTT brakes) and it show me this USR1229 number and they are rly 296mm rotors... So now iam rly confused... The rotors i have now on the car are 310mm asi shown... So where is the problem? Does the whole EBC got it wrong or my calipers are just...idk know what?
    • Oh What the hell, I used to get a "are you sure you want to reply, this thread is XX months old" message. Maybe a software update remove that. My bad.
    • This is a recipe for disaster* Note: Disaster is relative. The thing that often gets lost in threads like this is what is considered acceptable poke and compromise between what one person considers 'good' looks and what someone else does. The quoted specs would sit absurdly outside the guards with the spacers mentioned and need  REALLY thin tyres and a LOT of camber AND rolling the guards to fit. Some people love this. Some people consider this a ruined car. One thing is for certain though, rolling the guards is pretty much mandatory for any 'good' fitment (of either variety). It is often the difference between any fitment remotely close to the guards. "Not to mention the rears were like a mm from hitting the coilovers." I have a question though - This spec is VERY close to what I was planning to buy relative to the inboard suspension - I have an offset measuring tool on the way to confirm it. When you say "like a mm" do you mean literally 1mm? Or 2mm? Cause that's enough clearance for me in the rear :p I actually found the more limiting factor ISNT the coilover but the actual suspension arms. Did you take a look at how close those were?
    • @GTSBoy yeah sorry i know thery are known for colors bud those DBA are too in colors 🙂 Green will be good enough for me
