Wow. Just caught up on 180 pages in the last few days after not visiting Sau for ages. Still an awesome thread. Some excellent improvements and results Stao!!
Finally getting my SS2 off its run in tune soon and adjust for the change in cam timing. I'll post results when I get them.
What did you mean by 'run in tune' ? I've got a SS2 that's going on soon as well
I didn't get to see the tuner the day I dropped it off. He saw it had a new motor so only set it about 17psi and not much timing. Time to put some more hurt on it now I've dialled the cams and got rid of the lag it initially had when cams were retarded.
Some updates, This is an internally gated prototype that I've been working on few weeks, the goal is 370rwkws on E85 fuel with excellent drive ability, internally gated bolton to factory RB's manifold, dump and all lines.
My final result was 365rwkws @ 23psi E85 and 330rwkws P98 @ 22psi. 20psi was reached at 3800RPM, while made over 200rwkws @ 4000 using either fuel. This is probably the highest power any one has every made using a bolton turbo. I'm very happy with todays results.
R34 GTT RB25DET NEO unopened engine.
- Adaptronic​ ECU
- 1000CC ID injectors
- Factory cams and cam gears.
- HyperGear ATR45SAT Internal gated RB25 bolton Turbocharger
- JJR 3 inches turbo back exhaust
- Walbro 470L/H Fuel pump
- 4 inches induction pipe
- Split fire coil packs
- PWR 600x300x81mm intercooler
- P98 fuel @ 330rwkws
- E85 fuel @ 365rwkws
- Tuned by Trent Hewitson​, Chequered Tuning​.
Dyno below shown results on both E85 and P98 fuel.
  • Like 3
Anyone remember when the SS2 reached 20psi ? It was a while back and couldn't find it. Currently can't decide between the SS2 or new ATR45
That might I've been my dyno results im running 21psi internal gate 297rwkw on p98
4000rpm give or take a few hundred depending on mods and turbo specs
  • Like 1
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 😉. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 😍.
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 🙏 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 😉. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 😍 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
    • I've managed to find this: Nissan_Stagea_AutechVersion260RS (1).pdf
    • I believe @Duncan has given it a crack at Mt Buller before (in actual race conditions)
