Sorry I can't remember exactly. That should be the SAT model. Externally gated?
Internal.
I thought you were going to send me the SAT version but don't actually know the difference.
Please email me a photo of the rear turbine and comp of the turbo. I don't remember building internally gated SAT versions for any one. if it is the SAT model, it might be running 22psi minimum boost, but I can make changes to it if not yet installed.
Interesting re. The intercooler studies.
I'm considering a r34 blitz return flow on an r34gtt to be used in conjunction with a high flow to make around 250rwkw. Are these worth it? or will the generate alot more lag/loss of response? Would prefer not to cut a hole..
Consider PWR 600x300x81mm FMIC instead. The Blitz return flow did not work for me.
If you really have to use the Blitz return flow and make power. get our ATR45-SRFC special application turbo. I can pump get that to make close to 300rwkws on that cooler kit.
Out of curiosity which Blitz return flow are you using as there were two sizes of the long lower pipe . Mine I believe is the earlier version with the larger diameter lower one . It may not make much difference but occasionally things like this can .
A .
Well after 3 years I've finally got interested again at fixing the issues with my ss2 setup.
Since last time it's got a new exhaust, cams both dialled which resulted in them getting advanced and water meth kit finished off. Unfortunately similar results to last time :( anymore than 18 psi it started missing and seemed like a failed coil pack as changing plugs didn't help. I got into some testing and noticed my speed signal is erratic with about a 10:1 noise. At 800rpm it fluctuates 80, 300rpm changes while cruising at 3k on highway and map tracer is constantly bouncing left right.
I'll get a new Cas and double check for intake leaks etc then try again for a better result. It's currently running about 11 degrees at peak torque and increases to 15 post-24655-14385209287334_thumb.jpg
Just got this today.
Haven't got digital copy of this yet, only photo
Ive finally got my 25 back in the 31 with the atr43ss2, going to be getting a flex tune done shortly so will update what it does.
Tao what turbo do you have for a SOHC rb30? Mates after something quite large. Does the ATR45 come in a trim suitable for a 3litre?
If you using a 0p6/vl turbo/ 300zx etc etc .63 rear, id be getting a atr45 SAT for a Rb30..as the .63s with 3582/atr45 rear turbine wheels choke the f**k out of them..to much backpressure
Rb30 sohc motors like .82 housings with those atr45/3582 turbines..
cheers
darren
Edited by jet_r31
For externally gated if he still wants that dump pipe to be made it will still be $1250, How ever if he's happy to make his own dump pipe it will cost $950
Hey hypergear. Just wondering if you have any r33 high flow turbos on the shelf for exchange. Or do you only build them once receiving them from the customer.
Thanks mate
Edited by RIPS_R33
The one in photo above is .82 internally gated.
Very good ! You will also need a small/medium camshaft (220-230 @.50 duration, upper 400 thou lift, 115-117 lsa ) depending on car use and trans and a set of valve springs
on a on a sohc rb30 to make power with that turbo..
cheers
darren
Edited by jet_r31
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
