Yeah his after external gate version, going to put gate off housing, whats the price for the external gate version?
What exhaust manifold?, if a stocker vl turbo one, take it of the top of manifold...
cheers
darren
Hey hypergear. Just wondering if you have any r33 high flow turbos on the shelf for exchange. Or do you only build them once receiving them from the customer.
Thanks mate
Yes I do have one. it will cost you $150 additional. Which you get that back after I receive your stock turbo.
One more result to add. This is from Boostborthers in SA.
R34 GTT RB25DET NEO unopened engine.
- NIstune ECU
- 1000CC ID injectors
- Factory cams, cams gears, and all manifolds.
- HyperGear High flowed factory OP6 Turbocharger
- 3 inches turbo back exhaust
- Walbro 470L/H Fuel pump
- 3 inches induction pipe with POD filter
- Split fire coil packs
- 600x300x81mm Front mount intercooler
- P98 fuel, 292rwkws @ 19psi.
- Tuned by Boosted Brothers
Pretty ancient Hypergear ATR28G2 on an unopened RB25 on 17 psi, taking it back for a few more pounds soon, boost comes on pretty strong
Nistune
United e85
Walbro e85 pump
Nismo 740cc injectors
Nismo FPR
290kw
Ive read so many pages of this but cant find much info on 30dets and these turbos! - so i apologize if this has already been covered.
Im looking at either an ATR45 .82 or the ATR43G3 .82|
The car is track purposed so response is crucial
im aiming for around 330+ on pump 98 ( i figure if i want more cams and e85 will get me there )
30det is as follows
All supporting mods ie exhaust cooler fuel system etc
standard head
standard 30e so roughly 8.4~ CR
So looking at the dyno sheets for these turbos the atr43 g3 will come on 1000Rpm sooner than the ATR45 and will both make the power level i want?
add the extra cap of the 3 ltr and i should be looking at roughly 3200rpm all in with the ATR43?
25/30 neo. Standard head, standard cams, standard untouched RB30E, SS2 .82, 45mm hypergate, 6boost, Greddy plenum, working VCT.
Cam timing is retarded and only running a 7psi spring so gate opens almost instantly. Huge gains to be had playing with cam timing and running a stiffer gate spring and a bit more boost.
For rb30det use the atr43g4 rb bolt on version. Thats similar to a 3582 in .82 rear. its quite responsive with the 3l and Will make alot more then 330rwkws too.
Sorry I should mention it's already setup for highmount so rb bolt on is pointless.
Is the atr45 the same rear wheel as the atr43?
Not sure of its an error but on your site the atr43g4 boost graph is labelled as "atr45" and full boost is around 4900, not to mentioned. The sharp power curve
Also I'm not planning on going over 380 (which is what the g3 maxed out on e85) at any stage. don't think the chasis an take it
Hi Stato,
What is the difference between the .82 ATR45 or there the ATR45SS version and what other mods are done to the 33 GTST below? this is the EXACT power I want from mine. Also which profile option was this and will it bolt into the stock location without issues?
One more result to add. This is an ATR43SS2 internally gated on a R33 GTST, with usual mods. P98 fuel.
308rwkws @ 18psi
Edited by kingtube69
  • Like 1
^^^ I think i found the answer to profile option - SS2 is what I want being the .82
Please correct me if I'm wrong.. Also from my reading I'll need the spacer which apparently comes with it but need to but extended studs - Correct?
Get the ATR45SAT version. This is a newly developed turbocharger, similar response as the SS2 and alot more power. I'm currently working on a newer version of the SS2 and SS3 at moment. results will be posted shortly.
    • So, I started this repair and got as far as "fixing" the holes with some fibreglass. God all those years working on boats came back quickly. I decided I'd reach out to some rust guys just to see what they would say about it. I came across a guy about 40 mins away and went to see him. He said the windscreen needs to come out, that there might be some more bits around the windscreen and he'd quote them at the time. But his quote was $300 to remove and replace windscreen and $3k for the damage he can see. He said he could respray the roof for $1200 and the bonnet for another $800 (somebody has previously rattle canned it, its horrendous). This is $5300 + any small additional bits. It's a lot, I get that and the name of one of my fave youtube channels 'Not Economically Viable' comes to mind.  I'm not being financially rational, but I've taken him up on the quote. He's opening a new shop in November with more room, so we're waiting for that. I'll leave the currently missing headliner out until then. I'm looking forward to it being fixed and having the paint looking nice again (lots of clear coat issues on the roof too). / flame suit on.
    • Oh and some up-and-comings; New rear drivers wheel bearing. I'll do that this weekend while the diff is out. The car is already up and the d/c axles and missing exhaust will help with space. This is the last bearing for me to do and I've been dragging my feet on it. I also have some new EBC blue stuff pads for the car and some new brake fluid. I haven't ever flushed the fluid in this car and looking forward to it. I have 600 degree fluid to put in. Not exactly "race fluid" but better than the typical stuff I have been using.
    • A proper clutch/plate type mechanical diff with quite a lot of pre-load and high locking % is better for drifting. Much more consistent in its behaviour. A helical can be annoyingly vague and inconsistent in how it responds under the sorts of abuse found in drifting.
    • Some updates here. I pulled the entire interior out, minus some trim to respray the seats with Colourlock dye. It turned out really nice though I accidentally let the dog in the car after and she scratched up the front seat.  This is what it looked like before, the colour was just washing out everywhere but thankfully the leather was in good nic. Then after the respray   And after the bloody dog jumped in The headliner is out waiting to be retrimmed, but it will stay out now until Nov - see why below. I replaced the stereo/headunit with a period-styled Android headunit. I have no after pics, but I'll get some. This is because of the missing pixels. I tried to fix this twice with replacement ribbon cables but couldn't. Also the bluetooth interface I'd bought for this was crap. Then there's the rusty roof. Pics and info in this other thread. I have decided to get this repaired professionally, but I'll update that thread. This is why the headliner will stay out for now. I'll be getting the roof and bonnet resprayed at the same time the rust is fixed. I also had an interesting issue with my drivers door lock.  For a small period I was having issues getting any 12v power to the car - I mean *any*. It would have no dash lights, nothing. It happened while I was at the shops and I couldn't get in the car. So, we had 2 problems. The most pressing here is that I was locked out. I have only a single physical key hole on the car, the drivers door and no amount of turning would unlock the car. Surely it doesn't need power for this? The second issue is why am I losing all power periodically, The battery isn't dead, its almost like the battery isn't even there. Two issues that were surprisingly easy to fix. You fellow BMW over-engineering lovers will appreciate this. The lock in the door has 5 states; mechanical lock, electric lock, neutral, electric unlock, mechanical unlock achieved at -90 degrees, -45 degrees, 0 degrees, 45 degrees and 90 degrees. Although, the unlock is towards the front of the car, so opposite for LHD countries. Sticking the key in and turning 45 left or right is what is used 99% of the time. It activates the central locking etc. 90 degrees is for dead battery access and, obvs, only un/locks the one door. But because the mechanical lock is never used and is 27 years old, it seizes up. I was totally unable to turn the key far enough to get to the mechanical unlock (At the time of locking myself out, I didn't even know this was a thing). I eventually did it with some vicegrips and teflon spray.  I made a quick vid for other E39 peeps.   The battery issue is totally new to me also - It wasn't making sufficient contact between the post and the terminal. The terminal was bolted on tight, but the car wouldn't have power. After checking the battery with my multimeter I accidentally contacted the terminal and the battery post and the car got power. The battery was only a few years old and in good condition. I cleaned the post and the terminal with a wire brush, bolted it back on tight and never had the issue again. I'm still surprised that despite having solid contact it didn't work. Also, the car was getting Warragamba sized pools of water in the back when it rained. My initial concern was another rust problem. But when I went out on Weds while it was raining and while I had no headliner in I could see a steady stream of water coming through the roof mounted aerial. As this aerial is for the (now removed) car phone I pulled it out and whacked a blanking grommet in the hole. It seems fine now. I'm thinking I might get the hole permanently filled when the rust is fixed. Moving forward and things in progress; The tailgate needs some attention. I have taken all the trim off to clean it all and address some small rust spots. I have partially done all of this but I'll finish it up hopefully this weekend. As all the trim are now entirely devoid of trim clips I have bought a heap of strong velcro and I'm hoping it does a good enough job as any of this trim in good condition is super expensive and usually in Europe as we dont have many of the wagons here. Suspension and brakes!!! This is exciting. In the front; New control arms New sway bar links New lower Eibach springs (the only modification I'm planning on this car) M Sport shocks (these came with the car and will replace the longer shocks in the car) New top mounts Used 540i calipers (stock brakes suck!) New 540i disks and pads (22x296 mm for 528 and 30x334 mm for 540i) New front wheel bearings (thank all that is holy for bolt on bearings!) Annnnd in the back; New control arms New sway bar links Adjustable air suspension arms (fool the car into what the current height is so the self levelling suspension can match the new front ride height) New ball joints I'll also be doing a brake fluid flush while I'm in there. I'm planning on switching the car over to the 16's that came with it so I can clean up and respray the M Sport 17's. They've lost a lot of colour over the years and have some gutter rash. None of this will start until the E90 is back.
    • You mean you will regret it for drifting duties? I don't quite follow.
