head lifting because too much boost?
be a lazy prick like me and install ARP studs without pulling the head off! That 19 year old OEM headgasket loves it :)
  • Like 1
^^ Dodgy carnt...lol
you're forgetting I'm asian after all lol..
didn't you go to the darkside? why you still here? don't forget your turbo roots lol
sprayed more things black lol....
I might delete the charcoal canister and move the catch can there.. too much shit going across the engine bay at the moment :(
12108237_1139761716052956_84809291911063
Yeah that's not a bad idea, but removing the charcoal cannister and placing it there looks more tidy as well as defective lol.
On a side note, my dodgy install new studs and torque down the head band-aid solution worked.
Was at Wakefield all day today pumping 1.5 bar through the motor and no signs of pressure building up in the cooling system.. yay for 19 year old head gasket and motor haha
lol with a fuel pressure gauge and external gate on show you're fooling no-one about it being 'stock, officer' :P
good result on the no-head-off head stud job then, might have to look at that further myself.
Hey guys, I'm still tossing up between turbos for my build.
To be honest I just want the most responsive and snappy 300rwkw on E85 for the street.
I found a build thread where someone had made some very nice results on the highflow 21U turbo used on a R34.
There are a few options for me but I'm unsure.
SS1PU (I had one of these in my R33 for a few years and loved it, Stao has altered the build of these over the years and they seem to have gotten even better)
R34 Highflow (currently have the turbo so it would be cheap and easy to sort, but I'm unsure if it's going to be nice and responsive)
R33 Highflow (more responsive than the R34 highflow and I'm not sure where this sits between a SS1PU and the SS2 in terms of response and feel for street)
SS2 (stao said this is strong and powerful delivery)
I've looked at a fair few dyno sheets but still can't wrap my head around it all, can anyone lend some input
The SS2 should easily get 300 on e85, like very easily. I'm running 260kW on 18psi very safe tune. It has a bit of lag, but not much, full boost is about 3500 and it just picks up crazy ! I've heard the SS1 is a more responsive version, but makes less power. 300 would be pushing it with the stock turbos, but that's just my opinion.
Pretty much everything I listed there will net 300rwkw on E85, but which is going to be the most snappy and responsive.
Stao mentioned that the R33 turbo on a R34 would want to ping.
not on E85, I've found it just loses power rather than knock like 98RON, it might knock but not audible like 98RON (from my self tuning experience)
Interested to hear the answers to this.
Stay told me the same thing but I'm keen for ultimate response on the r34.
Someone on here got close to 300rwkw on an r34 with the 21u highflow, e85 and blitz return flow.
I'm wondering whether the e85 combats the pinging stao mentioned.
I don't want Lag so very keen to try and make the 21u work on the r34.
About to get some ID1000 to allow running of e85
I knew someone who made 310kw on 19-20 psi on e85 with the u21 highflow.. tbh it didn't feel very quick but the dyno sheet it had a very v8 looking power curve made full boost at like 3700 or something.. blitz front mount, xspurt 1000cc, pfc and hks exshaust
I guess it's a toss up between the SS1PU and the 21U then because the 21U has performed 300rwkw on E85 on fair few setups now. The SS1PU was a beast on my r33 and should easily make 300rwkw.
Stao, you're the man with the kowlwdge. Chuck us all some ideas :)
engineering a new ss2 at moment. should easily take over 300rwkws on pump. will up result shortly. ss1pu makes similar power then 21u but makes alot more torque. there is also a new turbine wheel on thd ss1pu this year, should up hp by 15kws with no lose in response.
  • Like 1
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
    • Shimmed or shimless, still solid, no hydraulic pump up stuff.
    • They have said food will be limited. Mainly meat pies and sausage rolls from memory. But they have a coffee van!
