Yo Stao
I have your ~2010 model atr43g3, which you high flowed into a ss2 around 2013.
Thats on my 34 at the moment ( your new ss2 sounds to good to pass up, i want it now lol )
Now onto my question, i have got a patrol that is getting a rb25 transplant.
Obviously i want more power in it so it can actually lug around the 3 tons, but i think the SS2 or possibly even the highflow op6 will be to laggy for what i need.
I was wondering if you have anything that could get boost on early, earlier the better, but still make some decent power.
Close to 2500-3000 rpm is what im hoping for .
^ive got the 21u highflow on mine. Made 248rwkw @18psi with a quiet restrictive nismo 3 inch exhaust and return flow cooler. Full boost @ 3450rpm. Tuner says could make 10-15kw more with better fliwing exhaust.
Following up about the 3inches diameter restriction problem with internally gated ATR45. I've made a simple Tee pieces that is attached to the front pipe. It is spring loaded, so gas pressure forces the valve open once it builds up to certain point, while remains shut and quite on cruise.
  • Like 1
Some further updates. Those are the CNC machined billet internal gate assemblies made for Nissan RB25det high flows. This upgrade will help stabilising boost and should pickup few extra KWs working with small 21U turbine housings also. This is usually a $200 upgrade job, Now comes standard with all RB20/25det high flows at no extra cost, that is $850 including braided oil feeding line.
  • Like 1
Yes, All RB25det and RB20det engines
I'm not sure that upgrade is actually required. I'm not having any boost control issue with my hi flow and I'm not awaren of anyone else having boost control issues but if you want to offer it for free, I don't think anyone is going to argue with you as long as it works properly.
Bigger waste gate keeps the turbine cooler on tracks and possibly an extra degree of timing. Did that on John Reco's WTAC car this year and it was very successful.
Just had time to install the new ATR43SS2 with the DIY dump bleeder.
Car is currently running the ATR45SAT's tune, its booked for tuning on the 9th. The response is similar to the older SS2 but making way more power. That Bleeder vale have made a noticeable difference to upper rev torque, the car pulls all the way to red line. That bleeder is definitely a worth while DIY to do. Will upload results once dyno tuned.
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
