On 07/05/2021 at 10:50 AM, hypergear said:
Yep it was more responsive then the stock twins, and held boost all the way to red line.
T4 twin scroll or single? What AR and when we can buy it 💓
Its currently a single scroll T4. I'm making a new prototype for 400awkws with same response. Will be available for public in T3 or T4 rear housings once tested in about two weeks time.
Tested more more Protoype Rb26 T4 Turbo today.  Car made 443awkws E85 at 27psi, reaching 20psi and 200awkws by 4000RPM. Will be looking at Cam shaft upgrade and slight turbine trimming for the next run.
Edited by hypergear
  • Like 1
ATR45SS-1 Ball beairng Turbocharger in T3 Vband rear externally gated. In an R33 GTST, built Rb25det engine, factory stroke, with 264 camshaft maintain VCT. Final result was 472rwkws externally gated, power pulling all the way to 8000RPM on E60 fuel with 230rwkws @ 4000RPM. It would easily make 500rwkws+ with upgraded cooler and fuel system.
  • Like 1
  • 3 weeks later...
On 05/06/2021 at 9:35 PM, hypergear said:
Following the car above, now with E85, Pull 511rwkws and still plumbed back gate.
RB26 owner's wet dream. On song before 4500rpm and make those kind of numbers.
  • Like 2
On 08/06/2021 at 1:28 PM, SKYMAGGOT said:
What size is the exhaust?
3.5 inches to 3. there should be another 20 kws left in it once externally gated with a better cooler.
Result for you. ATR43ss2 ballbearing version compared to Garrett GTX 3076 gen 2. Same 0.82 externally gated housing used on both, and the turbo was the only change to the setup. Forged RB25, Supertech valvesprings, 256 Poncams, topmount steampipe ex.manifold with Turbosmart 38mm external gate, 3.5in intake pipe, 3.5in turbo back exhaust, Apexi PFC. P98 fuel.
Disregard the pink line; that was the GTX running an EBC that overboosted, run aborted. The blue line is the ATR43, no boost controller, just running wastegate pressure. The red and green lines are the GTX, also just running wastegate pressure....crappy ex.manifold resulted in spiking a much higher boost pressure, another story so disregard that aspect of the higher HP when it hits 24psi.
Important part to note is the ATR making more HP through the entire run right up until the boost creep on the GTX. Also to note, the R35 afm in a 3.5in pipe was hitting 5v at the peak of the red run.
Here's the run of just the ATR.
Just under 400rwhp. Note this was also with an inadequate boost controller; now running a Greddy MAP controller allowing for boost to come on stronger earlier without overshooting at higher rpms, so the midrange is now stronger.
Same dyno and tuner for both, just done at different sessions.
Edited by hardsteppa
  • Like 2
Similar to an ATR43SS-2
Another ATR45SS-2 result to share, This time in a T3 1.0 Rear with a Built RB26 running stock cams. Car made a impressive 625rwkws @ 38psi E85 fuel.
New prototype ATR45SS turbocharger. Now sitting at 485Awkws @ 32psi of boost, all in by 4200RPM. New turbo made 40kws more in power while no lose in response. Car's nice and and responsive to drive. Currently sitting at the limitation of the stock engine, considering of doing a forged build soon.
Stock R34 GTR Rb26 with APR head studs
HKS Cam gears 0 inlet, 0 exhaust.
R35 GTR coil packs
Trigger kit
ID 1650cc injectors
Twin 540 Walbro pumps+11m fuel line
Apexi FMIC
Trust 3 inches turbo back exhaust
PS2000
Nismo Front mount cooler
T4 high mount exhaust manifold
HyperGear 50mm External gate
HyperGear ATR45SS Prototype T4 Vband rear
3 inches front pipe with cutout
Final result so far 485awkw / 650awhp @ 32psi E85 fuel. All in by 4200RPM.
Great work Tao, looks like Trent ramp in the boost gently to limit torque so the stock motor wouldn't explode. Judging by the graphs you could get more boost in earlier but most likely break the motor LOL
That comp cover also looks great, much nicer than premium products with poor casting and material missing.
  • Like 1
On 06/05/2021 at 9:01 AM, hypergear said:
Further development on the T4 printed turbo on Rb26. This prototype made a pretty big differences, peek 377awkws while making 20psi by 3500RPM and 220rwkws @ 4000RPM. Will doing few more things and hopefully seeing 420awkws+ without loosing response.
Is that turbo already available to buy?
  • 3 weeks later...
Some footage from last Winton practice from Mr Oversteering, Still running one of our high flowed OP6 Turbocharger making a responsive 310rwkws.
  • Like 1
  • 5 weeks later...
    • Food for thought, the stock oil filter thread is a 3/4-16 UNF, which has an ID of about 10 to 12mm (according to ChatGPT lol). Now compare than to an 10AN, which has an ID of about 14mm (Raceworks is 14.2mm, Speed flow is 14.27mm).
    • Yep, totally get that. However hooking in for Generator back up is only a few hundred bucks for the wiring. You could put a couple of those in (for different circuits explicitly) and run a couple of baby generators. Bonus, you can balance them across different circuits, and now have backups in your backup. I'm looking at buying places that won't even have water etc, and I don't mind the idea of getting off the electric grid either, even with everything you've said. This country already has enough power outages that even the mains grid isn't that reliable anymore. I do agree though on spending a bit more to get better gear, and to add some extra redundancy in to the system too.
    • You can set hard reserves on your battery system, and it can't be discharged past that.
    • That sounds like an excellent idea. But total self-sufficiency means exactly that. You have no-one else to blame when your system faults out and you have no power for a week or two while it gets fixed. You'd have to go the whole hog and get a diesel genny and all the switchover gear, to get you through such times. And, despite the fact that over 20 years, my system has been pretty reliable**, I have seen so many inverter explosions (or less dramatic deaths), panel and roof JB fires, and so on, over that time, to know that the stuff is the same as any other bulk Chinese manufactured stuff. The failure rate is well above zero - both on the equipment and on behalf of the meth addled installation labour force. And then..... warranty and means of redress against the supplier you bought the gear from. Best I can tell is that only a handful of solar companies are still around within 5 years of starting their advertising pitch. They disappear and phoenix like crazy. So, as per 1st paragraph, I suspect the only way to is go balls deep and spend maybe 2-3 times as much as you might think, so that you have every base covered. Plus, know and understand your gear intimately, so you can diagnose problems, sort them out yourself, etc, etc. Plus, probably have to consider upgrading various parts as the years pass, to maintain compatibility with newer stuff, performance and reliability, etc, etc. Whereas, remaining attached to the grid has an ongoing cost that keeps going up even if you use bugger all power from it. But it does provide the fallback in case of the worst case with your own gear. You either pay up front or as you go, I suspect.
    • Add more solar panels to the array. Call the electricity company and tell them you're moving out... Live off grid electric wise
