  • Replies 615
Posted Images
Get some up of your white R33 that we used to play with at the Motoconcepts days... I still love that car!
Yeah definitely still love that car... I wonder where it's hanging out now, or if it's still in one piece? :)
Made gobs of power in it's day... 300rwkw from a GTS-t was unheard of back then!!!
That thing never missed a beat, even with all the thrashings we gave it on the track.
Ahhhh... the memories :woot:
no the whiteline bars are NOT stiffer than the cusco ones even though they are solid and more than double the weight. the cusco ones are lighter, stiffer, better made, come with all the parts needed, and not very expensive. the whiteline ones are ill fitting, cheaply made, and don't always come with all the required bits. and they are damn heavy. simple as that. the only advantage the whiteline ones have is they are adjustable.
Interesting- i've never tested it. Where/how did you test them?
S15 ones fit fine but are very heavy. I have heard of the poor fitment, friend of mine had to send his whiteline bars back for his evo 6 as they hit the chassis and were actually warped.
I loved that car as well. So much better then your GTR :) I still remember you leaving the Cricketers Arm with a bit of gate off through the countryside. Such a nice car
let me shoot up some pics :woot:
A GTS-t with GTR badge and wing
:bunny:
Yeah tell me about it :banana: :banana:
They were on there when I bought the car... I could live with the wing, but not the badge, so the first thing I did was drive it home and get out the heat gun and steel wire to take off the badge.
Came off nicely, but after removing the leftover glue, I found two holes in the bootlid :(
So I put the badge back on and never got around to getting the holes welded up and repainted...
:(:rofl:
Your last GTR there.
I just found a set of those mags to go my R32. So nice and good offset...just need flaring :banana:
Nice numbers on the Gts-t as well.
Flaring guards is easy, and makes the car look TUFF :banana: Do it!
300rwkw is nothing these days, but back then, it was an eye opener! Most modified GTS-ts were around the 220rwkw mark.
Flaring guards is easy, and makes the car look TUFF :bunny: Do it!
I am! :banana:
300 is still a nice round number. Just got to make the fkn thing reliable :banana:
Wow Andrew. Sensational. I only came across your thread today and am really liking what you've done so far. Your attention to detail really makes me feel I should've spent a little more time on some aspects of my own 32 build. Seems to make all the difference. I love what you did with the cage and attaching it to the bar under the dash. That's exactly what I should have done to get the front stays closer to the pillers but didn't click untill it was all bent and welded in.
Your thoughts on brake and suspension gear is also very close to what I have planed when required funds become available.
Again, nice work.
Coop
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
