  • 1 month later...
  • Replies 615
Posted Images
  • 2 months later...
  • 2 months later...
I'm still alive...
I have to admit that I lost motivation after I booked into one of the last Oran Park days hoping to get a shakedown, and having that clutch blow up on me.... It was fun throwing the daily driver around (literally), but I really wanted to give this thing a run.
Ever since that massive letdown, work has been very busy and this has been gathering dust..... But I'll start coming back on here to get some motivation to finish it off :down:
WELCOME BACK!
I think everyone thought you'd been put away for your digital scales or something.
Will be good to see this thing going - its just so close... I must admit I have robbed lots of things from your build for my own studying photos etc
  • 1 month later...
  • 11 months later...
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
