  • Replies 96
Posted Images
You sound cut up Roy?
GTi's GTR's they've done it all.
Well done boys!
Andre, if you haven't realised if you make a bold statement on here it seems to upset people easily. It must be the stupid aussie tall poppy syndrome.
Well done on the results guys...top stuff.
Paul
381kw! WOW that is intense!
Well done CRD! Once again raising the bar!
The Beast will be out at WSID on Wednesday night. Will post the results.
ps. the car is incredible, the difference the Cobb has made over and above the HKS setup is quite surprising. CRD have done a superb job with this car, it's incredibly drivable (moreso with the huge increases in torque across the range), and has ridiculous throttle response.
Larger injectors will really unleash this car's true potential.
Anyway, I'll provide an update next week.
Forget the 381kw. plenty of 32/33/34 GTR with 2530s or T04Z making that much awkw. but check out the torque curve!!! or should I say torque platform! that is why when you're in your fairly laggy 380kw R32 GTR and you line up this bloke in his 35 you get left a long way behind...
and I'm with troy. I can remember the 1990s! :D croydon autosports. GTI specialists! when you guys moved and swtiched the name to CRD yeah you became more into the GTR scene in the 2000's... i don't think troy was 'cut up' lol. just giving a little stick. hell read the blurb on CRDs website..... :D
I would say croydon autosports definitely made the swift GTi a popular cult tuning car in the 90s. and I'd say they opened a lot of people up to small capacity engines as a good thing to own and tune. not sure I'd say they made the GTR a cult car, but since changing to CRD and moving they have tuned and built way more than most and have put out some very nice GTRs. :)
The jibe wasnt intended to be a cheap shot, perhaps what i think is funny isnt funny:)
I still say ITSMAD was the coolest buzz box getting around when i was young. They were the pioneers back in the early 90s with turbo GTis and Aus deliverd S14s before the import word went gangbusters and they are still on top now.
LOL, so ... maybe im showing my age. You say CRD i think ITSMAD :)
THE BEAST SNARLED LOUDLY LAST NIGHT AT WISD WITH A SPECTACULAR 10.8 @127MPH 1ST TIME OUT, 1ST TIME DRIVER.
WITH A BIT MORE CLEANING UP WE SHOULD BE ABLE TO GO A COUPLE TENTHS BETTER.
CONGRATS PAUL!
Jim Souvas
TEAM CRD
Jim, I presume it will need a roll cage before you can get any faster - in the 10's, damn, that's impressive for a minor-ish mods. Great job guys - definitely very close to the fastest R35, 10.48s or so the US R35.
Edited by rehab2010
Now that is a goal worth pursuing...is 10.48 the best time in the US/world?
LOL, so ... maybe im showing my age. You say CRD i think ITSMAD :P
lol, I realised you were just havin a jibe Roy, I think GTi when I hear the name too :banana: Heck, I bought a NEW 1990 GTi and went to town on it, ten gearboxes later I realised something a little stronger in the driveline department was the go, so, GTR it was. haha
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.   EDIT:  Not my channel but i saw this and i know that is what i want (and i have exactly this)
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
