tongue! That was the word i was looking for. I've been getting mental blanks on basic shit for the past couple of weeks.
Thanks Guys
I had an older hilux a few years back now, around an 04 from memory, and i don't remember the suspension being anywhere near as bad (but it was good for lifting the inside rear wheel on roundabouts). Though I suppose my reference point then was a 32gtst with 8f/6r springs rather than the girlfriends C4...
Thanks Guys
I agree that the hiluxs are pretty bad. Was going to blacktown to pick up my new 32 last week in the patrol bloody thing blew up id only just flushed the radiator and put some more oil in it when i stopped at the twin servos bloody oil was $35 bucks (diesel) so left it on peats ridge road with me car trailor and rang a mate to take me to gosford hired a new 4x4 3ltr turbo diesel hilux first thing i noticed was shes limited to 4500 rpm towed the patrol up the road and it was allover the place very dangerous left it at mt white and went to pick me 32 up the thing must have no swaybar as it was all over the road on the way home with the 32 in tow felt like it would pick up and drift across the road never again.
Now the patrols getting a 307 chev rammed in between the strut towers
The other thing i've noticed is the tow bar is really low, resulting in a lot of rake on the trailer and also makes it difficult to get my (not very low) cars on to the trailer. I'm thinking about flipping the insert part of the bar to try and gain a bit of height. Does anyone know if it's ok to do or am i going to end up with a snapped hitch in the middle of nowhere?
I recently bought new sunraysia wheels and toyo light truck tyres for my tandem trailer (it had used ford stud wheels and used car tyres on it that were 2yrs old which needed replacing for rego). The result was the trailer sat 2 inches higher because of the light truck tyres. To combat the angle of the trailer I bought an adjustable ball mount from hayman reese for about $150 (#21228) and adjusted it to full height and now it sits level again.
Russman: My '09 VE SSV Ute sits similar to yours (not as bad, but i've had mine lowered with stiffer rear springs too) and thats with just a 550kg car on a 550kg trailer (sitting level). I'm gonna look at getting some different rear shocks or some other setup in the rear. It does tow perfectly though, can safetly do the speed limit and keep up with regular cars (which shocks them because they all pull out to overtake only to find they cant even keep up) and my fuel economy only jumps about 2.5L/100km over regular city driving (6L engine drops to v4 for quite a bit of the trip back to sydney from wakefield which helps the economy).
Still got 4yrs to go on my utes lease so after that I may look at a new Navara as well.
As for using a van to tow, no problems but you really need to put some weight in the back of them when you tow (spare wheels and tools would be ideal) otherwise they feel like the trailer is doing all the steering. They lack power but make up for it in reliability. (I traded my previous tow vehicle, a 2000 hiace with 370,000km on it for my ssv ute - the hiace was great, it just didnt like going up hills with a trailer on it haha)
We haven't had an issue with Hilux's towing, last 2 years used an '05 V6 Petrol 4x4 to tow our rally car around the state and its in the process of being replaced with a '11 Diesel Hilux..
The dual range gearbox comes in quite handy at times too
Draw bar, how the trailer is loaded and how the car is loaded is pretty important, I can't understand people that reverse their car on the trailer so all the weight is over the back of the axles and then complain that its handling like shit!!!
It depends on the length of your trailer and the relative car overhang. I always have to reverse my 180 on to get it to ballance correct.
The regulations state that the centre of your axles must be behind the center of the payload area of a trailer (which makes sence to generally ensure you keep some tow ball weight). However if you have a short trailer (as many are to keep weight down - 4m bed or less) and you drive a stripped out F/R race car on to it fowards, by the time you get it far enough fowards that there is minimal rear over-hang, the center of gravity of the car might be well over 1m in front of the center of the trailer axles - buy which time you could have 300kg on the tow ball - thats fine if you have a very H/D tow bar and a car with suspension to match. But a lot of cars these days are only rated to about 100kg ball weight - mine is actually only 85kg even though it has a 2000kg towing capacity.
If I reverse my 180 on to the trailer, and line it up so that there is zero rear overhang I get pretty much exactly the max allowed ball weight down on the towbar.
But yeah, if you haven't done your homework and reverse a car on tying it down 'where-ever', it can be a recipie for disaster.
Edited by samstain
Who cares how much overhang there is at either end? Drive it onto the trailer so the load is properly balanced, and as long as the car wheels are actually on the trailer (and not within the tyre radius of the edge - just a rule of thumb - nothing too scientific about that) then all is good. The only reason you'd care about rear overhang is if you have fold - up ramps. If that were the case, then having a short trailer bed is not really going to work.
Besides, if you have lots of rear overhang, your race car can conveniently block out the trailer rego plate from those nasty red light cameras - not that I'd ever contemplate such tomfoolery :whistling:
But to echo the sentiments above - yes, balancing the load on the trailer is imperative. The general guide is to have 10% of the trailer weight on the tow ball, as long as it doesn't exceed the allowable down force on the towing vehicle draw bar. 4WD's tend to have a higher rating for this, which is another reason they're better for towing.
Edited by warps
Yep, my JGC is rated at 3,500kg with 350kg ball weight, all with the factory hitch. Ample!
I love it so much, I'm likely ordering the new model soon once they've arrived, it's most reliable and hands down best tow vehicle I've ever owned :)
Lol... my uncle just came over and I asked; is your Patrol a 4.8L? And he was like, nah, 4.5L it is gutless! Might have to let him know how you go with this... the exhaust port almost looks like a perfect square?
Most of the Japanese utes are like that, Toyota used to supply all of their test Hilux's with 500kg's of sandbags in the tray, to "give journalists a real world feel for the vehicles handling" but mainly to hide the stiff rear spring rates and resultant oversteer biased handling caused by not enough weight being over ther rear wheels.
I put a tonne of gravel in the back of it the other day. If "real world feel for the vehicles handling" means softens up the ride nicely at the expense of steering then they have it right....
yes mercury is doing it, Luke is fabricating it all now.
GT3076 I think is the turbo going in.
staying with conservative tune and stock internals for now. maybe 200rwkw? maybe more or less dunno.
drop by sometime this week if you want to see lukes work - its good work!
sorry mate yep just did some more searching and just saw you started a build thread.
I'd love to drop by this build sounds good and sensible ...was told a GT3582R would be for mine but I'm liking the flavour of this one.
I reckon you could be spot on there at 200rw approx with a gt3076.
subscribed!
6 acres with a big barn shed here merli if you need to leave your toy somewhere :rofl:
2000 Grand Cherokee: 1837kg, 4.7L, V8, 162kw, 390nm, petrol.
2002 Grand Cherokee: 1776kg, 4L, I6, 140kw, 295nm, petrol.
2003 Nissan Patrol: 2440kg, 4.1L, I6, 114kw, 360nm, turbo diesel.
2005 Toyota Hilux Ute: 1490kg, 4L, V6, 175kw, 343nm, petrol.
Lighter, newer, more power, more storage, most reliable. I know which i'd have at the top of my list :D
I know its an older topic but why no mention of the:
:worship: Nissan Patrol: 2375kg, 4.8L, I6, 180kw, 400Nm, petrol (but can run on gas) 3500kg towing :rofl: and bigger drive line then all 4 of the above mentioned cars and far stronger (diff, axles, transfer case, brakes, etc). As far as fuel economy goes, on petrol its like any other 180kw vehicle but on gas mine was fully loaded and towed a caravan from south of Sydney to Maroochydore (1200km) at Christmas cost me $215 and still had 3/4 tank of gas. The car was on cruise control most of the way and had no problems with hills etc. only problem was slower traffic...lol I could of got even better fuel economy out of it if I took off my 35" tyres, the big lift kit, winch with steel cable....makes it like a block of flats coming down the road, not exactly aero dynamic but goes everywhere I ask it to even when towing the van... :rolleyes:
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
    • It was picked up on the MOT/Inspection that the offside front wheel bearing had excessive play along with the ball joint. It made sense to do both sides so I sourced a pair of spare IS200 hubs to do the swap. Unfortunately I don't have any photos of the strip down but here's a quick run down. On the back of the hub is a large circular dust cover, using a flat head screw driver and a mallet I prised it off. Underneath will reveal a 32mm hub nut (impact gun recommended). With the hub nut removed the ABS ring can be removed (I ended up using a magnetic pick up tool to help). Next up is to remove the stub axle, this was a little trickier due to limited tools. I tried a 3 leg puller but the gap between the hub and stub axle wasn't enough for the legs to get in and under. Next option was a lump hammer and someone pulling the stub axle at the same time. After a few heavy hits it released. The lower bearing race had seized itself onto the stub axle, which was fine because I was replacing them anyway. With the upper bearing race removed and the grease cleaned off they looked like this The left one looked pristine inside but gave us the most trouble. The right one had some surface rust but came apart in a single hit, figure that out?! I got a local garage to press the new wheel bearings in, reassemble was the opposite and didn't take long at all. Removing the hub itself was simple. Starting with removing the brake caliper, 2x 14mm bolts for the caliper slider and 2x 19mm? for the carrier > hub bolts. I used a cable tie to secure the caliper to the upper arm so it was out of the way, there's a 10mm bolt securing the ABS sensor on. With the brake disc removed from the hub next are the three castle nuts for the upper and lower ball joints and track rod end. Two of these had their own R clip and one split pin. A few hits with the hammer and they're released (I left the castle nuts on by a couple of turns), the track rod ends gave me the most grief and I may have nipped the boots (oops). Fitting is the reversal and is very quick and easy to do. The lower ball joints are held onto the hub by 2x 17mm bolts. The castle nut did increase in socket size to 22mm from memory (this may vary from supplier) The two front tyres weren't in great condition, so I had those replaced with some budget tyres for the time being. I'll be replacing the wheels and tyres in the future, this was to get me on the road without the worry of the police hassling me.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
