I rate the F40s. I grabbed some 6 pot Alcons and got all wet over them until i realised they run 376x36mm rotors :P A bit bigger then i was expecting/hoping. Oh well, back to std brakes while the car sits in storage. One day....i will just burn it and build a track GTSt like Two Bens Racing
The pump unit in the 32 series is the same.
My GTR has Porsche 6 pot's on it, and i can still flat spot tyres with it.
I'd put a fair but of thought into a Tarmak Rally GTR, and if wanted to build the best 32, you'd fill it with R33 bits. The ATTESSA PRO ecu is day and night compared to the R32, heaps faster, ABS is heaps more responsive (but not too aggresive) , also feeds torque to the front wheels under brakes (found that from datalogging it) for stability, and a R33 transfer case to handle the higher baseline awd. IMO the biggest problem with the 32 is the old tech ECU's, it was bloody advanced in 1989, but tech came a long way by 1995, i think the pumps are fine, just the ECU that drives them.
A R33 ATTESSA ECU would be well worth doing, as you have better ABS, and AWD. I'm not sure how hard it is to disable to A-LSD in the ATTESSA PRO, cause that's the one you want. Only thing you'd want to consder is if the R32 tranfercase can handle running a little all the time.
On another note, where did you get the rotors for your F40's? Are they 2 peice, and 332mm?
The F40's (like most stuff on SAU) came from Roy. They are a good calliper & take a pad from the 4 pot Brembos on the Falcons of all things. Makes me wonder if all those Brembos on Foulcans can be put to better use?
The rotors are stock R33 gear, ie 324x30. Still trying to find a 345 rotor to suit & get bracket made. Project Mu don't quote the offset for their 345 rotor for the Nissan (Part Number FC44 N102A & FS44 N102A with the callipers dependent on which calliper). :ninja:
I found the bias to be a little too far rearward so I reckon the bigger rotor would be excellent.
The issue(s) I had with the ABS ECU are obviously that the cycle rate is rubbish but more so that the damn thing doesn't appear to actually release the locked wheel when you are on R compounds. Maybe the line pressure is too high but it doesn't function at all well as ABS on the track. Makes me wonder why bother carrying it.
R33 computers/ATTESSA looks like an idea. No need for the 33 V-spec stuff but if the povvo pack gear works on a 32 that would be excellent. Although having said that with the Ruzic controller there isn't too much wrong with the 32 ATTESSA - as long as it is shimmed to spec.....
Bugger, i have a 343mm bracket for the F40, though its buried in storage :) Dont run PMU 345s...lol for gods sale. Way too expensive., Grab some B-Spec 343mm x 32mm rotors. Good sturdy design and reasonably priced replacements and they are a very easy rotor to adapt the F40 to.
Depends on which hats you have. Alcon, Dixcel, Brembo, Stoptech all make a decent 332 x 32mm rotor. I guess you run Brembo so you can get Dixcel replacement rotors off yahoo or out of Japan. Since the dollar is doing ok you can consider buying new stoptech hats and rotors as the hats are damn similar but sadly dont take the Stoptech rotor (assuming you run a Brembo hat) It may work out more viable as the Stoptech replacement rotors are very cheap compared to many of the others out there
fgs, re bend those brake lines!~ my grandmother can bend tube better than that... =P
other than that im loving the suede dash and the build up in general... awesome stuff, best of luck.
are you allowed to replace all the glass with something a bit lighter like perspex?
im heading out to strip my '32 after being hit with a wave of inspiration hah ha.
Cheers, Rowdy
Cheers, Rowdy
Re brake line. Damo is not responsible for any of the braking system thus the level of workmanship is low. lol.
yep perspex can be used but its getting more like a dollar thing as im spending more money than ben had budgeted. i dont think we will have any issue getting down to the base weight for targa anyway.
Cheers, Rowdy
your grandma can definatly take pipe better than that, she's very good at taking pipe. :D
Edited by sav man
more update
Mounts 1/2 fabricated for the abs sensors. just need to drill holes for sensors.
Test fitting the dash
Damo straightening the fins on roys old intercooler.
Painted engine bay, now with some more wires.
Modified coolent pipe for under the plenum
dash looks good boys... will be doing mine this weekend.
ive read that the 3m spray glue is good to use also?? yes?? no?? dont know?? should i repeat the question?? or is selleys qwik grip the only shit to use??
using pegs is a bloody good idea too... must get some of them yes.
this biger question is will it be ready in 30 days. As those last 26 days will be used for testing.
Nah its only fun when your running in/tuning/finishing off interior on the drive to scrutineering!!!!
But yeh good plan!
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
