Ben's R32 Gtst Build
sav man
I rate the F40s. I grabbed some 6 pot Alcons and got all wet over them until i realised they run 376x36mm rotors :P A bit bigger then i was expecting/hoping. Oh well, back to std brakes while the car sits in storage. One day....i will just burn it and build a track GTSt like Two Bens Racing
The pump unit in the 32 series is the same.
My GTR has Porsche 6 pot's on it, and i can still flat spot tyres with it.
I'd put a fair but of thought into a Tarmak Rally GTR, and if wanted to build the best 32, you'd fill it with R33 bits. The ATTESSA PRO ecu is day and night compared to the R32, heaps faster, ABS is heaps more responsive (but not too aggresive) , also feeds torque to the front wheels under brakes (found that from datalogging it) for stability, and a R33 transfer case to handle the higher baseline awd. IMO the biggest problem with the 32 is the old tech ECU's, it was bloody advanced in 1989, but tech came a long way by 1995, i think the pumps are fine, just the ECU that drives them.
A R33 ATTESSA ECU would be well worth doing, as you have better ABS, and AWD. I'm not sure how hard it is to disable to A-LSD in the ATTESSA PRO, cause that's the one you want. Only thing you'd want to consder is if the R32 tranfercase can handle running a little all the time.
On another note, where did you get the rotors for your F40's? Are they 2 peice, and 332mm?
The F40's (like most stuff on SAU) came from Roy. They are a good calliper & take a pad from the 4 pot Brembos on the Falcons of all things. Makes me wonder if all those Brembos on Foulcans can be put to better use?
The rotors are stock R33 gear, ie 324x30. Still trying to find a 345 rotor to suit & get bracket made. Project Mu don't quote the offset for their 345 rotor for the Nissan (Part Number FC44 N102A & FS44 N102A with the callipers dependent on which calliper). :ninja:
I found the bias to be a little too far rearward so I reckon the bigger rotor would be excellent.
The issue(s) I had with the ABS ECU are obviously that the cycle rate is rubbish but more so that the damn thing doesn't appear to actually release the locked wheel when you are on R compounds. Maybe the line pressure is too high but it doesn't function at all well as ABS on the track. Makes me wonder why bother carrying it.
R33 computers/ATTESSA looks like an idea. No need for the 33 V-spec stuff but if the povvo pack gear works on a 32 that would be excellent. Although having said that with the Ruzic controller there isn't too much wrong with the 32 ATTESSA - as long as it is shimmed to spec.....
Bugger, i have a 343mm bracket for the F40, though its buried in storage :) Dont run PMU 345s...lol for gods sale. Way too expensive., Grab some B-Spec 343mm x 32mm rotors. Good sturdy design and reasonably priced replacements and they are a very easy rotor to adapt the F40 to.
Depends on which hats you have. Alcon, Dixcel, Brembo, Stoptech all make a decent 332 x 32mm rotor. I guess you run Brembo so you can get Dixcel replacement rotors off yahoo or out of Japan. Since the dollar is doing ok you can consider buying new stoptech hats and rotors as the hats are damn similar but sadly dont take the Stoptech rotor (assuming you run a Brembo hat) It may work out more viable as the Stoptech replacement rotors are very cheap compared to many of the others out there
fgs, re bend those brake lines!~ my grandmother can bend tube better than that... =P
other than that im loving the suede dash and the build up in general... awesome stuff, best of luck.
are you allowed to replace all the glass with something a bit lighter like perspex?
im heading out to strip my '32 after being hit with a wave of inspiration hah ha.
Cheers, Rowdy
Cheers, Rowdy
Re brake line. Damo is not responsible for any of the braking system thus the level of workmanship is low. lol.
yep perspex can be used but its getting more like a dollar thing as im spending more money than ben had budgeted. i dont think we will have any issue getting down to the base weight for targa anyway.
Cheers, Rowdy
your grandma can definatly take pipe better than that, she's very good at taking pipe. :D
Edited by sav man
more update
Mounts 1/2 fabricated for the abs sensors. just need to drill holes for sensors.
Test fitting the dash
Damo straightening the fins on roys old intercooler.
Painted engine bay, now with some more wires.
Modified coolent pipe for under the plenum
dash looks good boys... will be doing mine this weekend.
ive read that the 3m spray glue is good to use also?? yes?? no?? dont know?? should i repeat the question?? or is selleys qwik grip the only shit to use??
using pegs is a bloody good idea too... must get some of them yes.
this biger question is will it be ready in 30 days. As those last 26 days will be used for testing.
Nah its only fun when your running in/tuning/finishing off interior on the drive to scrutineering!!!!
But yeh good plan!
been there done that, ended up wedged off the road at hillwood, that flattening a pole at stragn. Not doing that again, if it's not going by the end of March I won't run this year.
    • He could just take the Bogan Cruise Ships setup... Already got a good setup, with blower, the auto was rebuilt too wasn't it? Perfect time for him to upgrade the tailshaft, diff, and axles...    And wouldn't need to waste money on redoing the Commos seats, as he could just buy race seats for the 5...   As a highly modded car he could avoid the ability to give it away to offspring too when they crash their cars...
    • It's really interesting how much it's moving left to right, and doesn't appear to be actually spreading. For this to be moving left to right, without flaring, means unequal forces being applied until equilibrium hits in one way or another.   Reasons it could be unequal; Piston sizes left to right are different sizes. Only minute differences. Pistons moving on different planes. That is, are they moving directly straight at each other, or slightly out of alignment. The fluid is restricted getting to one side.   Some tests you could do. Pull the bleeders on the left and right, fit each side with pressure gauges. It will allow you to make sure pressure is equal (and really, it should be as fluid flow is so damn low, so fluid flow dynamics shouldn't come into it).   With the calipers off the car, have both sides retracted as far as possible, measure very very accurately (think micrometre) distances between opposing pistons in four different spots per set of pistons. Firstly, on each opposing pistons pair, the measures on for different spots should be equal. If it's not, and especially if one spot appears to actually get closer compared to another, the pistons aren't aligned, and now the forces left to right won't be equal, as they're the forces fighting each other.   You can also pull all the pistons out, and very very accurately measure the diameter of them. If they're not equal left to ight in the pairings, and especially if the area of the pistons on one side is different to the area on the other overall, it'll all be out of whack.   My bet, is shit QC in making sure the pistons move in the same plane left vs right. Some minor out of square machining, and nothing will line up, things will want to move around.
    • Whilst putting a V8 in a MX5 would be fun, it would negate the whole cheap to run fun daily that the MX5 will be used for If I wanted a faster little convertible I would have got a engine check light, I mean a BMW Z4 M, but going off the issues that the guy at work who recently got one is having, it is lucky I didn't  Meh, horses for courses, the Bogan Cruise Ship is my go to for some horse torques
    • I reckon give him a few months, LSX swap would be good
    • Mark needs to get bored at work and order things on here...
