Cable ties farken :)
Looks good and +1 needs rear pods!
Pair of rear pods would struggle to weigh half a kg haha
the point of the car is for minimum weight. if you had seen the effort we have gone to every where elce on the car than .5kg is good weight to us. i totaly understand that most people fob off weight reduction but its one of thoes things that if you are going to do it you need to get really anal about it. no point getting half assed. and to be honest it is very noticable the difference we have found from driving this to all the other skylines we have as a group.
also on anther side note. Bens vision was to run the full nismo/N1 aero kit which never had rear pods. what most people think are N1 pods are actualy trust or other pods. the rear pods do nothing for the cars performance or aero so they are un-nessasary. this car was built with only nessasary items installed. also if you look at most modern TA cars the rear area behind the wheels is usualy cut out to help the air excape from behind the wheel. some teams run multiple wings behind them to help smooth the air but we cant do this.
the conclusion is, no pods it is.
I never wanted the pods before we got on the weight saving campain. I just have never liked them, plus they only hold water and make the rear 1/4 panel rust out (which i've already fixed one time to many)
Why did you bother with the type m side skirts then? A little weight in those too.
How much do you weigh? Taking a decent turd will loose you the half a kilogram... I love how 100kg plus people talk about weight reduction (not saying you are one of them) when if they just layed off some cheeseburgers they would be a lot better off :)
There is no "nismo/n1 aero kit" for a gts-t, you can get type-m side skirts and rear pods but n1 stuff is for gtr's. also there are no "n1 pods" for a r32 gtr, they are only trust pods which look similar to a gts-t's type-m rear pods
You could always just drill a drain hole in the bottom of them to disperse the water... I've never seen that issue on a 32 before. The only rust we see is rear 1/4 panels on the 4wd gts4's or gtr's
the idea was to make the N1 side skirts fit. im pretty sure we all know the difference between GTRs and Gts-ts. im pretty sure i already said there was no N1 pods but you must have read over that.
we have found one company that makes N1 style skirts to fit gtst but haven bothered as yet.
like i said before if your not into weight loss on a car than you will never get it. its a combination of many small parts that weigh half of f all that makes the difference. serious people will un-tack or cut off every un nessasary bracket and cut the extra length out of every bolt just to save 5kg over the whole car. most people think once they have removed the ac and back seat they have removed every thing they can. the point is weight is free power and free brakes. simple physics.
wrong.
see we rubbed all the paint off where the stickers were going then rubbed some of the metal back to save a few more grams.
this also ensured a seemless join between the sticker and original paint
    • I strongly recommend anyone playing with cars chasing anything electric, get a basic understanding of using a DMM, and about 12V DC systems. They're REALLY easy, you only need to know V=IR and how to apply it, and you can work out what your readings should be doing. For a simple check on a light bulb, you're looking for 12V at the positive to the light, a near zero resistance to ground, and then for a small resistance across the globe when unplugged. If one of those values isn't right, you won't get what you need. Now if they're all okay,and you then plug the light in, and it still won't work, you now do a voltage check across the globe positive to negative. It should effectively read full battery voltage. If it's not, especially if it's quite low, the age old V=IR starts to be able to be thought about, you now know though, for the current flowing, there isn't much voltage for the given resistance, but the rest of that V has to be dropping somewhere else. So now do a voltage check from ground of globe, to ground of car, then do voltage check from positive of battery, to positive of the light connector. Things like a high resistance in a wire/join will start to "steal" voltage on you. So now step back through which ever wire, until you find the voltage drop is non existent, you're now before what ever is steal your voltage for example.   There's plenty of YouTube videos, but really worth understanding some V=IR, and doing some even theoretical numbers to start to understand it. Then you'll know what the DMM is telling you.
    • Is Jackie home by Friday?
    • Item 10: Tech Edge wideband sensor interface and display. You’ll need to buy a new sensor. $150. Item 11: part of a Willians 5 point harness. $40 Item 12: OS88 gear display. No need for it now, my PPG sequential came with one. $30
    • I took it out, even though I knew I probably don't know what I'm doing other than looking for power signal lol. Lesson learned here I guess, even if it looks normal, worth checking as it only takes a few seconds anyhow. And maybe disconnect the battery, even though really shouldn't have to.
