Well I killed another engine, but still finished 5th (was 2nd at the time)
here are some stages
Paloona 2nd fastest EM car
Plimsoll fastest EM car
Edited by sav man
I'll have to pull it down, but i'm guessing the valvle didn't close properly for what ever reason, and it gas axed the side out of it. We checked plugs, injectors, and ignitor on the side of the road.
We rounded that GT2 up 2 stages in a row!! There will be more stages uploaded soon.
I wondered what happened! I saw you were 3rd going into the last day and then finished 5th. Time for a 2jz?
It was 2nd, and no shitty Toyota engine is going in my car. I've done a different thing each time from the bottom up, so now i'm at the top, the next engine will be fine.
Rinadeena looks like an amazing stage...absolutely hammering! Suspension looks planted. OK, time to start flogging your spec Penskes to the rest of us :)
I did almost poo my pants at 10:25 when the car jumped sideways. If you want some I can put you onto my tuner, he organised all the valving. still learning a lot about setting them up, but being able to adjust hi and low speeds separatly makes a big diference in changing conditions. Any good shock can have my valving applied Penske/ohlins (sweedsh)/mca/proflex.... But it's probably cheaper to get the Penske's out of the states, and revalve them here
the bloke that done the specks on the shocks is about to do the same thing to a old set of jap ohlins that i got ahold of. they only have one twiddle valve but he said he will get them close enough.
this year ben adjusted the shocks at least every other stage and the car got faster by the end of each day and once it rained he new what way to go with them. it would take a few club days to dial these in perfect so its not a set and forget part. just for anyone elce thinking they mite like to spend the money. beauty of a bilstein is you cant adjust it. haha.
Starting to sound like a 300zx, 5 days... Engine out Lol! I won't touch it next year, promise!
PS where is the adjustment on the Penske's??? The KW we ran were easy to adjust on the front, but UBER gay on the rear.. especially on the side of the road between stages
c'mon a 300zx need a engine out every stage.
The penske's are upside down (shaft at the bottom), and the remote canisters are under the boot and bonnet (high and low speed bump), so the bump is super easy. Rebound is on the bottom of the shock, and required laying on the ground. But I didn't change the rebound very often.
haha well you were damn luck it was running at all.
I'd be pulling, checking and cleaning the head. When I snapped a cam it f**ked the tunnel as well and it needed to be machined straight again. Also, you will have aluminium everywhere including the sump.
    • Welcome to my 2004 Toyota Mark ii IR-V Fortuna (series 2) With a 1JZ-GTE powerplant under the bonnet (hood) it'll give me plenty of scope for power upgrades. For those who aren't familiar with imports, the 1JZ-GTE is a 2.5L 6 cylinder VVTi engine with a single turbocharger. This has the factory R154 5 speed gearbox, along with a aftermarket 2 way LSD differential (brand unknown). Under the arches are a set of CST Zero 1 alloys, 18x9 +30 225/40 up front and 18x9.5 +15 265/35 on the rear. The car was quite low in Japan and there's evidence of the wheels catching the rolled arches/fenders. The tyre's aren't great so I'm in two minds whether to replace both or just the tyres and put up with the wider wheels on the rear. The car still uses stock brakes with the addition of some braided hoses. The exterior is stock with the exception of a BN Sports front bumper and a replacement Fortuna grill  Moving to the interior, the steering wheel has been replaced with a dished MOMO steering wheel (which will get swapped for my Momo Tuner for the time being) Defi Link Gauges are mounted above the climate controls and on the A pillar, the Oil Temp,Oil Pressure,Water Temp and Boost gauges should help with spirited and track driving  The stock seats have been replaced with some retrimmed Recaro bucket seats. Being a larger build these are a little snug, unfortunately the orange isn't for me so I'll look into replacing these down the line. Other modifications include a twin plate clutch, Blitz intercooler, Evolve alloy radiator, a stainless exhaust with decat, HKS EVC-S boost controller and coil overs
    • Apologies for the long read My R34 GTT was up for sale at the beginning of spring due to a few repairs creeping up. The strut tops needed replacing, roof and bonnet (hood) painting (yay for 3 stage pearl) and the underside stripped and treated. I sold the car which allowed me to be in a much better place financially. Leading up to the sale I was already thinking about the replacement. In an ideal world it needed to be a good all-rounder. Something I can mess around with, modify, do track days, do the school run, go on long drives etc.  Options included but not limited to... Laurel C35, Evo 8/9, Civic FD2, Impreza Hawkeye, Aristo and even an Audi S4 Avant (I've already got the Mazda 6 wagon). But there was always one car at the top of the list The Toyota Mark ii JZX110 I found an advert on a Facebook group for an example in Japan, from a seller called Jon at Rising Sun Exports. A few messages back and forth and Jon calls me from Yokohama one morning (or afternoon in his case). He briefly explained the import process, the costs involved and a repeat of the advert. After much deliberation, the price was agreed and the sale was locked in. I've never imported a vehicle so I jumped into the unknown head first. The money transfer was completed through wise.com (fees apply), very easy to use and the money was with him within a day or two.  The car suspension was raised for the vessel and the car dropped off at the port. It was 7 weeks later when the bill of lading was received and the freight invoice sent to me, followed by the export certificate a couple of days after (both digital copies) In the mean time the port had been in contact. I needed an agent to deal with the NOVA (notification of vehicle arrival) along with the tax/duty invoice, this was £75.00. The port also had a fee of £100, I'm guessing to cover the cost of the 10 day 'free storage' and for moving the car off the boat etc. They need a copy of the vehicle invoice, freight invoice and export certificate to allow the vehicle to pass through customs. The vessel arrived on Tuesday 5th August, the tax/duty invoice was generated and sent over. This is generally tax 20% and duty 10% of the vehicle value. Although the invoice came in at a higher amount than I had calculated. Once HMRC had received the payment the vehicle could be released from customs. I thought once the tax/duty was paid you could collect at any point, that's not the case. Your agent will need to book a collection slot, I requested Thursday 7th which was accepted, with a 9:00am slot allocated. It was a 5:00am start from Norfolk heading to Southampton. We eventually found the compound, upon presenting the bill of lading and some ID they released the car (they drove it out of the compound to the front ready for us to load up). The email from the port stated each slot had a 10 minute window, which seemed abit farfetched but the staff said it's not a strict rule. We were there for approx. 30-40 mins in total. A week prior to collecting I contacted my garage and explained the situation, I was able to get an inspection slot that afternoon. For the registration, DVLA require the car to be insured, for this I used a company called Adrian Flux who can insure the vehicle using the VIN number.
    • Hey guys, looking for these side skirts if anyone can help me out.
    • Wife and I are still looking for a new home. One condition was a large enough garage for a full-size lift in one bay. Now if only we could find something... We've been looking for almost a year now.
    • Thanks everyone for the ideas! Sadly, ramps are a no go for me. With young kids at home, I do most of my work late at night while they're sleeping. Starting the car multiple times wouldn't be a great idea.  I'll go see one of those new long reach low profile jacks and take a couple measurements to see if they will fit.
