Amazing thread to go with an amazing car. Your choice of parts and the carbon/colour combo couldn't have been more spot on!
Add me to the list of people waiting for the vids!
Can't wait to see the feature, any idea what issue # it will be?
Must be that Silver one with same mods in GTR.co.uk site... but So nice.... would probably end up copying inside Carbon idea, when i get mine... Everything else in this car is so out of the average Joe "Mine" budget, it's not funny. where those video's
I started reading this thread a few months ago when only the teaser pics were up.
Found the thread again and spent all night reading it.
Perfect, tasteful, powerful R34 GTR. This over a R35 anyday. :P
How's your gearbox holding up by the way?
  • 3 weeks later...
Hi all,
Just a quick update on the suspension upgrade with Racepace customised Tein RS setup.
The Tein RS, aka 'Circuit Master; Super Racing Spec', has been out of production since 2006-2007. They were the top of the line in the Tein catalogue for production cars at that time. In some ways, I feel that the materials used and the way it was manufactured surpass what's commonly available today, even the premium priced shocks.
Details of the RS are listed below (sourced from US based my.is forum in 2002)
MATERIALS AND FACTS:
DAMPING MECHANISM:
45mm diameter pistons
Double shim stacks (near unlimited tunability with knowledge of shim valves)
Two 'special form' adjustment needles
SHOCK/RESERVOIR BODY:
Monotube shock body
53mm outer diameter
Aluminum alloy (A7050) seamless tube, CNC'ed, green (hard?) anodized
Inner tolerances:
diameter: ±5µm
roughness: ±1.6µm
Reservoir body interior is PTFE (Teflon) coated
CNC'ed aluminum alloy eyelet, Tein rubber bushing, steel pivot
SHOCK SHAFT:
14mm diameter
Chromoly (SCM435) steel, Ti-N coating
SHAFT SEAL/GUIDE:
WRC spec
PILLOWBALL MOUNT:
Aluminum alloy, CNC'ed, powdercoated (gold)
SPRINGS:
Main and helper
Steel, ground and tapered, enameled
10K front, 10K rear
SPRING PERCHES:
Aluminum alloy, forged and machined
SETTINGS:
-34mm front, -12mm rear (easier measured as 335mm both from the center of the wheel to the fender lip, front and rear)
10 clicks rebound front
10 clicks compression front
10 clicks rebound rear
13 clicks compression rear
Out of the box, the RS will not suit my purpose of a street orientated setup in Australian conditions. So the solution Racepace derived is to employ a high quality, well engineered shock to begin with and customise the valving and spring rates.
The current spring rates are less than half of 10K front and rear. The exact rate Racepace did not divulge and so is what they did to the revalving. BUT believe me, the setup works very very well.
My initial impression, compared to the Nismo S Tunes, which is also street orientated:
- The damping is comparable, soaks up bumps and road undulations well. The rebound is quicker than the S Tunes, that the RS is less 'cushy'
- The car feels more planted and can hold its intended steering path despite mid corner bumps etc
- At very low speeds, the RS is very compliant
The only annoying thing is an annoying 'whimper' originating from the rear shocks at very minute bumps. It almost sounds like someone rubbing a wet finger on clean glassware. However, I did some research and found that this is quite common, and indicates no fault. The pillow ball mounts also transfer more road noise to the cabin.
I spent a good afternoon with Chris from Racepace. And this is how I feel as a passenger..... Well Chris test drove the car in a 'hill' run. (Chris is an excellent driver btw. He scared the sh*t out of me)
- The car feels like its on tracks and bumps do not upset the momentum.
- Car feels planted, period!
Chris comments that the RS allows him to transfer weight nicely and from the get go the setup is confidence inspiring. That is he can drive a lot quicker if I was not in the car with him. He was extremely happy with the way the RS can handle the low speed stuff equally as well as the high speed.
Overall, I am very impressed, bearing in mind that the Nismo S Tunes were very good to start with. I highly recommend it to anyone wanting a street car to go for less spring rate but good damping force.
Final thing on the agenda - increase ride height on front end and transfer case reinforcement.
PS will post pics on weekend.
Cheers
Matt
can still buy the tein RS from tein japan :)
can still buy the tein RS from tein japan :banana:
oreally? I can only see reference to "super racing spec" on their sites which I believe were the same thing, but everyone reports them as being discontinued.
I am up for a set if this is true and someone can speak Japanese!!
Hi all,
I am totally amazed at the continued support and interest in my build.
Regarding some of the queries:
The gearbox is holding up well despite the extra power. I guess I do look after the gearbox by avoiding any hard launches.
Second hand Tein RS still pop up every now and then on Yahoo Japan. You need to check frequently to find them and they do sell rather quickly. I sourced my set with help from Import Monster.
I am looking forward to the Performance Import featuure article. However, I have received no news as to when it will be published or even seen proofs of Jun Sawa's work. They are certainly keeping me in suspense.
Cheers
Matt
Matt Im so glad you have had your PI shoot. with mine still a couple months away it almost gaurentees i wont be in the same magazine haha...which im very thankful for.
Must be time to use your modifying talent on a 35 now too :(
http://www.tein.co.jp/search/search1.cgi?a...SAN〈=ja
price isn't cheap ¥292,000yen
What you have quoted is not the TEIN RS's that Tangomatt and other Racepace GT-R's use.
They are the replacement model which are too hardcore for a street orientated track car....
Hi all,
Cheers
Matt
Hey Matt,
I will be in touch to catch up soon.. i do believe its out January but will confirm.....
  • 5 weeks later...
Hi guys,
Its been a while since an update. I finally got around to posting the pictures below of Tein RS before the installation.
Yes, you are right, that is a another set of Tein RS in one of the pictures that Racepace was modifying at the time my set was being done.
Eibach coils
custom aluminium spring seat:
I will take installed photos soon
Cheers
Matt
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
