  • Replies 181
ok boys i know its not saterday but yeah im stuffed and today is the first time to post
well you all know it started like this
well now its final finished for now LOL we all say that LOL
Well that's it for now while my downloads are capped but be sure when its back a lot more photos and description will be added
lol GB, i could not think of anything that sanded for lol,
its a gal spray paint its awesome for covering imperfections and covers anything, ill take a photo of the can some time next week for you.
also for more interior photos ill get some more in the week
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
