Spotted Humbla on the Hume Hwy yesterday and cruised together for about 20k's. :action-smiley-069:
Our lil cruise was nice till a fool cut in front of me and slowed down.Was lovely to see your smiling face again. :action-smiley-069:
Saw 2 White R34's separately 30 mins ago at Bella Vista. 5:30 PM
One going going north on Old Windsor Rd passing the traffic light near BP gas station and Maccaz
I was exiting the gas station so couldn't get a good look.
and the other one parked outside 20 Lexington Drive. Had no spoiler. Love the body! thumbsup.gif
This thread needs more ictures of spotted cars. I have been on here searching for any spots of my old car... I miss her. And RTA search reveals number plate has been changed :( Will I ever see my baby again :unsure:
Yer on green parker and one head light lol i thought was 32 rear 34 front but didnt get a good enough look at the rear.. You wouldnt have seen me i was in a green 2011 fiesta :-P
car looks phat mate..!!
Hahah yeah.. the dreaded one-eye r32 headlight ailment..I need to pull the lightswitch apart by the sound of things :rant:
...and the green parkers certainly add some wank-factor :rofl2:
It's a work in progress, though it'll never be a show car I like the 'beef' that the wide 34 panels give :turned:
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
