Had a chat with Darksky34 at the lights on Balaclava Rd and Epping Rd tonight :action-smiley-069:
Hey Adam hope work wasn't too bad! :action-smiley-069: oh and by the way do you know your two inner tail lights are only half lit up?
Work was painfully dead, bored out of my mind lol
No I didnt know that, i'll need to check those out. Cheers
MR 34 YO
yellow R34 Sunnyholt road. I didnt see him until pulled up at lights. but it looked like he was trying to catch me, almost entered the set of lights when it was red. then took off like a clown.
Why the f*k do you have a VTEC sticker on your back window??
MR 34 YO
Had to read that twice lol
And I had to agree with that question… what the fark!!!
  • Like 1
Followed a white R35 through Glenwood last night between 7:30 and 8pm then a few minutes later passed a white R34 GTR, didnt get the plates but I think it was Brett (REAP3R)
Wouldn't have been me last night I was out and about at that time around there but I was in my s14 instead haha
I had a black R34 GTt parked in my street earlier in Toonie, almost directly across the road from my house. It had a kit on it and black multi-spoke wheels, not sure who owns it and didn't get a chance to check it out.
    • @Haggerty this is your red flag. In MAP based ECU's the Manifold pressure X RPM calculation is how the engine knows it is actually...running/going through ANY load. You are confusing the term 'base map' with your base VE/Fuel table. When most people say 'base map' they mean the stock entire tune shipped with the ECU, hopefully aimed at a specific car/setup to use as a base for beginning to tune your specific car. Haltech has a lot of documentation (or at least they used to, I expect it to be better now). Read it voraciously.
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
