Just finished putting a new turbo on the 32 everthing is all sweet there. But now it runs super hot always hovering around the 85-90deg area the car has a new waterpump new thermostat new hose's new thermo housing have just heat wrapped the dump pipe and have a beanie on the way for the turbo, even have the bonnet lifted at the back. Car does have a FMIC but there is plenty of room between it and the Radiator, radiator is in very good condition as well.
Any ideas?
Thanks
https://www.sau.com.au/forums/topic/295916-always-hot/
What radiator?
High mount turbo or low?
85-90 isn't anything overtly 'bad'.
Did you put the rear of the bonnet up @ the same time as the rest? Could try it down (i've never been convinced it helps, i never get over 75 with my rear down :happy:)
https://www.sau.com.au/forums/topic/295916-always-hot/#findComment-4931618
I had a issue with mine after a rebuild. I found that I accidently put on the wrong engine fan. The one i put on was from a R31 skyline and it was a different design to the RB25 one and it caused heating up to about 98 deg on normal running.
Also make sure you have bleed the cooling system correctly. ask if you are unsure how to do this. It is also good to do it when the front of the car is jacked up as high as you can go.
if your running thermo fans make sure they are turning the correct way also
Radiator is factory turbo is low mount and the bonnet was up before the turbo install.
There just seems to be a super amount of hot air at the front of the engine.
https://www.sau.com.au/forums/topic/295916-always-hot/#findComment-4931795
Like the Nismoid, I, too, am unconvinced on the ability of a raised bonnet rear to assist in cooling.
The base of the windscreen is a high pressure region, which is how air gets pushed into the ventilation / heater system. I believe it is also why the old-school GroupA Fords / Holdens had that reverse bonnet scoop to feed the carburetors.
Air moves from regions of high pressure to regions of low pressure. The high pressure air at the base of the windscreen will be pushed into the engine bay through the raised rear edge, increasing the pressure inside the engine bay. This will reduce the pressure differential between the front of the car and the engine bay, limiting air being able to pass through the radiator. And if air doesn't pass through the radiator, no cooling takes place.
Put the bonnet rear back down (the way Nissan designed it).
https://www.sau.com.au/forums/topic/295916-always-hot/#findComment-4931934
that's because R34 (GTR/GTT) thermostat starts opening at 82c and is fully open at 85c (or 86 can't remember exactly now) whereas the R32/33 starts opening at 76.5c I think it's an emissions thing, R34 engines like a bit more heat.
To bleed properly try this .. get a 2l coke bottle (clean it out obviously) and cut the bottom off. Stick it inside the radiator opening and seal the area properly so that coolant can't escape. Poor the coolant in and overfill so that there's like 10-15cm of coolant in the bottle ABOVE the radiator cap. Run the car like this for 20-30 mins. You'll see an absolute insane shitload of air bubbles come out through the coolant in the bottle as the car warms up. I couldn't believe the amount of air that came out when I used this method. Probably about 20x more than I got out using the engine bleed screws.
If it's still overheating make sure your fan shroud is on properly .. without a shroud it will always overheat no matter what.
https://www.sau.com.au/forums/topic/295916-always-hot/#findComment-4932547
mine reads at 82 with an ISC alloy radiator, even on hot and when im giving it a hard time, also my screamerpipe is hanging out with no shields on dump pipes and turbo heatshield is offl, If i chuck back on my turbo heatshield would it make a diffrence?
https://www.sau.com.au/forums/topic/295916-always-hot/#findComment-4934507
my old rb20 would stay rock solid between 78-82c highest i got it was 87c
the rb25 i have now is all over the place it will get up to 90c after 5 mins of idling in hot weather usually idles around 84ish but when i hit the freeway in the morning and give it a bit in 2nd/3rd out of the off ramp it will go down to 74c... then back up to 78c while cruising in 5th at 3000rpm.
i think the water pump is on the way out, i get a little whine on idle so that's probably the cause.
https://www.sau.com.au/forums/topic/295916-always-hot/#findComment-4934634
Best way to seal it is to put some electrical tape on the thread where the bottle cap goes, then you just have to push it into the radiator and twist it and it will seal as well as staying there with out having to hold it.
https://www.sau.com.au/forums/topic/295916-always-hot/#findComment-4935453
  • 4 weeks later...
Sorry to bring up my old post but i still cant get my temp down ive bleed the system more then 5 times using all the suggested ways but it still sits at 90deg at idle and when i give it a bit the temp hit 100+ and takes over 20min to come back down. Realished tonight that my fan clutch/hub is always on and working??
Really over this so any help is appreciated.
https://www.sau.com.au/forums/topic/295916-always-hot/#findComment-4979232
direct from one of cams highest regarded officials, the windscreen is actually the highest pressure point of the cars body. raising the rear of the bonnet will force air into it at speed and not allow the hot air to exit the engine bay as efficiently as designed from factory. this is Fact.
as for temps of 85-90, I personally think this is fine. I once had an NXR that would not turn the rad fans on till 105 deg, keep in mind there are only electric fans on those cars.
https://www.sau.com.au/forums/topic/295916-always-hot/#findComment-4979434
the clutch fan should be pretty 'stiff'. if you spin it by hand (while the car is off :) ) it should stop pretty quick.
if it doesnt stop quickly, the fluid in the fan is most likely gone. so wen the prop spins the fan doesnt spin with it all the time.
so it could be moving, but not fast enough.
also the radiator could be clogged. it will flow, but not fast enough.
i went through this just a little while ago.
swapped the fan over as its was pretty much free spinning, then found the radiator channels to be blocked, to the point where there was
about 2-3mm for the water to flow.
also with the new turbo, the water lines? used the standard lines? the bango bolt pin hole could be blocked a little?
https://www.sau.com.au/forums/topic/295916-always-hot/#findComment-4979673
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
    • I forgot about my shiny new plates!
    • Well, apparently they do fit, however this wont be a problem if not because the car will be stationary while i do the suspension work. I was just going to use the 16's to roll the old girl around if I needed to. I just need to get the E90 back on the road first. Yes! I'm a believer! 🙌 So, I contacted them because the site kinda sucks and I was really confused about what I'd need. They put together a package for me and because I was spraying all the seat surfaces and not doing spot fixes I decided not to send them a headrest to colour match, I just used their colour on file (and it was spot on).  I got some heavy duty cleaner, 1L of colour, a small bottle of dye hardener and a small bottle of the dye top coat. I also got a spray gun as I needed a larger nozzle than the gun I had and it was only $40 extra. From memory the total was ~$450 ish. Its not cheap but the result is awesome. They did add repair bits and pieces to the quote originally and the cost came down significantly when I said I didn't need any repair products. I did it over a weekend. The only issues I had were my own; I forgot to mix the hardener into the dye two coats but I had enough dye for 2 more coats with the hardener. I also just used up all the dye because why not and i rushed the last coat which gave me some runs. Thankfully the runs are under the headrests. The gun pattern wasn't great, very round and would have been better if it was a line. It made it a little tricky to get consistent coverage and I think having done the extra coats probably helped conceal any coverage issues. I contacted them again a few months later so I could get our X5 done (who the f**k thought white leather was a good idea for a family car?!) and they said they had some training to do in Sydney and I could get a reduced rate on the leather fix in the X5 if I let them demo their product on our car. So I agreed. When I took Bec in the E39 to pick it up, I showed them the job I'd done in my car and they were all (students included) really impressed. Note that they said the runs I created could be fixed easily at the time with a brush or an air compressor gun. So, now with the two cars done I can absolutely recommend Colourlock.  I'll take pics of both interiors and create a new thread.
    • Power is fed to the ECU when the ignition switch is switched to IGN, at terminal 58. That same wire also connects to the ECCS relay to provide both the coil power and the contact side. When the ECU sees power at 58 it switches 16 to earth, which pulls the ECCS relay on, which feeds main power into the ECU and also to a bunch of other things. None of this is directly involved in the fuel pump - it just has to happen first. The ECU will pull terminal 18 to earth when it wants the fuel pump to run. This allows the fuel pump relay to pull in, which switches power on into the rest of the fuel pump control equipment. The fuel pump control regulator is controlled from terminal 104 on the ECU and is switched high or low depending on whether the ECU thinks the pump needs to run high or low. (I don't know which way around that is, and it really doesn't matter right now). The fuel pump control reg is really just a resistor that controls how the power through the pump goes to earth. Either straight to earth, or via the resistor. This part doesn't matter much to us today. The power to the fuel pump relay comes from one of the switched wires from the IGN switch and fusebox that is not shown off to the left of this page. That power runs the fuel pump relay coil and a number of other engine peripherals. Those peripherals don't really matter. All that matters is that there should be power available at the relay when the key is in the right position. At least - I think it's switched. If it's not switched, then power will be there all the time. Either way, if you don't have power there when you need it (ie, key on) then it won't work. The input-output switching side of the relay gains its power from a line similar (but not the same as) the one that feeds the ECU. SO I presume that is switched. Again, if there is not power there when you need it, then you have to look upstream. And... the upshot of all that? There is no "ground" at the fuel pump relay. Where you say: and say that pin 1 Black/Pink is ground, that is not true. The ECU trigger is AF73, is black/pink, and is the "ground". When the ECU says it is. The Blue/White wire is the "constant" 12V to power the relay's coil. And when I say "constant", I mean it may well only be on when the key is on. As I said above. So, when the ECU says not to be running the pump (which is any time after about 3s of switching on, with no crank signal or engine speed yet), then you should see 12V at both 1 and 2. Because the 12V will be all the way up to the ECU terminal 18, waiting to be switched to ground. When the ECU switches the fuel pump on, then AF73 should go to ~0V, having been switched to ground and the voltage drop now occurring over the relay coil. 3 & 5 are easy. 5 is the other "constant" 12V, that may or may not be constant but will very much want to be there when the key is on. Same as above. 3 goes to the pump. There should never be 12V visible at 3 unless the relay is pulled in. As to where the immobiliser might have been spliced into all this.... It will either have to be on wire AF70 or AF71, whichever is most accessible near the alarm. Given that all those wires run from the engine bay fusebox or the ECU, via the driver's area to the rear of the car, it could really be either. AF70 will be the same colour from the appropriate fuse all the way to the pump. If it has been cut and is dangling, you should be able to see that  in that area somewhere. Same with AF71.   You really should be able to force the pump to run. Just jump 12V onto AF72 and it should go. That will prove that the pump itself is willing to go along with you when you sort out the upstream. You really should be able to force the fuel pump relay on. Just short AF73 to earth when the key is on. If the pump runs, then the relay is fine, and all the power up to both inputs on the relay is fine. If it doesn't run (and given that you checked the relay itself actually works) then one or both of AF70 and AF71 are not bringing power to the game.
    • @PranK can you elaborate further on the Colorlock Dye? The website has a lot of options. I'm sure you've done all the research. I have old genuine leather seats that I have bought various refurbing creams and such, but never a dye. Any info on how long it lasts? Does it wash out? Is it a hassle? What product do I actually need? Am I just buying this kit and following the steps the page advises or something else? https://www.colourlockaustralia.com.au/colourlock-leather-repair-kit-dye.html
