Whoever owns the silver R33 GTS-T usually parked outside or next to 'Taxpert' you keep forgetting to close your fuel flap :)
Spotted R34 with carbon?? bonnet and boot heading onto Flemmington drive.
Also spotted a garage full of silvias in Amaroo (its in Gungahlin), blue one parked outside with smoked tail lights.
Edited by Helious
https://www.sau.com.au/forums/topic/30059-spotted/page/502/#findComment-4115074
Whoever owns the silver R33 GTS-T usually parked outside or next to 'Taxpert' you keep forgetting to close your fuel flap :3some:
If the R34 was silver that was me.
https://www.sau.com.au/forums/topic/30059-spotted/page/502/#findComment-4115929
Spotted Baconer doin his lanudry like me at the car wash in Belco hehe
haha terrible timing, i was sitting there for about 30 minutes twiddling my thumbs then as soon as the bay frees up i get a "hey Baconer" and i had to go
https://www.sau.com.au/forums/topic/30059-spotted/page/502/#findComment-4116029
followed then got followed by a black stock looking 33 down college street at around 520.
then followed a gun gray 32 gtst down haydon drive then ginnenderra, it had a full body kit (dont know what brand) and a big wing off the trunk (GT wing??) looked and sounded awesome.. havent seen it before either
https://www.sau.com.au/forums/topic/30059-spotted/page/502/#findComment-4121649
Spotted a white R33 leaving Bunnings on saturday (late spotted i know) but the driver waved so it counts. Had gold wheels i think?
Also, spotted a s13/14/15 hybrid. Pretty sure it was an S13 convertible with S14 rear and S15 front. Not yet sprayed, looks like a work in progress. It was interesting, i'll give it that.
https://www.sau.com.au/forums/topic/30059-spotted/page/502/#findComment-4122428
Yay, someone spotted me :blink:
I had to get a 'last minute gift' for Fathers Day from Bunnings since my brothers deviated from the plan..
https://www.sau.com.au/forums/topic/30059-spotted/page/502/#findComment-4122854
spotted silver r33 with kit travelling down tuggers parkway (you saw me im pretty sure) i think it might be naughtyruski, car looks exactly like hes avatar! Im guessing u live belco side of the world?
Yeh mate that was me. I didnt see you actually. Which way were you going? I was pretty out of it this morning, being that it was before 10am. I live in Gungahlin just working in Phillip for a bit
Edited by naughtyruski
https://www.sau.com.au/forums/topic/30059-spotted/page/502/#findComment-4125847
I remember, yeh wasnt sure if you were a member. I booted up to 170 after the camera then decided I might just tone it down a notch and follow someone else speeding. I am house sitting in belco, otherwise I would have followed you to gunners
na mate it was yesterday arvo sorry, i was going from woden to gungahlin. You took the belco exit and i took the gungy one, i was behind you for a bit then i over took ya! i was in the maroon one!
https://www.sau.com.au/forums/topic/30059-spotted/page/502/#findComment-4126212
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
