Spotted a white 34 GTT this morning on Belconnen way turning in to Oconnor. I think I've seen the same one a few times now.
Oh and spotted that fricking foxtel ad at the top being very annoying! Not a fan of the rollover type ads!
https://www.sau.com.au/forums/topic/30059-spotted/page/622/#findComment-5228738
Back way through CSIRO to bypass traffic ftw.
https://www.sau.com.au/forums/topic/30059-spotted/page/622/#findComment-5229456
Spotted Silver R35 at like 1pm ish hitting some golf balls on Griffith ovals (no idea what they technically are)....I was one of the wanks playing soccer on the oval. f**k yeah lunchtime soccer!
Anyway, your bloody car was blinding me every time I looked at it - and believe me that was a LOT lol...very sexy!
https://www.sau.com.au/forums/topic/30059-spotted/page/622/#findComment-5230971
There was a Series 4 blue RX7 on the side of the Barton Highway this morning just near crace, in case anyones knows of anyone missing one. Horrible POS chrome wheels.
I also spotted a Maxima TI with get this a GT-R badge high and proud on the boot, I didn't think they made Maxima GT-R's?
https://www.sau.com.au/forums/topic/30059-spotted/page/622/#findComment-5241486
Hahaha seen that car. The guy is an idiot. Not only is it spotting a boot badge, it has gtr front quarter panel badges too. This person has gone to alot of effort to be a dumbass.
https://www.sau.com.au/forums/topic/30059-spotted/page/622/#findComment-5243389
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
