Black R32 with red plated and first three letters of: RED this afternoon about 1pm heading from woden to Civic I don't know the name of the road. I pulled alongside you but your tint was so damn dark I couldn't see a thing inside.
Anyone know who this guy is?
https://www.sau.com.au/forums/topic/30059-spotted/page/16/#findComment-759219
If you mean R33 not R32 then it was probably me - were you in the black 350Z? I was wondering at the time whether it was someone off the boards. Next time I won't be so rude (was on the phone this time)...give me a wave or something. Yeah, the tint is dark innit...
https://www.sau.com.au/forums/topic/30059-spotted/page/16/#findComment-759259
nice black R32..number plate started with W... at Carlovers Tugg this arvo, waiting to use the bay I was in :)
sorry i took so long, had only just put my money in when you turned up, and she hadn't been washed for a few months :D
https://www.sau.com.au/forums/topic/30059-spotted/page/16/#findComment-759313
burgundy R32 GTST with DRIFTO plates crossing commonwealth ave bridge about 8:15am
Got me!
Don't you just love that big long left coming onto the bridge. Gotta watch those buses though!!!
Taking the GF to work each morning is not a chore.
Spotted a few times in QBN a smick 32 with black vented bonnet, big wing, big gold volks, very nice.
Also spotted a bargain at the QBN Scotts Big Boys Toys, White 33 GTS that use to be owned by a local guy. Well respected car with nice mods about 18k.
https://www.sau.com.au/forums/topic/30059-spotted/page/16/#findComment-759331
crap, just noticed the typo... meant R33
Yeah the 350Z was me :D
If I had of waved would you have even seen it? I have a mild tint but yours would have to be one of the darkest I have ever seen.
Yeah, it's not too bad to see out of, of course, nighttime can be a little interesting trying to use the side mirrors. Was on the car when I got it, considering getting it removed and replaced with something not quite so dark.
https://www.sau.com.au/forums/topic/30059-spotted/page/16/#findComment-759347
Spotted a few times in QBN a smick 32 with black bented bonnet, big wing, big gold volks, very nice.
Thats Goran's car...very tidy R32 GTR!
Always spotted at the Centrelink carpark in Tuggeranong - A jet black R34 GTT with massive wing, lowered to the absolute max! - Its for sale too - Nice car!
https://www.sau.com.au/forums/topic/30059-spotted/page/16/#findComment-759593
Spotted yesterday in Chifley parked near my mates house, a very clean White R33 GTST with a full GTR bodykit - We we're in the other white R33 that pulled up slowly alongside looked like we cased the joint. Sorry if u are on these boards didn't mean to scare ya, just havin a squizz!
https://www.sau.com.au/forums/topic/30059-spotted/page/16/#findComment-761155
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
